:crash_log='C:\ProgramData\VSO\ConvertXtoDVD\7\Log\ConvertXtoDVD 7_crashlog.20180105.102938.588.log'
:library=false
:app_name=ConvertXtoDvd.exe
:app_version=7.0.0.52
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
11:04:07.405 Info Conversion failed after 00:33:47
10:30:19.353 Info [ ] Loop playback
10:30:19.350 Info [ ] Play titles one after the other
10:30:19.348 Info [x] Don't create title menu for single video
10:30:19.345 Info [ ] Return to title menu after titleset playback
10:30:19.343 Info [ ] Skip root menu initially
10:30:19.340 Info [ ] Auto-start playback
10:30:19.338 Info Template: Metallic (open style), contains 4 page(s)
10:30:19.338 Group Video DVD menu options
10:30:19.336 Info Video DVD format: PAL (25 Fps)
10:30:19.333 Info Output target size : DVD-5 (4300 MB)
10:30:19.331 Info Number of core(s) used for encoding : 4
10:30:19.329 Info Number of core(s) used for decoding : 4
10:30:19.327 Info [ ] Use 2 pass encoding
10:30:19.325 Info [ ] Use best video quality settings
10:30:19.323 Info [ ] Use hardware decoding (if possible)
10:30:19.321 Info Max simultaneous conversions: 4
10:30:19.321 Group Advanced encoding options
11:04:05.920 Error Error while encoding file: VTS_01_1.VOB
10:30:19.557 ------------ +--> [subtitle #3 - dvd_subtitle subtitle, 720x576 (Default)]
+-[subtitle #0 - srt subtitle]
+--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[audio aac primær lyd 2 Ka. 48000Hz , 96 Kbps]
+--> [video #1 - mpeg2video video, 720x576, yuv420p, 16x9, Pulldown: 23,98Fps -> 25,00Fps, 4480Kbps]
+-[video h264 1920x808 240:101 yuv420p, 23,98Fps, 1851Kbps ]
Outputfil: C:\Users\Svend Christensen\Documents\ConvertXtoDVD\The.Boondock.Saints.II.All.Saints.Day.2009.BluRay.1080p.YIFY\VIDEO_TS\VTS_01_1.VOB (DVD PAL)
Inputfil: \\HERREN\Downloads\The Boondock Saints II All Saints Day (2009) [1080p]\The.Boondock.Saints.II.All.Saints.Day.2009.BluRay.1080p.YIFY.mp4
Video filters used:
- DeInterlace filter: VSO
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: letterbox (Padding: top: 72, bottom: 72, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
10:30:19.554 Info Chapters to generate: 24 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, 0h55m00s, 1h00m00s, 1h05m00s, 1h10m00s, 1h15m00s, 1h20m00s, 1h25m00s, 1h30m00s, 1h35m00s, 1h40m00s, 1h45m00s, 1h50m00s, 1h55m00s, )
10:30:19.312 Info Menu fit: Text size reduced from 27.00 to 20.00 in style "Captions in title menu pages"
10:30:19.239 Info Menu fit: Text size reduced from 36.00 to 25.00 in style "Title of title menu pages"
10:30:18.677 Info Added in conversion queue list...
10:30:18.670 Info Menu fit: Text size reduced from 36.00 to 25.00 in style "Title of root menu pages"
10:30:18.149 Group ******************** Titelsæt #1 - ~117 min. Fil: "The.Boondock.Saints.II.All.Saints.Day.2009.BluRay.1080p.YIFY" -> VTS_01_1.VOB - DVD PAL ********************|GK_TITLESET|
10:30:18.145 Info Encoding options: Medium Project (Automatic)
10:30:18.144 Info Target size: 4,2 GB.
10:30:18.142 Important Setting queuer for DVD PAL output: [Wait: 0], [ld: 0], [Hd: 0], [MAM: 100], [RM: 100], [ALL: False]
10:30:18.140 Important 4 simultaneous conversions allowed
10:30:18.138 Info Don't log FFMpeg log events
10:30:18.137 ------------ ***************************************************Burn settings end****************************************************
10:30:18.135 Info Default speed selected: 4x
10:30:18.134 Info [ ] Delete vsomsl files after burn complete
10:30:18.133 Info [ ] Delete output folder after burn complete
10:30:18.131 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
10:30:18.130 Info SAO setting: Automatic
10:30:18.129 Info [x] Burn result to disk / as ISO file in working folder
10:30:18.127 ------------ **************************************************Burn settings begin***************************************************
10:30:18.127 Group Encoding session started at 10:30:18: 1 titleset(s) to encode|GK_CONVERT_SESSION|
10:30:16.643 Info Added stream "srt 720x576" in file "C:\Users\Svend Christensen\Downloads\The.Boondock.Saints.II.All.Saints.Day.REPACK.720p.Bluray.x264-HUBRIS.srt" to titleset "The.Boondock.Saints.II.All.Saints.Day.2009.BluRay.1080p.YIFY"
10:30:10.788 Info #1 h264 1920x808 240:101 yuv420p, 23,98Fps, 1851Kbps
10:30:10.786 Group Video streams
10:30:10.786 Info #2 aac primær lyd 2 Ka. 48000Hz , 96 Kbps - Unspecified
10:30:10.786 Group Audio streams
10:30:10.786 Group Added file: \\HERREN\Downloads\The Boondock Saints II All Saints Day (2009) [1080p]\The.Boondock.Saints.II.All.Saints.Day.2009.BluRay.1080p.YIFY.mp4
10:29:54.382 Info Menu templates loaded: 20
10:29:51.254 Info Kommando: 0 parameter(s)
Param #00: "C:\Program Files (x86)\VSO\ConvertX\7\ConvertXtoDvd.exe"
10:29:51.253 Info Total fysisk hukommelse : 15305 Mb.
Tilgængelig fysisk hukommelse : 12028 Mb.
Memory Load : 21%
Virtuel hukommelse : 4095 Mb.
Tilgængelig virtuel hukommelse : 3666 Mb.
Tilgængelig udvidet hukommelse : 0 Mb.
Total hukommelse : 17609 Mb.
Tilgængelig hukommelse : 12494 Mb.
10:29:51.252 Info Processor AMD A10-7700K Radeon R7, 10 Compute Cores 4C+6G with 4/4 core(s) CPU
Støttede instruktion: MMX,ExMMX,sse,sse2 (slow),sse3,sse41,sse42,sse4A,avx,bmi1,aes,tbm,xop,Fma4
10:29:51.241 Info User OS: Windows 10 Pro, Microsoft Windows 10 Professional (Build 16299)
filnavn : C:\Program Files (x86)\VSO\ConvertX\7\ConvertXtoDvd.exe
filversion : 7.0.0.52
Brugersprog : Dansk (Danmark)
Systemsprog : Dansk (Danmark)
10:29:50.987 Info License status: active customer license
10:29:50.986 Info License type: commercial (online activated)
10:29:50.986 Info Computer ID: 848670
10:29:50.985 Group License
10:29:38.628 Info Loading templates from: "C:\Users\Svend Christensen\Documents\ConvertXtoDVD_Resources\Templates\"
10:29:38.627 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoDVD\7\Templates\"
10:29:38.623 ------------ **************************ConvertXtoDvd.exe:4400 Log session start 2018-01-05 at 10:29:37.742***************************
10:29:38.613 Info 1 writer(s) found.
10:29:38.587 Group Burn engine events
