Not recognizing blu ray folder structure
jmanwf
Post by jmanwf »
Hi guys converter x to hd is not recognizing a blu ray folder structure even though it does normally. Log provided below
Here are the specks of the file this was created using dvdfab blu ray creator
Format : BDAV
Format/Info : Blu-ray Video
File size : 169 MiB
Duration : 1 min 28 s
Overall bit rate : 16.0 Mb/s
Maximum Overall bit rate : 48.0 Mb/s
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=3, N=25
Codec ID : 27
Bit rate mode : Variable
Bit rate : 15.1 Mb/s
Maximum bit rate : 22.5 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.292
Stream size : 160 MiB (95%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 129
Bit rate mode : Constant
Bit rate : 192 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 spf)
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : -30 ms
Stream size : 2.03 MiB (1%)
Service kind : Complete Main
ConvertXtoHD 3_crashlog.20171230.154902.289.log
(3.61 KiB) Downloaded 508 times
jmanwf
Re: Not recognizing blu ray folder structure
Post by jmanwf »
I am getting sound but no picture when converting this file in remux mode all other file work fine just not this one. This happens when i play it in my blu ray disk recorder
felicia
Post by felicia »
The excerpt you attached corresponds to just a ts of a little over a minute, is there any other stream in the folders?
jmanwf
Post by jmanwf »
Nope just used that as a test clip
felicia
Post by felicia »
A single clip is not a BD, and with that short duration it could be anything in the stream, please test with full a BD.
