Question about putting movies on 1 DVD
robertg_s
Post by robertg_s »
I have 2 movies that are 20 mins long (actually 1 is only 19 minutes) my question is regarding the ability to have no sound on each menu as it creates 2 with each movie. I am able to do it on the first one (the 20 minute movie) but when I click on the other I am getting sound. Is it because they are so short? I can try to explain this better if it sounds to confusing.
I know it is possible as I did when I had a 26 minute movie followed by another that was over an hour long.
robertg_s
Re: Question about putting movies on 1 DVD
Post by robertg_s »
Hi all
I tinkered around and found myself a workable fix for my problem. I just edited the root menu for the 2 movies and selected no audio in each.
Happy Holidays to you all.
