can someone please explain me why when I select a .m2ts file it must be parsed for the actual duration which takes a long time from an original remuxed blu-ray (30 GB)?
Isn't the information that mediainfo reads out within a second enough (and CXV can do the same?)?
e.g.
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 4 Ref Frames
Duration : 2 h 0 min
Bit rate mode : Variable
Bit rate : 31.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Bits/(Pixel*Frame) : 0.624
Stream size : 26.0 GiB (95%)
Why parsing for actual duration when selecting .m2ts
Re: Why parsing for actual duration when selecting .m2ts
The parsing looks for time inconsistency in files that may have them. Those errors can't be found just parsing the header and will cause the conversion to fail if not fixed by the parsing.
Thanks a lot - I understand.
The m2ts file has been created with VSO blu-ray converter - so the header should be correct.
Timestamps are not in the header but in frames. We don't look for the stream generator because there's no way to check if the file has been modified afterwards.
