I have a 1280*720 video (no black bars) that I want to output at half the size i.e. 640*360 (no black bars).
Been playing around with the values in the Video fit method menu but can't get it to work.
Suggestions?
Video fit method
Re: Video fit method
Nine days and no reply.
I thought this was an easy question to answer for the VSO savvy people.
That is not easy resolution:
https://en.wikipedia.org/wiki/Graphics_ ... lution#nHD
OK, if perfect scaling is not possible what values/settings do I use to get somewhere near?
The problem I have right now is that when I pad the black bars remain no matter what.
You should try resolutions that are multiples of 16, 360 is not, and pads are added.
So there is no way to reduce the resolution and get rid of the black bars?
No easy way and there is no use for non-standard file, it will always have black bars when playing on anything else than computer.
The target device in this case is the computer.
But it's all right, I found a web based service that did what I was looking for and the video was converted in a matter of seconds.
