Youtube not detecting
NBTBRV8
Post by NBTBRV8 »
When I manually copy in a link it doesn't detect and the auto scan initially finds it but quickly fails. The log says that "Signature extraction failed".
I am using 5.01.55
Any clues how to fix?
Jen2
Re: Youtube not detecting
Post by Jen2 »
Ditto for having this issue. Nov. 28 it was fine, running version 5.0.1.55 and now I can't download anything from YouTube either through detection or download URL.
Thanks!
Did you get it working now?
I have been using vers 50155 Ultimate since mid September 2018 and works 95% of the time.
I just copied this url and it downloaded from youtube successfully.
Maybe try doing uninstall and clean install to see if that helps
NBTBRV8
Post by NBTBRV8 »
No, I still have it.
I get the same error message for that particular video which is 1hr 26 min in length
I also get the message "not supported yet" on screen
dl not supported
NBTBRV8
Post by NBTBRV8 »
I am getting more of these now than I used to. So something has changed in recent weeks.
Must be time for VSO to update VSO Downloader to keep up with YouTube changes
NBTBRV8 wrote:I am getting more of these now than I used to. So something has changed in recent weeks.
Yes, Youtube is constantly changing to prevent downloads.
Hello VSO
Last update was5.0.1.55 Released 2018-09-12
Is next update planned for release soon?
NBTBRV8
Post by NBTBRV8 »
It would be nice for the Downloader to give us the option to just to download the audio only, not the video.
next beta version 50166 just released
Jen2
Post by Jen2 »
Examples:
https://www.youtube.com/watch?v=e01P7dQ14XE
https://www.youtube.com/watch?v=M9BNoNFKCBI
Both start to download on auto-detect, and then says download error. If trying manual download it gives the same image that yoyo57 posted on Dec. 2 2:20am.
Thanks!
Jen2
Post by Jen2 »
Works with new update. Thanks!
umerjaved
Post by umerjaved »
I get the same error message for that particular video which is 1hr 26 min in length.
