Convertx latest Update
moxley108
Post by moxley108 »
Hi Folks
from loading cxdvd 7 0 0 62 I'm having to find the dvd drive and set speed as the software is spotting another drive which I don't use, have tried for quite a while to get it to remember the drive and speed I'm setting but it always comes back to the one it chooses. This has only happened since update as usually software just goes to usual folder and no trouble all settings remain the same . Please could you offer any suggestions as its a bit of a faf having to set dvd recorder going because software is waiting.
Re: Convertx latest Update
It appears that this latest version is messed up. Perhaps you should remain with version 7.0.0.61, untill the next fixed version. I have posted a request to VSO.
