"... remux not allowed: source is not compatible structure"
ira
Post by ira »
Both vso_convertxtodvd_setup_7.0.0.55b: and vso_convertxtovideo2_setup_2.0.0.85b: failed to complete the conversion to DVD. Each attempt halted approx 75% through with the dreaded "Damm, we have a problem.' I tried changing "Allow Smart Copy" from it's default of "... only if source is a compliant structure" to "Disabled." It did not resolve the problem. Note: I am not using vso_convertxtodvd_setup_7.0.0.56b for reasons I stated in a different post that you've not yet responded to? I doubt that 56b would solve this issue. Below are part of each log and the 'Media Info' from the source file.
IMPORTANT: VideoRedo TV Suite Ver 5.3 by DRD Systems, another product I am registered with [for many years] had NO PROBLEM rendering the source: The Special Relationship - Michael Sheen, Helen McCrory, Dennis Quaid, Hope Davis 2010.mp4 to DVD 5.1, and created the DVD media and plays ok.
Here are the log files:
:std_log='C:\ProgramData\VSO\ConvertXtoDVD\7\Log\ConvertXtoDVD 7_mainlog.20180203.125559.143.log'
:library=false
:app_name=ConvertXtoDvd.exe
:app_version=7.0.0.55
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=stopped
:group_indent=4
12:55:59.115 ------------ ***************ConvertXtoDvd.exe:7768 Log session stop after 28 minute(s) 43 second(s) 133 millisecond(s)***************
12:55:57.468 Info Thumber terminated
12:55:57.366 Info Waiting for thumber to end
12:55:51.587 Info Removed segment: The Special Relationship - Michael Sheen, Helen McCrory, Dennis Quaid, Hope Davis 2010
12:55:48.808 Info Stream "0, [eng] aac main audio 6 Ch. 48000Hz , 224 Kbps", remux not allowed: source is not compatible structure
^^^Repeated 4 Times in 3 millisecond(s)^^^
12:55:22.737 Group Audio log (this could get bloated
12:37:47.438 Group Audio log (this could get bloated
12:55:23.219 Info Conversion failed after 00:17:35
12:37:47.566 Info [ ] Loop playback
12:37:47.566 Info [x] Play titles one after the other
12:37:47.565 Info [ ] Return to title menu after titleset playback
12:37:47.564 Info [x] Skip root menu initially
12:37:47.564 Info [x] Auto-start playback
12:37:47.563 Info No menu generated
12:37:47.563 Group Video DVD menu options
12:37:47.562 Info Video DVD format: NTSC (30 Fps)
12:37:47.562 Info Output target size : DVD-5 (4300 MB)
12:37:47.561 Info Number of core(s) used for encoding : 8
12:37:47.560 Info Number of core(s) used for decoding : 8
12:37:47.560 Info [ ] Use 2 pass encoding
12:37:47.559 Info [ ] Use best video quality settings
12:37:47.559 Info [ ] Use hardware decoding (if possible)
12:37:47.558 Info Max simultaneous conversions: 8
12:37:47.558 Group Advanced encoding options
12:55:22.672 Error Error while encoding file: VTS_01_1.VOB
12:37:47.703 ------------ +--> [audio #2 - ac3 audio, 48000Hz, 5.1 Ch. back, 448000 bps [English]]
+-[audio [eng] aac main audio 6 Ch. 48000Hz , 224 Kbps]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, Pulldown: 23.98Fps -> 29.97Fps, 5730Kbps]
+-[video h264 1920x816 40:17 yuv420p, 23.98Fps, 2500Kbps ]
Output file: C:\Users\Ira Lieberman\Documents\ConvertXtoDVD\The Special Relationship - Michael Sheen, Helen McCrory, Dennis Quaid, Hope Davis 2010\VIDEO_TS\VTS_01_1.VOB (DVD NTSC)
Input file: C:\tmp\The Special Relationship - Michael Sheen, Helen McCrory, Dennis Quaid, Hope Davis 2010.mp4
Video filters used:
- DeInterlace filter: VSO
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: letterbox (Padding: top: 58, bottom: 58, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
12:37:47.701 Info Chapters to generate: 19 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, 0h55m00s, 1h00m00s, 1h05m00s, 1h10m00s, 1h15m00s, 1h20m00s, 1h25m00s, 1h30m00s, )
12:37:47.542 Info Added in conversion queue list...
12:37:47.439 Group ******************** Titleset #1 - ~92 min. File: "The Special Relationship - Michael Sheen, Helen McCrory, Dennis Quaid, Hope Davis 2010" -> VTS_01_1.VOB - DVD NTSC ********************|GK_TITLESET|
12:37:47.437 Info Encoding options: Medium Project (Automatic)
12:37:47.437 Info Target size: 4.2 GB.
12:37:47.436 Important Setting queuer for DVD NTSC output: [Wait: 0], [ld: 0], [Hd: 0], [MAM: 100], [RM: 100], [ALL: False]
12:37:47.436 Important 8 simultaneous conversions allowed
12:37:47.435 Info Don't log FFMpeg log events
12:37:47.434 ------------ ***************************************************Burn settings end****************************************************
12:37:47.434 Info Default speed selected: Max
12:37:47.433 Info [x] Delete vsomsl files after burn complete
12:37:47.433 Info [ ] Delete output folder after burn complete
12:37:47.432 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
12:37:47.432 Info SAO setting: Automatic
12:37:47.431 Info [x] Burn result to disk / as ISO file in working folder
12:37:47.431 ------------ **************************************************Burn settings begin***************************************************
12:37:47.431 Group Encoding session started at 12:37:47 PM: 1 titleset(s) to encode -> Failed after 00:17:35|GK_CONVERT_SESSION|
:std_log='C:\ProgramData\VSO\ConvertXtoVideo Ultimate\2\Log\ConvertXtoVideo Ultimate 2_mainlog_.20180203.132651.591.log'
:library=false
:app_version=2.0.0.85
:most_recent=first
:status=stopped
:group_indent=4
13:26:51.563 ------------ *************vsoVideoConverter.exe:9736 Log session stop after 29 minute(s) 44 second(s) 728 millisecond(s)*************
13:16:58.765 Info An error occured while converting
13:26:50.752 Important Setting queuer for MKV (Matroska) output: [Wait: 4000], [ld: 1000], [Hd: 10000], [MAM: 400], [RM: 500], [ALL: False]
13:26:50.752 Important 8 simultaneous conversions allowed
13:26:49.574 Important Setting queuer for MKV (Matroska) output: [Wait: 4000], [ld: 1000], [Hd: 10000], [MAM: 400], [RM: 500], [ALL: False]
13:26:49.574 Important 8 simultaneous conversions allowed
13:26:47.794 Important Setting queuer for DVD NTSC output: [Wait: 0], [ld: 0], [Hd: 0], [MAM: 100], [RM: 100], [ALL: False]
13:26:47.794 Important 8 simultaneous conversions allowed
12:59:55.644 Info Description:
12:59:55.644 Info Template name: DVD Video
12:59:55.644 Info Name: NTSC 16/9
12:59:55.644 Info Output folder:
12:59:55.644 Info codec=mpeg2video
12:59:55.644 Info width=720
12:59:55.644 Info height=480
12:59:55.644 Info time_base=1001/30000
12:59:55.644 Info dar=16/9
12:59:55.644 Info me_method=epzs
12:59:55.644 Info mbd=simple
12:59:55.644 Info trellis=0
12:59:55.644 Group MPEG2VIDEO, 720x480, 29.97Fps
12:59:55.644 Info codec=dvd_subtitle
12:59:55.644 Group DVD_SUBTITLE
12:59:55.644 Group Profile settings
12:59:55.644 Info [ ] Loop playback
12:59:55.644 Info [x] Play titles one after the other
12:59:55.644 Info [ ] Return to title menu after titleset playback
12:59:55.644 Info [x] Skip root menu initially
12:59:55.644 Info [x] Auto-start playback
12:59:55.644 Info No menu generated
12:59:55.644 Group Video DVD menu options
12:59:55.644 Info Video DVD format: NTSC (30 Fps)
12:59:55.644 Info Output target size : DVD-5 (4300 MB)
12:59:55.644 Info Number of core(s) used for encoding : 8
12:59:55.644 Info Number of core(s) used for decoding : 8
12:59:55.644 Info [ ] Use 2 pass encoding
12:59:55.644 Info [ ] Use best video quality settings
12:59:55.644 Info [ ] Use hardware decoding (if possible)
12:59:55.644 Info Max simultaneous conversions: 8
12:59:55.644 Group Advanced encoding options
13:16:58.612 Error Error while encoding file: VTS_01_1.VOB
13:16:58.415 Error [muxer][dvd]: Pulldown failed on GOP at PTS 369882513, LBA 1043114, with 5 frames
13:16:58.349 Error [decoder][aac]: channel element 0.0 is not allocated
^^^Repeated 21 Times in 65 millisecond(s)^^^
12:59:55.778 ------------ +--> [audio #2 - ac3 audio, 48000Hz, 5.1 Ch. back, 448000 bps [English]]
Output file: C:\Users\Ira Lieberman\Documents\ConvertXtoVideo Ultimate\The Special Relationship - Michael Sheen, Helen McCrory, Dennis Quaid, Hope Davis 2010\NTSC 169\VIDEO_TS\VTS_01_1.VOB (DVD NTSC)
Video filters used:
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: automatic (Padding: top: 34, bottom: 34, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 118, right: 118)
12:59:55.778 Info Chapters to generate: 10 (0h00m00s, 0h10m00s, 0h20m00s, 0h30m00s, 0h40m00s, 0h50m00s, 1h00m00s, 1h10m00s, 1h20m00s, 1h30m00s, )
12:59:55.777 Important Starting video encoding: [Memory load 38%] [Available virtual memory 3572 Mb.]
12:59:55.637 Info Added in conversion queue list...
12:59:55.634 Group ******************** Titleset #1 - ~92 min. File: "The Special Relationship - Michael Sheen, Helen McCrory, Dennis Quaid, Hope Davis 2010" -> VTS_01_1.VOB - DVD NTSC ********************|GK_TITLESET|
12:59:55.633 Info Encoding options: Medium Project (Automatic)
12:59:55.633 Info Target size: 4.2 GB.
12:59:55.633 Important Setting queuer for DVD NTSC output: [Wait: 0], [ld: 0], [Hd: 0], [MAM: 100], [RM: 100], [ALL: False]
12:59:55.633 Important 8 simultaneous conversions allowed
12:59:55.462 Important Setting queuer for DVD NTSC output: [Wait: 0], [ld: 0], [Hd: 0], [MAM: 100], [RM: 100], [ALL: False]
12:59:55.462 Important 8 simultaneous conversions allowed
12:59:55.393 Group DVD Video NTSC 16/9|GK_CONVERT_SESSION|
Media Info for The Special Relationship.txt
(4.05 KiB) Downloaded 392 times
Ira
reddwarf4ever
Re: "... remux not allowed: source is not compatible structu
Post by reddwarf4ever »
Try running in safe mode...
Works for me when I have problems
Good luck
