ConvertX series do not use "disc-filling" - they create size-efficient output. With most default settings you get best possible output.
Using CBR is just a waste of disc space as in most movies there are scenes that do not require even third of CBR bitrate, and then again action scenes might require twice that causing lower quality.
I want to create a blue-ray disk 50GB
Re: I want to create a blue-ray disk 50GB
