I've set max. downloads to 1 but always multiple simultaneous downloads happen.
In Options
- Detection / Auto download is disabled
- Download / Max simultaneous downloads are set to 1
- copy e.g. 10 URL's into clipboard
- click "Download URL"
- paste the URL's inside
- click Download button,
- then these 10 URL's are checked and finally listed
and then I have to select all and right click "Start/Resume"
.. and now all 10 are starting at the same time.
How can I avoid this and one-by-one start? What must I do?
Max downloads set to 1 but multiple simultaneous happen
Re: Max downloads set to 1 but multiple simultaneous happen
Hi there,
Thanks for pointing that out!
I've just reported this bug and we'll be working on it as soon as possible.
In case you would like to be informed of its resolution: http://bugs.vso-software.fr/view.php?id=13680
