Bug: burning the DVD twice
mrupp
Post by mrupp »
I think I encountered a bug: while burning the converted project I activated the checkbox to overwrite rewritable media without prompting. Then, after the burning finished, the DVD wasn't ejected (althought the checkbox to do so was checked) but erased and burned once more. Then, after the 2nd burn, the disc was ejected as expected.
I'm using version 7.0.0.64 which is the latest version at this time of writing.
I hope you can reproduce this and fix it for the next version.
Cheers,
Michael
