I am new to video editing . I have a long project with multiple parts. After I have finished edits and cutting a part, is it saved somewhere? Should it be converted or do you only convert the fully edited project.
I am confused about how to save part of a project and then work on other parts the next day. Do I have to do all my editing in one day?
Save the work as a project from the file menu. Don't move or delete anything after saving a project. You can come back and load the project anytime, even after switching off your computer and continue from there. Or convert the project.
A little "trick". Produce another project. You don't have to go into any details. Just load a movie and from the file menu choose Save Project As. That will take you to where all the projects are stored by default. You will find the project you have previously saved there. It would probably be in the Documents folder.
