when VMP is playing a file and I double-click a different audio/video file in the file explorer (DOpus), VMP does not start to play this different file. It only adds this file to the playlist. Can this behaviour be changed so VMP stops playing the old file and starts to play the last chosen file?
Thank you.
Simple problem: play file on double-click?
Re: Simple problem: play file on double-click?
I will ad a settings in the playback options to switch the behaviour.
Thank you very much.
I think this would really enhance the usability of VMP.
Thanks for adding this setting to VMP, and for making a great program even better!
Peter.
Peter.
