ConvertXtoDVD of 7.0.0.56 (from VSO products download site.)
7.0.0.56 Released February 20th 2018
0013453: [Feature Request] Add thumbs to section bar
0013448: [Bug] Progress fomr not always appears on collaing form's center
0013446: [Bug] Exception when opening cut tab
0013442: [Bug] Burning an already converted project may produce bad disks
0013437: [Bug] Delete folder after burn not working if ISO is selected
0013432: [Bug] Overhaul file loading (May fix random load deadlock)
0013430: [Feature Request] Add thumbs to sections in cut tab
0013428: [Feature Request] Add thumbs when hovering video trackbar
0013419: [Bug] Program prevents batcher to switch to next item if output is ISO
0013417: [Feature Request] Detect stt file language if present in filename
0013402: [Bug] Any way to keep "Sound Events" preferences?
0013408: [Bug] Template editor - Resources not remembered if not copied
0013406: [Bug] Template editor - Button overlays are not remembered
0013404: [Bug] Separate smart copy option for video, audio and subtitles
0013381: [Feature Request] Detail reasons to refuse remux
0013368: [Bug] conversion fails with subrip because of unhandled exception
0013357: [Bug] Default typesetting not applied if custom
0013394: [Bug] If source is DVD only beginning of video is read
0013390: [Bug] Conversion files if last project name letter is a space for DVD output
0013387: [Feature Request] Add support for F4V files
0010703: [Bug] complex ass subtitles do no display in CXD preview or on output
0013370: [Bug] Delete after burn option no longer works
0013364: [Bug] Audio edition for menu has issue with drop down translation visibility
ConvertXtoDVD - 7.0.0.56 - Released 2018-01-16 (from forum)
- 0013453: [Feature Request] Add thumbs to section bar (felicia)
- 0013448: [Bug] Progress fomr not always appears on collaing form's center (felicia)
- 0013446: [Bug] Exception when opening cut tab (felicia)
- 0013442: [Bug] Burning an already converted project may produce bad disks (felicia)
- 0013437: [Bug] Delete folder after burn not working if ISO is selected (felicia)
Is there two issues of version 7.0.0.56 ?
The release dates don't match and some of the version history is missing.
Same Version Released On Different Dates ?
Re: Same Version Released On Different Dates ?
when i download both exe files its totally same and subtitle language detection is still not working best chooise is 7.xxx.40 and i think felicia doest work on convertxtodvd so updates doesnt come common and quick as before. they should find a programmer immediately.
Felicia has left VSO. I have been collaborating with Felicia on CXtoDVD 7 the Template editor, extra resources.flamfuser wrote:i think felicia doest work on convertxtodvd so updates doesnt come common and quick as before. they should find a programmer immediately.
I don't know how is working on CXtoDVD now.
