Hi everyone
I am new to this program and don't want to loose time and material.
So how can I get the size of the files on DVD before burning it.
Or can I add another file or does the file(s) fit on a DVD.
If the question was answered please refer to it.
Pierre
Size on DVD
Re: Size on DVD
On the bottom left corner of the interphase you should see the indication of the space that the movie would occupy on a DVD. You will be adviced if you should use a double layer DVD for better quality.
Re: Size on DVD
Hi Coral,
Sorry to be so late to reply, I was programming Adobe Bridge with a new menu and didn't notice my email notice
I am using version 7.0.0.56
On the left corner I see: 1 titleset(s), Total time ~ 02:22:49
This doesn't tell me how much space is taken by the files on DVD
Is there a way to change it to indicate 1.23 GB free from 4.37 GB which would be quite practical
Thanks for your prompt reply, it is greatly appreciated
Pierre
Pierre
Re: Size on DVD
Hello Pierre,
What I meant is the indicator with the 3 different colours as in the attached picture.
This should give you an indication of the converted movie quality according to the DVD media in use (single layer or double layer)
- Encodeing Indicator.jpg (14.79 KiB) Viewed 3239 times
