Cutting Bug ?
Nemesh
Cutting Bug ?
Post by Nemesh »
Have overhere all episodes of a Blu-Ray series.
Except for the first episode, all the other .srt files have no subtitle for the intro's (episode 2 - 10).
So, the main part of the episode is subtitled except for the intro.
So, I used the scissor the remove the intro on episode 2.
Video: 1080p@ 23.976
Audio: DTS-HD Master Audio 5.1
Subtitle: Dutch.
What dot I do:
1. Load the episode in ConvertXtoHD version 3.0.0.61
2. Select the scissor.
3. Set the first marker at: 00:00:00:000
4. Set the second marker at 00:00:55:806
5. Press the Convert button.
ConvertXtoHD does it job however when I watch de result, the dutch subtitles are NOT beeing displayed.
Openend the stream-file with TsMuxer and saw that the subtitle is in the file.
So, to be sure I opened the working file with Windows Media Player and skiped ahead to around 53 seconds .
No problems with the working files, the subtitles are beeing displayed.
Is this a possible bug in ConverXtoHD ?
With much regards,
Nemesh
