DVD jumps back to first title
brosello@yahoo.com
Post by brosello@yahoo.com »
I use this software to record music videos to a DVD for my road trips. The issue I have is that whenever I skip a video title (music video), when the title I skipped to ends, it jumps back to the first title. Unless I click next title before the video ends. If I forget to select next video at any time after initially skipping a title, it starts the DVD all over again. Is there any setting I should select to avoid this? I usually record the DVD with the "No Menu" option. Any help with this would be appreciated. I am running the most recent version of 7.0.0.64
Re: DVD jumps back to first title
That is something that can be set on some DVD players, check settings on that player. Something like "what to do after title is finished".
This is NOT CxDVD issue, it is DVD standard.
ichido
Post by ichido »
There is a setting in convert. Go to default setting and to the drop down menu options and on the right check the box that say play titles one after the other. This should do it for you.
