I have been using convert x to dvd with quite a bit of success to convert video files to dvd format so they can be played on my dvd player. However I have recently bought a blue ray burner and some blue ray discs I was wondering can I use convert x to dvd to convert video files to blueray format on blank blueray discs so they can be played on my blueray player connected to my tv?
If not do I have to buy a new program that can convert video format to blueray and burn on blueray discs so so they can be played on my blueray player?
thanks for taking the time to read my question
can convertxtodvd be used to convert to bluray
- VSO Fanatic
Re: can convertxtodvd be used to convert to bluray
No
ConvertXtoVideo do that job
You need ConvertXtoHDMrCman wrote:I have been using convert x to dvd with quite a bit of success to convert video files to dvd format so they can be played on my dvd player. However I have recently bought a blue ray burner and some blue ray discs I was wondering can I use convert x to dvd to convert video files to blueray format on blank blueray discs so they can be played on my blueray player connected to my tv?
http://www.vso-software.fr/products/convert-x-to-hd/
ConvertXtoVideo doesn't do that job either. That's for converting eg AVI into MP4deadlyshadow wrote:No
ConvertXtoHD is the one
Desktop: Project Phoenix
