Burn an already converted project
mikesev
Post by mikesev »
When using the action, "burn an already converted project" finishes with the message that the burn completed successfully. However, the DVD is not recognized in any player.
Re: Burn an already converted project
Have you tried playing the DVD is a software player like the VLC player ?
mikesev
Post by mikesev »
Yes. I've tried VLC, VSO Media Player, Power DVD and a standalone DVD player.
mikesev wrote:Yes. I've tried VLC, VSO Media Player, Power DVD and a standalone DVD player.
The next thing you should try is to use a different brand of DVD media.
Also try a different burner if possible.
mikesev
Post by mikesev »
I've tried 2 different burners and I've used Verbatim DVD+R, MCC-004-00 from 2 pkgs.
Just to be sure. Try and play the conversion before burning via the video_ts folder.
mikesev
Post by mikesev »
The conversion plays fine via the video_ts folder.
Also, when doing the conversion, if I use the option to burn to DVD, it works OK. It's only when I try to burn an already converted project.
mikesev wrote: if I use the option to burn to DVD, it works OK. It's only when I try to burn an already converted project.
Strange !! Let's wait and see what Felicia has to say after the new year break.
mikesev
Post by mikesev »
Felicia - any ideas on this?
felicia
Post by felicia »
Hi, sorry for the delay, I'm looking into it, at the moment I have no explanation but I reproduce the issue.
felicia
Post by felicia »
New beta available here: http://forums.vso-software.fr/cxd-v7-beta-t19580.html should fix this an other weird issues
