any idea why this failed
ink
Post by ink »
after some 16 hours - it just failed [so I'm back to square one - and have to spend another 16 hours?] - but any idea why it failed... as if I don't know how to avoid it happening again it's a waste of time
here is the log [I'm not very technical - so if it's obvious to you... it isn't to me - so thanks for any help]
Argh too many characters - will try posting over a few posts
:std_log='C:\ProgramData\VSO\ConvertXtoHD\3\Log\ConvertXtoHD 3_mainlog.20190120.183326.238.log'
:library=false
:app_name=ConvertXToHD.exe
:app_version=3.0.0.58
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
18:32:57.324 Info Conversion failed after 10:35:43
07:57:13.878 Info [ ] Loop playback
07:57:13.874 Info [ ] Play titles one after the other
07:57:13.871 Info [ ] Don't create title menu for single video
07:57:13.867 Info [x] Return to title menu after titleset playback
07:57:13.863 Info [ ] Skip root menu initially
07:57:13.860 Info [ ] Auto-start playback
07:57:13.856 Info Template: 10 titles per page without sub menus (open style), contains 1 page(s)
07:57:13.856 Group Blu-ray/AVCHD menu options
07:57:13.852 Info Output target size : BD-50 (46000 MB)
07:57:13.849 Info Number of core(s) used for encoding : 8
07:57:13.845 Info Number of core(s) used for decoding : 8
07:57:13.841 Info [ ] Use 2 pass encoding
07:57:13.838 Info [ ] Use best video quality settings
07:57:13.834 Info [ ] Use hardware encoding (if possible)
07:57:13.830 Info [ ] Use hardware decoding (if possible)
07:57:13.826 Info Max simultaneous conversions: 4
07:57:13.826 Group Advanced encoding options
07:57:13.593 Info Menu fit: Text size reduced from 13.00 to 13.00 in style "Captions in title menu pages"
^^^Repeated 21 Times in 222 millisecond(s)^^^
07:57:13.582 Info Menu fit: Text size reduced from 17.00 to 13.00 in style "Captions in title menu pages"
07:57:13.479 Info Menu fit: Text size reduced from 17.00 to 17.00 in style "Captions in title menu pages"
^^^Repeated 6 Times in 57 millisecond(s)^^^
07:57:13.468 Info Menu fit: Text size reduced from 27.00 to 17.00 in style "Captions in title menu pages"
07:57:13.378 Info Menu fit: Text size reduced from 36.00 to 23.00 in style "Title of title menu pages"
07:57:12.990 Info Added in conversion queue list...
07:57:12.977 Info Added in conversion queue list...
07:57:12.962 Info Added in conversion queue list...
07:57:12.936 Info Added in conversion queue list...
07:57:12.870 Info Added in conversion queue list...
07:57:12.808 Info Added in conversion queue list...
18:32:49.805 ------------ *****************************************File encoded successfully: 00022.m2ts******************************************
18:32:49.799 Important Starting BD root menu encoding: [Memory load 72%] [Available virtual memory 1150 Mb.]
18:32:49.793 Info Building menus using template: 10 titles per page without sub menus (open style)
18:32:49.786 Info Building menu for The.Americans.S02E10.Yousaf.1080p.WEB-DL.DD5.1.h.264-NTb
18:32:49.779 Info Menu style: Root menu
18:32:49.773 Info Requested page index:
18:32:49.766 Info Render params in thumbs: False
18:32:49.715 Info subtitle #3 - Encoded subtitles frames: 1603
18:32:49.707 Info video #1 - Processed video frames: 69894 (69893 frames encoded, 0 frames dropped, 0 frames duplicated)
18:05:10.501 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,language=en,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
18:05:10.493 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [English] (Default)]
+-[subtitle #2 - subrip subtitle]
+--> [audio #2 - ac3 audio, 48000Hz, 5.1 Ch., 640000 bps [English]]
+-[audio [eng] ac3 main audio 6 Ch. 48000Hz , 384 Kbps]
+--> [video #1 - h264 video, 1920x1080, yuv420p, 16x9, 23.98Fps, 3500Kbps]
+-[video [eng] h264 1920x1080 16:9 yuv420p, 23.98Fps, 0Kbps ]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00022.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E10.Yousaf.1080p.WEB-DL.DD5.1.h.264-NTb.mkv
Video filters used:
- DeInterlace filter: VSO
18:05:10.487 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
18:05:10.480 Important Starting video encoding: [Memory load 72%] [Available virtual memory 1166 Mb.]
07:57:12.750 Info Added in conversion queue list...
07:57:12.699 Group ******************** Titleset #23 - ~48 min. File: "The.Americans.S02E10.Yousaf.1080p.WEB-DL.DD5.1.h.264-NTb" -> 00022.m2ts - Blu-ray ********************|GK_TITLESET|
18:05:04.877 ------------ *****************************************File encoded successfully: 00021.m2ts******************************************
18:05:04.871 Important Starting BD root menu encoding: [Memory load 74%] [Available virtual memory 1209 Mb.]
18:05:04.864 Info Building menus using template: 10 titles per page without sub menus (open style)
18:05:04.858 Info Building menu for The.Americans.S02E09.Martial.Eagle.1080p.WEB-DL.DD5.1.h.264-NTb
18:05:04.851 Info Menu style: Root menu
18:05:04.844 Info Requested page index:
18:05:04.838 Info Render params in thumbs: False
18:05:04.780 Info subtitle #3 - Encoded subtitles frames: 1797
18:05:04.773 Info video #1 - Processed video frames: 69811 (69810 frames encoded, 0 frames dropped, 0 frames duplicated)
17:37:32.375 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,language=en,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
17:37:32.368 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [English] (Default)]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00021.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E09.Martial.Eagle.1080p.WEB-DL.DD5.1.h.264-NTb.mkv
Video filters used:
17:37:32.362 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
17:37:32.355 Important Starting video encoding: [Memory load 72%] [Available virtual memory 1235 Mb.]
07:57:12.684 Info Added in conversion queue list...
07:57:12.637 Group ******************** Titleset #22 - ~48 min. File: "The.Americans.S02E09.Martial.Eagle.1080p.WEB-DL.DD5.1.h.264-NTb" -> 00021.m2ts - Blu-ray ********************|GK_TITLESET|
17:37:26.957 ------------ *****************************************File encoded successfully: 00020.m2ts******************************************
17:37:26.951 Important Starting BD root menu encoding: [Memory load 72%] [Available virtual memory 1278 Mb.]
17:37:26.945 Info Building menus using template: 10 titles per page without sub menus (open style)
17:37:26.939 Info Building menu for The.Americans.S02E08.New.Car.1080p.WEB-DL.DD5.1.h.264-NTb
17:37:26.933 Info Menu style: Root menu
17:37:26.927 Info Requested page index:
17:37:26.920 Info Render params in thumbs: False
17:37:26.871 Info subtitle #3 - Encoded subtitles frames: 1703
17:37:26.863 Info video #1 - Processed video frames: 69954 (69953 frames encoded, 0 frames dropped, 0 frames duplicated)
17:09:09.699 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,language=en,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
17:09:09.692 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [English] (Default)]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00020.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E08.New.Car.1080p.WEB-DL.DD5.1.h.264-NTb.mkv
Video filters used:
17:09:09.685 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
17:09:09.679 Important Starting video encoding: [Memory load 72%] [Available virtual memory 1315 Mb.]
07:57:12.622 Info Added in conversion queue list...
07:57:12.575 Group ******************** Titleset #21 - ~48 min. File: "The.Americans.S02E08.New.Car.1080p.WEB-DL.DD5.1.h.264-NTb" -> 00020.m2ts - Blu-ray ********************|GK_TITLESET|
17:09:04.041 ------------ *****************************************File encoded successfully: 00019.m2ts******************************************
17:09:04.035 Important Starting BD root menu encoding: [Memory load 71%] [Available virtual memory 1358 Mb.]
17:09:04.029 Info Building menus using template: 10 titles per page without sub menus (open style)
17:09:04.023 Info Building menu for The.Americans.S02E07.Arpanet.1080p.WEB-DL.DD5.1.h.264-NTb
17:09:04.017 Info Menu style: Root menu
17:09:04.011 Info Requested page index:
17:09:04.005 Info Render params in thumbs: False
17:09:03.960 Info subtitle #3 - Encoded subtitles frames: 1468
17:09:03.952 Info video #1 - Processed video frames: 60317 (60316 frames encoded, 0 frames dropped, 0 frames duplicated)
16:46:06.476 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,language=en,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
16:46:06.469 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [English] (Default)]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00019.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E07.Arpanet.1080p.WEB-DL.DD5.1.h.264-NTb.mkv
Video filters used:
16:46:06.463 Info Chapters to generate: 9 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, )
16:46:06.457 Important Starting video encoding: [Memory load 73%] [Available virtual memory 1383 Mb.]
07:57:12.563 Info Added in conversion queue list...
07:57:12.516 Group ******************** Titleset #20 - ~41 min. File: "The.Americans.S02E07.Arpanet.1080p.WEB-DL.DD5.1.h.264-NTb" -> 00019.m2ts - Blu-ray ********************|GK_TITLESET|
16:46:01.017 ------------ *****************************************File encoded successfully: 00018.m2ts******************************************
16:46:01.011 Important Starting BD root menu encoding: [Memory load 73%] [Available virtual memory 1424 Mb.]
16:46:01.004 Info Building menus using template: 10 titles per page without sub menus (open style)
16:46:00.999 Info Building menu for The.Americans.S02E06.Behind.the.Red.Door.1080p.WEB-DL.DD5.1.h.264-NTb
16:46:00.993 Info Menu style: Root menu
16:46:00.987 Info Requested page index:
16:46:00.981 Info Render params in thumbs: False
16:46:00.932 Info subtitle #3 - Encoded subtitles frames: 1802
16:46:00.925 Info video #1 - Processed video frames: 70177 (70176 frames encoded, 0 frames dropped, 0 frames duplicated)
16:19:43.286 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,language=en,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
16:19:43.280 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [English] (Default)]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00018.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E06.Behind.the.Red.Door.1080p.WEB-DL.DD5.1.h.264-NTb.mkv
Video filters used:
16:19:43.274 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
16:19:43.268 Important Starting video encoding: [Memory load 69%] [Available virtual memory 1468 Mb.]
07:57:12.496 Info Added in conversion queue list...
07:57:12.453 Group ******************** Titleset #19 - ~48 min. File: "The.Americans.S02E06.Behind.the.Red.Door.1080p.WEB-DL.DD5.1.h.264-NTb" -> 00018.m2ts - Blu-ray ********************|GK_TITLESET|
16:19:38.306 ------------ *****************************************File encoded successfully: 00017.m2ts******************************************
16:19:38.300 Important Starting BD root menu encoding: [Memory load 69%] [Available virtual memory 1511 Mb.]
16:19:38.294 Info Building menus using template: 10 titles per page without sub menus (open style)
16:19:38.289 Info Building menu for The.Americans.S02E05.The.Deal.1080p.WEB-DL.DD5.1.h.264-NTb
16:19:38.283 Info Menu style: Root menu
16:19:38.277 Info Requested page index:
16:19:38.271 Info Render params in thumbs: False
16:19:38.217 Info subtitle #3 - Encoded subtitles frames: 1849
16:19:38.210 Info video #1 - Processed video frames: 76243 (76242 frames encoded, 0 frames dropped, 0 frames duplicated)
15:50:39.392 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,language=en,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
15:50:39.385 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [English] (Default)]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00017.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E05.The.Deal.1080p.WEB-DL.DD5.1.h.264-NTb.mkv
Video filters used:
15:50:39.379 Info Chapters to generate: 11 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, )
15:50:39.373 Important Starting video encoding: [Memory load 68%] [Available virtual memory 1555 Mb.]
07:57:12.434 Info Added in conversion queue list...
07:57:12.388 Group ******************** Titleset #18 - ~53 min. File: "The.Americans.S02E05.The.Deal.1080p.WEB-DL.DD5.1.h.264-NTb" -> 00017.m2ts - Blu-ray ********************|GK_TITLESET|
15:50:33.666 ------------ *****************************************File encoded successfully: 00016.m2ts******************************************
15:50:33.661 Important Starting BD root menu encoding: [Memory load 68%] [Available virtual memory 1598 Mb.]
15:50:33.655 Info Building menus using template: 10 titles per page without sub menus (open style)
15:50:33.649 Info Building menu for The.Americans.S02E04.A.Little.Night.Music.1080p.WEB-DL.DD5.1.h.264-NTb
15:50:33.644 Info Menu style: Root menu
15:50:33.638 Info Requested page index:
15:50:33.632 Info Render params in thumbs: False
15:50:33.582 Info subtitle #3 - Encoded subtitles frames: 1845
15:50:33.575 Info video #1 - Processed video frames: 67368 (67367 frames encoded, 0 frames dropped, 0 frames duplicated)
15:21:20.517 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,language=en,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
15:21:20.511 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [English] (Default)]
+-[video [eng] h264 1916x1076 203:114 yuv420p, 23.98Fps, 0Kbps ]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00016.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E04.A.Little.Night.Music.1080p.WEB-DL.DD5.1.h.264-NTb.mkv
Video filters used:
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: letterbox (Padding: top: 2, bottom: 2, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
15:21:20.505 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
15:21:20.499 Important Starting video encoding: [Memory load 69%] [Available virtual memory 1620 Mb.]
07:57:12.372 Info Added in conversion queue list...
07:57:12.325 Group ******************** Titleset #17 - ~46 min. File: "The.Americans.S02E04.A.Little.Night.Music.1080p.WEB-DL.DD5.1.h.264-NTb" -> 00016.m2ts - Blu-ray ********************|GK_TITLESET|
15:20:40.567 ------------ *****************************************File encoded successfully: 00015.m2ts******************************************
15:20:40.559 Important Starting BD root menu encoding: [Memory load 72%] [Available virtual memory 1110 Mb.]
15:20:40.550 Info Building menus using template: 10 titles per page without sub menus (open style)
15:20:40.520 Info Building menu for The.Americans.S02E03.The.Walk.In.1080p.WEB-DL.DD5.1.h.264-NTb
15:20:40.511 Info Menu style: Root menu
15:20:40.501 Info Requested page index:
15:20:40.488 Info Render params in thumbs: False
15:20:40.343 Info subtitle #3 - Encoded subtitles frames: 1562
15:20:40.333 Info video #1 - Processed video frames: 63899 (63898 frames encoded, 0 frames dropped, 0 frames duplicated)
14:31:36.864 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,language=en,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
14:31:36.850 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [English] (Default)]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00015.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E03.The.Walk.In.1080p.WEB-DL.DD5.1.h.264-NTb.mkv
Video filters used:
14:31:36.838 Info Chapters to generate: 9 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, )
14:31:36.829 Important Starting video encoding: [Memory load 72%] [Available virtual memory 1225 Mb.]
07:57:12.309 Info Added in conversion queue list...
07:57:12.263 Group ******************** Titleset #16 - ~44 min. File: "The.Americans.S02E03.The.Walk.In.1080p.WEB-DL.DD5.1.h.264-NTb" -> 00015.m2ts - Blu-ray ********************|GK_TITLESET|
15:21:15.027 ------------ *****************************************File encoded successfully: 00014.m2ts******************************************
15:21:15.021 Important Starting BD root menu encoding: [Memory load 69%] [Available virtual memory 1663 Mb.]
15:21:15.016 Info Building menus using template: 10 titles per page without sub menus (open style)
15:21:15.011 Info Building menu for The.Americans.S02E02.Cardinal.1080p.WEB-DL.DD5.1.h.264-NTb
15:21:15.006 Info Menu style: Root menu
15:21:15.000 Info Requested page index:
15:21:14.995 Info Render params in thumbs: False
15:21:14.943 Info subtitle #3 - Encoded subtitles frames: 1703
15:21:14.937 Info video #1 - Processed video frames: 65282 (65281 frames encoded, 0 frames dropped, 0 frames duplicated)
14:31:32.672 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,language=en,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
14:31:32.666 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [English] (Default)]
+-[video [eng] h264 1912x1072 239:134 yuv420p, 23.98Fps, 0Kbps ]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00014.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E02.Cardinal.1080p.WEB-DL.DD5.1.h.264-NTb.mkv
Video filters used:
14:31:32.660 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
14:31:32.654 Important Starting video encoding: [Memory load 69%] [Available virtual memory 1778 Mb.]
07:57:12.248 Info Added in conversion queue list...
07:57:12.202 Group ******************** Titleset #15 - ~45 min. File: "The.Americans.S02E02.Cardinal.1080p.WEB-DL.DD5.1.h.264-NTb" -> 00014.m2ts - Blu-ray ********************|GK_TITLESET|
14:31:27.072 ------------ *****************************************File encoded successfully: 00013.m2ts******************************************
14:31:27.067 Important Starting BD root menu encoding: [Memory load 69%] [Available virtual memory 1821 Mb.]
14:31:27.062 Info Building menus using template: 10 titles per page without sub menus (open style)
14:31:27.057 Info Building menu for The.Americans.S02E01.Comrades.1080p.WEB-DL.DD5.1.h.264-NTb
14:31:27.051 Info Menu style: Root menu
14:31:27.046 Info Requested page index:
14:31:27.041 Info Render params in thumbs: False
14:31:26.992 Info subtitle #3 - Encoded subtitles frames: 1857
14:31:26.986 Info video #1 - Processed video frames: 67610 (67609 frames encoded, 0 frames dropped, 0 frames duplicated)
13:37:45.729 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,language=en,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
13:37:45.720 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [English] (Default)]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00013.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E01.Comrades.1080p.WEB-DL.DD5.1.h.264-NTb.mkv
Video filters used:
13:37:45.706 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
13:37:45.698 Important Starting video encoding: [Memory load 69%] [Available virtual memory 1419 Mb.]
07:57:12.186 Info Added in conversion queue list...
07:57:12.143 Group ******************** Titleset #14 - ~47 min. File: "The.Americans.S02E01.Comrades.1080p.WEB-DL.DD5.1.h.264-NTb" -> 00013.m2ts - Blu-ray ********************|GK_TITLESET|
14:30:16.897 ------------ *****************************************File encoded successfully: 00012.m2ts******************************************
14:30:16.888 Important Starting BD root menu encoding: [Memory load 72%] [Available virtual memory 1269 Mb.]
14:30:16.880 Info Building menus using template: 10 titles per page without sub menus (open style)
14:30:16.864 Info Building menu for The Americans S01E13 The Colonel.1080p.WEB-DL.x264.anoXmous_
14:30:16.857 Info Menu style: Root menu
14:30:16.849 Info Requested page index:
14:30:16.842 Info Render params in thumbs: False
14:30:16.730 Info subtitle #4 - Encoded subtitles frames: 738
14:30:16.719 Info subtitle #3 - Encoded subtitles frames: 1254
14:30:16.705 Info video #1 - Processed video frames: 69224 (69225 frames encoded, 0 frames dropped, 2 frames duplicated)
13:37:41.689 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
13:37:41.683 ------------ +--> [subtitle #4 - hdmv_pgs_subtitle subtitle, 1920x1080 ]
+-[subtitle #0 - srt subtitle]
+--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 (Default)]
+--> [audio #2 - ac3 audio, 48000Hz, 5.1 Ch. back, 640000 bps]
+-[audio aac main audio 6 Ch. 48000Hz , 384 Kbps]
+-[video h264 1912x1072 239:134 yuv420p, 23.98Fps, 2091Kbps ]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00012.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 13\The Americans S01E13 The Colonel.1080p.WEB-DL.x264.anoXmous_.mp4
Video filters used:
13:37:41.677 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
13:37:41.672 Important Starting video encoding: [Memory load 66%] [Available virtual memory 1968 Mb.]
07:57:12.123 Info Added in conversion queue list...
07:57:11.957 Group ******************** Titleset #13 - ~48 min. File: "The Americans S01E13 The Colonel.1080p.WEB-DL.x264.anoXmous_" -> 00012.m2ts - Blu-ray ********************|GK_TITLESET|
13:34:45.394 ------------ *****************************************File encoded successfully: 00011.m2ts******************************************
13:34:45.387 Important Starting BD root menu encoding: [Memory load 68%] [Available virtual memory 1571 Mb.]
13:34:45.382 Info Building menus using template: 10 titles per page without sub menus (open style)
13:34:45.375 Info Building menu for The Americans S01E12 The Oath.1080p.WEB-DL.x264.anoXmous_
13:34:45.368 Info Menu style: Root menu
13:34:45.362 Info Requested page index:
13:34:45.353 Info Render params in thumbs: False
13:34:45.274 Info subtitle #4 - Encoded subtitles frames: 794
13:34:45.266 Info subtitle #3 - Encoded subtitles frames: 1284
13:34:45.258 Info video #1 - Processed video frames: 63205 (63206 frames encoded, 0 frames dropped, 2 frames duplicated)
12:43:41.592 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
12:43:41.585 ------------ +--> [subtitle #4 - hdmv_pgs_subtitle subtitle, 1920x1080 ]
+-[video h264 1912x1072 239:134 yuv420p, 23.98Fps, 2089Kbps ]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00011.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 12\The Americans S01E12 The Oath.1080p.WEB-DL.x264.anoXmous_.mp4
Video filters used:
12:43:41.578 Info Chapters to generate: 9 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, )
12:43:41.566 Important Starting video encoding: [Memory load 69%] [Available virtual memory 1282 Mb.]
07:57:11.934 Info Added in conversion queue list...
07:57:11.796 Group ******************** Titleset #12 - ~43 min. File: "The Americans S01E12 The Oath.1080p.WEB-DL.x264.anoXmous_" -> 00011.m2ts - Blu-ray ********************|GK_TITLESET|
12:25:00.255 ------------ *****************************************File encoded successfully: 00010.m2ts******************************************
12:25:00.250 Important Starting BD root menu encoding: [Memory load 71%] [Available virtual memory 904 Mb.]
12:25:00.245 Info Building menus using template: 10 titles per page without sub menus (open style)
12:25:00.240 Info Building menu for The Americans S01E11 Covert War.1080p.WEB-DL.x264.anoXmous_
12:25:00.235 Info Menu style: Root menu
12:25:00.230 Info Requested page index:
12:25:00.225 Info Render params in thumbs: False
12:25:00.161 Info subtitle #4 - Encoded subtitles frames: 801
12:25:00.153 Info subtitle #3 - Encoded subtitles frames: 1394
12:25:00.148 Info video #1 - Processed video frames: 62460 (62461 frames encoded, 0 frames dropped, 2 frames duplicated)
11:18:43.072 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=4
11:18:43.057 ------------ +--> [subtitle #4 - hdmv_pgs_subtitle subtitle, 1920x1080 ]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00010.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 11\The Americans S01E11 Covert War.1080p.WEB-DL.x264.anoXmous_.mp4
Video filters used:
11:18:43.047 Info Chapters to generate: 9 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, )
11:18:43.040 Important Starting video encoding: [Memory load 71%] [Available virtual memory 1230 Mb.]
07:57:11.780 Info Added in conversion queue list...
07:57:11.650 Group ******************** Titleset #11 - ~43 min. File: "The Americans S01E11 Covert War.1080p.WEB-DL.x264.anoXmous_" -> 00010.m2ts - Blu-ray ********************|GK_TITLESET|
13:33:08.697 ------------ *****************************************File encoded successfully: 00009.m2ts******************************************
13:33:08.688 Important Starting BD root menu encoding: [Memory load 71%] [Available virtual memory 1003 Mb.]
13:33:08.680 Info Building menus using template: 10 titles per page without sub menus (open style)
13:33:08.666 Info Building menu for The Americans S01E10 Only You.1080p.WEB-DL.x264.anoXmous_
13:33:08.653 Info Menu style: Root menu
13:33:08.639 Info Requested page index:
13:33:08.631 Info Render params in thumbs: False
13:33:08.522 Info subtitle #4 - Encoded subtitles frames: 832
13:33:08.508 Info subtitle #3 - Encoded subtitles frames: 1470
13:33:08.499 Info video #1 - Processed video frames: 67983 (67984 frames encoded, 0 frames dropped, 2 frames duplicated)
12:43:37.264 Important Resuming paused task
12:08:09.308 Important Pausing task because memory is runnng low
11:18:38.865 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=4
11:18:38.857 ------------ +--> [subtitle #4 - hdmv_pgs_subtitle subtitle, 1920x1080 ]
+-[video h264 1912x1072 239:134 yuv420p, 23.98Fps, 2088Kbps ]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00009.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 10\The Americans S01E10 Only You.1080p.WEB-DL.x264.anoXmous_.mp4
Video filters used:
11:18:38.849 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
11:18:38.841 Important Starting video encoding: [Memory load 69%] [Available virtual memory 1688 Mb.]
07:57:11.631 Info Added in conversion queue list...
07:57:11.469 Group ******************** Titleset #10 - ~47 min. File: "The Americans S01E10 Only You.1080p.WEB-DL.x264.anoXmous_" -> 00009.m2ts - Blu-ray ********************|GK_TITLESET|
13:37:36.582 ------------ *****************************************File encoded successfully: 00008.m2ts******************************************
13:37:36.577 Important Starting BD root menu encoding: [Memory load 66%] [Available virtual memory 2021 Mb.]
13:37:36.573 Info Building menus using template: 10 titles per page without sub menus (open style)
13:37:36.568 Info Building menu for The Americans S01E09 Safe House.1080p.WEB-DL.x264.anoXmous_
13:37:36.564 Info Menu style: Root menu
13:37:36.559 Info Requested page index:
13:37:36.555 Info Render params in thumbs: False
13:37:36.492 Info subtitle #4 - Encoded subtitles frames: 838
13:37:36.487 Info subtitle #3 - Encoded subtitles frames: 1438
13:37:36.482 Info video #1 - Processed video frames: 73078 (73079 frames encoded, 0 frames dropped, 2 frames duplicated)
12:43:36.447 Important Resuming paused task
12:08:09.295 Important Pausing task because memory is runnng low
11:18:34.767 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=4
11:18:34.762 ------------ +--> [subtitle #4 - hdmv_pgs_subtitle subtitle, 1920x1080 ]
ink
Re: any idea why this failed
Post by ink »
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00008.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 09\The Americans S01E09 Safe House.1080p.WEB-DL.x264.anoXmous_.mp4
Video filters used:
11:18:34.758 Info Chapters to generate: 11 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, )
11:18:34.753 Important Starting video encoding: [Memory load 67%] [Available virtual memory 2128 Mb.]
07:57:11.455 Info Added in conversion queue list...
07:57:11.317 Group ******************** Titleset #9 - ~50 min. File: "The Americans S01E09 Safe House.1080p.WEB-DL.x264.anoXmous_" -> 00008.m2ts - Blu-ray ********************|GK_TITLESET|
12:43:36.288 ------------ *****************************************File encoded successfully: 00007.m2ts******************************************
12:43:36.283 Important Starting BD root menu encoding: [Memory load 69%] [Available virtual memory 1335 Mb.]
12:43:36.278 Info Building menus using template: 10 titles per page without sub menus (open style)
12:43:36.274 Info Building menu for The Americans S01E08 Mutually Assured Destruction.1080p.WEB-DL.x264.anoXmous_
12:43:36.270 Info Menu style: Root menu
12:43:36.266 Info Requested page index:
12:43:36.261 Info Render params in thumbs: False
12:43:36.202 Info subtitle #4 - Encoded subtitles frames: 730
12:43:36.196 Info subtitle #3 - Encoded subtitles frames: 1288
12:43:36.190 Info video #1 - Processed video frames: 70523 (70524 frames encoded, 0 frames dropped, 2 frames duplicated)
12:25:00.757 Important Resuming paused task
12:08:09.284 Important Pausing task because memory is runnng low
11:18:30.732 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=4
11:18:30.727 ------------ +--> [subtitle #4 - hdmv_pgs_subtitle subtitle, 1920x1080 ]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00007.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 08\The Americans S01E08 Mutually Assured Destruction.1080p.WEB-DL.x264.anoXmous_.mp4
Video filters used:
11:18:30.722 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
11:18:30.718 Important Starting video encoding: [Memory load 65%] [Available virtual memory 2574 Mb.]
07:57:11.300 Info Added in conversion queue list...
07:57:11.170 Group ******************** Titleset #8 - ~49 min. File: "The Americans S01E08 Mutually Assured Destruction.1080p.WEB-DL.x264.anoXmous_" -> 00007.m2ts - Blu-ray ********************|GK_TITLESET|
11:15:33.640 ------------ *****************************************File encoded successfully: 00006.m2ts******************************************
11:15:33.635 Important Starting BD root menu encoding: [Memory load 67%] [Available virtual memory 2169 Mb.]
11:15:33.631 Info Building menus using template: 10 titles per page without sub menus (open style)
11:15:33.627 Info Building menu for The Americans S01E07 Duty and Honor.1080p.WEB-DL.x264.anoXmous_
11:15:33.622 Info Menu style: Root menu
11:15:33.618 Info Requested page index:
11:15:33.613 Info Render params in thumbs: False
11:15:33.540 Info subtitle #4 - Encoded subtitles frames: 672
11:15:33.535 Info subtitle #3 - Encoded subtitles frames: 1320
11:15:33.525 Info video #1 - Processed video frames: 61226 (61227 frames encoded, 0 frames dropped, 2 frames duplicated)
09:48:02.369 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=4
09:48:02.351 ------------ +--> [subtitle #4 - hdmv_pgs_subtitle subtitle, 1920x1080 ]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00006.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 07\The Americans S01E07 Duty and Honor.1080p.WEB-DL.x264.anoXmous_.mp4
Video filters used:
09:48:02.337 Info Chapters to generate: 9 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, )
09:48:02.326 Important Starting video encoding: [Memory load 71%] [Available virtual memory 1523 Mb.]
07:57:11.148 Info Added in conversion queue list...
07:57:11.013 Group ******************** Titleset #7 - ~42 min. File: "The Americans S01E07 Duty and Honor.1080p.WEB-DL.x264.anoXmous_" -> 00006.m2ts - Blu-ray ********************|GK_TITLESET|
11:18:25.526 ------------ *****************************************File encoded successfully: 00005.m2ts******************************************
11:18:25.521 Important Starting BD root menu encoding: [Memory load 64%] [Available virtual memory 2628 Mb.]
11:18:25.517 Info Building menus using template: 10 titles per page without sub menus (open style)
11:18:25.513 Info Building menu for The Americans S01E06 Trust Me.1080p.WEB-DL.x264.anoXmous_
11:18:25.509 Info Menu style: Root menu
11:18:25.505 Info Requested page index:
11:18:25.500 Info Render params in thumbs: False
11:18:25.437 Info subtitle #4 - Encoded subtitles frames: 707
11:18:25.432 Info subtitle #3 - Encoded subtitles frames: 1210
11:18:25.427 Info video #1 - Processed video frames: 74064 (74065 frames encoded, 0 frames dropped, 2 frames duplicated)
09:44:32.239 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=4
09:44:32.231 ------------ +--> [subtitle #4 - hdmv_pgs_subtitle subtitle, 1920x1080 ]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00005.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 06\The Americans S01E06 Trust Me.1080p.WEB-DL.x264.anoXmous_.mp4
Video filters used:
09:44:32.219 Info Chapters to generate: 11 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, )
09:44:32.198 Important Starting video encoding: [Memory load 71%] [Available virtual memory 1546 Mb.]
07:57:10.978 Info Added in conversion queue list...
07:57:10.838 Group ******************** Titleset #6 - ~51 min. File: "The Americans S01E06 Trust Me.1080p.WEB-DL.x264.anoXmous_" -> 00005.m2ts - Blu-ray ********************|GK_TITLESET|
11:11:43.516 ------------ *****************************************File encoded successfully: 00004.m2ts******************************************
11:11:43.508 Important Starting BD root menu encoding: [Memory load 70%] [Available virtual memory 1714 Mb.]
11:11:43.500 Info Building menus using template: 10 titles per page without sub menus (open style)
11:11:43.494 Info Building menu for The Americans S01E05 COMINT.1080p.WEB-DL.x264.anoXmous_
11:11:43.486 Info Menu style: Root menu
11:11:43.461 Info Requested page index:
11:11:43.448 Info Render params in thumbs: False
11:11:43.344 Info subtitle #4 - Encoded subtitles frames: 712
11:11:43.337 Info subtitle #3 - Encoded subtitles frames: 1060
11:11:43.326 Info video #1 - Processed video frames: 60273 (60274 frames encoded, 0 frames dropped, 2 frames duplicated)
09:41:56.922 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=4
09:41:56.915 ------------ +--> [subtitle #4 - hdmv_pgs_subtitle subtitle, 1920x1080 ]
+-[video h264 1912x1072 239:134 yuv420p, 23.98Fps, 2087Kbps ]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00004.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 05\The Americans S01E05 COMINT.1080p.WEB-DL.x264.anoXmous_.mp4
Video filters used:
09:41:56.904 Info Chapters to generate: 9 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, )
09:41:56.890 Important Starting video encoding: [Memory load 70%] [Available virtual memory 1551 Mb.]
07:57:10.823 Info Added in conversion queue list...
07:57:10.722 Group ******************** Titleset #5 - ~41 min. File: "The Americans S01E05 COMINT.1080p.WEB-DL.x264.anoXmous_" -> 00004.m2ts - Blu-ray ********************|GK_TITLESET|
09:44:26.761 ------------ *****************************************File encoded successfully: 00003.m2ts******************************************
09:44:26.730 Important Starting BD root menu encoding: [Memory load 70%] [Available virtual memory 1599 Mb.]
09:44:26.707 Info Building menus using template: 10 titles per page without sub menus (open style)
09:44:26.700 Info Building menu for The Americans S01E04 In Control.1080p.WEB-DL.x264.anoXmous_
09:44:26.689 Info Menu style: Root menu
09:44:26.677 Info Requested page index:
09:44:26.665 Info Render params in thumbs: False
09:44:26.500 Info subtitle #4 - Encoded subtitles frames: 780
09:44:26.490 Info subtitle #3 - Encoded subtitles frames: 1492
09:44:26.484 Info video #1 - Processed video frames: 63516 (63517 frames encoded, 0 frames dropped, 2 frames duplicated)
07:57:26.763 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=4
07:57:26.755 ------------ +--> [subtitle #4 - hdmv_pgs_subtitle subtitle, 1920x1080 ]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00003.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 04\The Americans S01E04 In Control.1080p.WEB-DL.x264.anoXmous_.mp4
Video filters used:
07:57:26.743 Info Chapters to generate: 9 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, )
07:57:26.732 Important Starting video encoding: [Memory load 65%] [Available virtual memory 2144 Mb.]
07:57:10.701 Info Added in conversion queue list...
07:57:10.562 Group ******************** Titleset #4 - ~44 min. File: "The Americans S01E04 In Control.1080p.WEB-DL.x264.anoXmous_" -> 00003.m2ts - Blu-ray ********************|GK_TITLESET|
09:41:50.958 ------------ *****************************************File encoded successfully: 00002.m2ts******************************************
09:41:50.945 Important Starting BD root menu encoding: [Memory load 70%] [Available virtual memory 1603 Mb.]
09:41:50.939 Info Building menus using template: 10 titles per page without sub menus (open style)
09:41:50.932 Info Building menu for The Americans S01E03 Gregory.1080p.WEB-DL.x264.anoXmous_
09:41:50.926 Info Menu style: Root menu
09:41:50.919 Info Requested page index:
09:41:50.895 Info Render params in thumbs: False
09:41:50.678 Info subtitle #4 - Encoded subtitles frames: 710
09:41:50.672 Info subtitle #3 - Encoded subtitles frames: 1526
09:41:50.666 Info video #1 - Processed video frames: 68454 (68455 frames encoded, 0 frames dropped, 2 frames duplicated)
07:57:22.347 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=4
07:57:22.341 ------------ +--> [subtitle #4 - hdmv_pgs_subtitle subtitle, 1920x1080 ]
+-[video h264 1916x1076 203:114 yuv420p, 23.98Fps, 2088Kbps ]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00002.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 03\The Americans S01E03 Gregory.1080p.WEB-DL.x264.anoXmous_.mp4
Video filters used:
07:57:22.332 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
07:57:22.318 Important Starting video encoding: [Memory load 62%] [Available virtual memory 2608 Mb.]
07:57:10.546 Info Added in conversion queue list...
07:57:10.414 Group ******************** Titleset #3 - ~47 min. File: "The Americans S01E03 Gregory.1080p.WEB-DL.x264.anoXmous_" -> 00002.m2ts - Blu-ray ********************|GK_TITLESET|
09:47:57.109 ------------ *****************************************File encoded successfully: 00001.m2ts******************************************
09:47:57.102 Important Starting BD root menu encoding: [Memory load 70%] [Available virtual memory 1574 Mb.]
09:47:57.096 Info Building menus using template: 10 titles per page without sub menus (open style)
09:47:57.090 Info Building menu for The Americans S01E02 The Clock.1080p.WEB-DL.x264.anoXmous_
09:47:57.084 Info Menu style: Root menu
09:47:57.077 Info Requested page index:
09:47:57.071 Info Render params in thumbs: False
09:47:56.940 Info subtitle #4 - Encoded subtitles frames: 860
09:47:56.934 Info subtitle #3 - Encoded subtitles frames: 1640
09:47:56.924 Info video #1 - Processed video frames: 71713 (71714 frames encoded, 0 frames dropped, 2 frames duplicated)
07:57:18.120 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=4
07:57:18.115 ------------ +--> [subtitle #4 - hdmv_pgs_subtitle subtitle, 1920x1080 ]
+-[video h264 1916x1076 203:114 yuv420p, 23.98Fps, 2089Kbps ]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00001.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 02\The Americans S01E02 The Clock.1080p.WEB-DL.x264.anoXmous_.mp4
Video filters used:
07:57:18.111 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
07:57:18.106 Important Starting video encoding: [Memory load 60%] [Available virtual memory 3072 Mb.]
07:57:10.397 Info Added in conversion queue list...
07:57:10.268 Group ******************** Titleset #2 - ~49 min. File: "The Americans S01E02 The Clock.1080p.WEB-DL.x264.anoXmous_" -> 00001.m2ts - Blu-ray ********************|GK_TITLESET|
10:41:56.980 ------------ *****************************************File encoded successfully: 00000.m2ts******************************************
10:41:56.968 Important Starting BD root menu encoding: [Memory load 71%] [Available virtual memory 1331 Mb.]
10:41:56.949 Info Building menus using template: 10 titles per page without sub menus (open style)
10:41:56.941 Info Building menu for The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_
10:41:56.936 Info Menu style: Root menu
10:41:56.928 Info Requested page index:
10:41:56.922 Info Render params in thumbs: False
10:41:56.642 Info subtitle #4 - Encoded subtitles frames: 988
10:41:56.633 Info subtitle #3 - Encoded subtitles frames: 2242
10:41:56.618 Info video #1 - Processed video frames: 102263 (102264 frames encoded, 0 frames dropped, 2 frames duplicated)
07:57:14.027 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3500000,bt=50M,maxrate=30000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=4
07:57:14.022 ------------ +--> [subtitle #4 - hdmv_pgs_subtitle subtitle, 1920x1080 ]
Output file: M:\VSO Blu Ray\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_\BDMV\STREAM\00000.m2ts (Blu-ray)
Input file: M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 01\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_.mp4
Video filters used:
07:57:14.018 Info Chapters to generate: 15 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, 0h55m00s, 1h00m00s, 1h05m00s, 1h10m00s, )
07:57:14.014 Important Starting video encoding: [Memory load 58%] [Available virtual memory 3523 Mb.]
07:57:10.248 Info Added in conversion queue list...
07:57:10.014 Group ******************** Titleset #1 - ~71 min. File: "The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
07:57:09.973 Info Encoding options: Long Project (Automatic)
07:57:09.970 Info Target size: 44.9 GB.
07:57:09.955 Important Setting queuer for Blu-ray output: [Wait: 4000], [ld: 1000], [Hd: 10000], [MAM: 600], [RM: 500], [ALL: True]
07:57:09.946 Info Don't log FFMpeg log events
07:57:09.942 ------------ ***************************************************Burn settings end****************************************************
07:57:09.939 Info Default speed selected: 1x
07:57:09.936 Info [ ] Delete vsomsl files after burn complete
07:57:09.933 Info [ ] Delete output folder after burn complete
07:57:09.929 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
07:57:09.926 Info SAO setting: Automatic
07:57:09.923 Info [x] Burn result to disk / as ISO file in working folder
07:57:09.920 ------------ **************************************************Burn settings begin***************************************************
07:57:09.920 Group Encoding session started at 07:57:03: 29 titleset(s) to encode -> Failed after 10:35:43|GK_CONVERT_SESSION|
07:55:37.752 Info Removed segment: The Americans S03E04 Dimebag (1080p x265 10bit Joy)
07:55:35.621 Info Removed segment: The Americans S03E05 Salang Pass (1080p x265 10bit Joy)
07:55:32.161 Info Removed segment: The Americans S03E06 Born Again (1080p x265 10bit Joy)
07:55:25.285 Important Loaded with result [File ]
07:55:24.536 Info Loading: "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E04 Dimebag (1080p x265 10bit Joy).mkv - File" 3/3
07:55:24.531 Info Loading: "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E06 Born Again (1080p x265 10bit Joy).mkv - File" 2/3
07:55:24.525 Info Loading: "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E05 Salang Pass (1080p x265 10bit Joy).mkv - File" 1/3
07:55:24.447 Info Sources filtered, found 3 protocols
07:55:24.376 Info Added protocol M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E04 Dimebag (1080p x265 10bit Joy).mkv, candidate 3/3
07:55:24.368 Info Added protocol M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E06 Born Again (1080p x265 10bit Joy).mkv, candidate 2/3
07:55:24.361 Info Added protocol M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E05 Salang Pass (1080p x265 10bit Joy).mkv, candidate 1/3
07:55:24.281 Info Found 3 candidates
07:55:24.202 Info Filtering sources
07:55:24.202 Group Loading file(s)
07:55:05.252 Info File "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E03 Open House (1080p x265 10bit Joy).mkv" parsed successfully
07:55:05.245 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E03 Open House (1080p x265 10bit Joy).mkv
07:54:59.428 Info Parsed new section for stream "hevc 1920x1080 16:9 yuv420p10le, 23.98Fps, 0Kbps " [Section: Section #1][ts: 0.00][duration: 2580.05][position: 39399]
07:54:59.422 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E03 Open House (1080p x265 10bit Joy).mkv
07:54:59.406 Info The file The Americans S03E03 Open House (1080p x265 10bit Joy) needs to be parsed in order to find its actual duration.
07:54:59.402 Group Parsing file "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E03 Open House (1080p x265 10bit Joy).mkv"
07:54:59.103 Info File "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E02 Baggage (1080p x265 10bit Joy).mkv" parsed successfully
07:54:59.097 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E02 Baggage (1080p x265 10bit Joy).mkv
07:54:54.355 Info Parsed new section for stream "hevc 1920x1080 16:9 yuv420p10le, 23.98Fps, 0Kbps " [Section: Section #1][ts: 0.00][duration: 2767.05][position: 39400]
07:54:54.346 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E02 Baggage (1080p x265 10bit Joy).mkv
07:54:54.332 Info The file The Americans S03E02 Baggage (1080p x265 10bit Joy) needs to be parsed in order to find its actual duration.
07:54:54.328 Group Parsing file "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E02 Baggage (1080p x265 10bit Joy).mkv"
07:54:54.038 Info File "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E01 EST Men (1080p x265 10bit Joy).mkv" parsed successfully
07:54:54.032 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E01 EST Men (1080p x265 10bit Joy).mkv
07:54:47.243 Info Parsed new section for stream "hevc 1920x1080 16:9 yuv420p10le, 23.98Fps, 0Kbps " [Section: Section #1][ts: 0.00][duration: 2797.91][position: 39399]
07:54:47.237 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E01 EST Men (1080p x265 10bit Joy).mkv
07:54:47.224 Info The file The Americans S03E01 EST Men (1080p x265 10bit Joy) needs to be parsed in order to find its actual duration.
07:54:47.222 Group Parsing file "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E01 EST Men (1080p x265 10bit Joy).mkv"
07:54:46.781 Important Loaded with result [File ]
07:54:46.445 Info Loading: "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E03 Open House (1080p x265 10bit Joy).mkv - File" 3/3
07:54:46.439 Info Loading: "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E02 Baggage (1080p x265 10bit Joy).mkv - File" 2/3
07:54:46.435 Info Loading: "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E01 EST Men (1080p x265 10bit Joy).mkv - File" 1/3
07:54:46.346 Info Sources filtered, found 3 protocols
07:54:46.266 Info Added protocol M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E03 Open House (1080p x265 10bit Joy).mkv, candidate 3/3
07:54:46.259 Info Added protocol M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E02 Baggage (1080p x265 10bit Joy).mkv, candidate 2/3
07:54:46.253 Info Added protocol M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E01 EST Men (1080p x265 10bit Joy).mkv, candidate 1/3
07:54:46.166 Info Found 3 candidates
07:54:46.085 Info Filtering sources
07:54:46.085 Group Loading file(s)
07:54:36.501 Info Removed segment: The Americans S03E04 Dimebag (1080p x265 10bit Joy)
07:54:35.330 Info Removed segment: The Americans S03E05 Salang Pass (1080p x265 10bit Joy)
07:54:34.138 Info Removed segment: The Americans S03E06 Born Again (1080p x265 10bit Joy)
07:54:32.345 Info Removed segment: The Americans S03E07 Walter Taffet (1080p x265 10bit Joy)
07:54:30.253 Info Removed segment: The Americans S03E08 Divestment (1080p x265 10bit Joy)
07:54:29.141 Info Removed segment: The Americans S03E09 Do Mail Robots Dream of Electric Sheep (1080p x265 10bit Joy)
07:54:28.099 Info Removed segment: The Americans S03E10 Stingers (1080p x265 10bit Joy)
07:54:13.592 Info Load aborted by user.
07:54:13.589 Warning File "The Americans S03E11 One Day in the Life of Anton Baklanov (1080p x265 10bit Joy)" ignored. Unknown duration.
07:54:13.522 Important Progress cancelled by user
07:54:13.538 Warning Parsing cancelled by user
07:54:13.526 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E11 One Day in the Life of Anton Baklanov (1080p x265 10bit Joy).mkv
07:54:10.991 Info Parsed new section for stream "hevc 1920x1080 16:9 yuv420p10le, 23.98Fps, 0Kbps " [Section: Section #1][ts: 0.00][duration: 2576.80][position: 829462]
07:54:10.978 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E11 One Day in the Life of Anton Baklanov (1080p x265 10bit Joy).mkv
07:54:10.964 Info The file The Americans S03E11 One Day in the Life of Anton Baklanov (1080p x265 10bit Joy) needs to be parsed in order to find its actual duration.
07:54:10.940 Group Parsing file "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E11 One Day in the Life of Anton Baklanov (1080p x265 10bit Joy).mkv"
07:54:10.697 Info File "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E10 Stingers (1080p x265 10bit Joy).mkv" parsed successfully
07:54:10.680 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E10 Stingers (1080p x265 10bit Joy).mkv
07:54:02.545 Info Parsed new section for stream "hevc 1920x1080 16:9 yuv420p10le, 23.98Fps, 0Kbps " [Section: Section #1][ts: 0.00][duration: 2695.21][position: 3719882]
07:54:02.529 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E10 Stingers (1080p x265 10bit Joy).mkv
07:54:02.516 Info The file The Americans S03E10 Stingers (1080p x265 10bit Joy) needs to be parsed in order to find its actual duration.
07:54:02.494 Group Parsing file "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E10 Stingers (1080p x265 10bit Joy).mkv"
07:54:01.957 Info File "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E09 Do Mail Robots Dream of Electric Sheep (1080p x265 10bit Joy).mkv" parsed successfully
07:54:01.950 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E09 Do Mail Robots Dream of Electric Sheep (1080p x265 10bit Joy).mkv
07:53:56.735 Info Parsed new section for stream "hevc 1920x1080 16:9 yuv420p10le, 23.98Fps, 0Kbps " [Section: Section #1][ts: 0.00][duration: 2620.88][position: 39399]
07:53:56.727 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E09 Do Mail Robots Dream of Electric Sheep (1080p x265 10bit Joy).mkv
07:53:56.714 Info The file The Americans S03E09 Do Mail Robots Dream of Electric Sheep (1080p x265 10bit Joy) needs to be parsed in order to find its actual duration.
07:53:56.711 Group Parsing file "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E09 Do Mail Robots Dream of Electric Sheep (1080p x265 10bit Joy).mkv"
07:53:56.444 Info File "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E08 Divestment (1080p x265 10bit Joy).mkv" parsed successfully
07:53:56.438 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E08 Divestment (1080p x265 10bit Joy).mkv
07:53:50.780 Info Parsed new section for stream "hevc 1920x1080 16:9 yuv420p10le, 23.98Fps, 0Kbps " [Section: Section #1][ts: 0.00][duration: 2587.12][position: 39404]
07:53:50.772 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E08 Divestment (1080p x265 10bit Joy).mkv
07:53:50.757 Info The file The Americans S03E08 Divestment (1080p x265 10bit Joy) needs to be parsed in order to find its actual duration.
07:53:50.285 Group Parsing file "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E08 Divestment (1080p x265 10bit Joy).mkv"
07:53:49.862 Info File "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E07 Walter Taffet (1080p x265 10bit Joy).mkv" parsed successfully
07:53:49.852 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E07 Walter Taffet (1080p x265 10bit Joy).mkv
07:53:40.114 Info Parsed new section for stream "hevc 1920x1080 16:9 yuv420p10le, 23.98Fps, 0Kbps " [Section: Section #1][ts: 0.00][duration: 2739.07][position: 39399]
07:53:40.107 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E07 Walter Taffet (1080p x265 10bit Joy).mkv
07:53:40.094 Info The file The Americans S03E07 Walter Taffet (1080p x265 10bit Joy) needs to be parsed in order to find its actual duration.
07:53:40.080 Group Parsing file "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E07 Walter Taffet (1080p x265 10bit Joy).mkv"
07:53:39.850 Info File "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E06 Born Again (1080p x265 10bit Joy).mkv" parsed successfully
07:53:39.844 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E06 Born Again (1080p x265 10bit Joy).mkv
07:53:33.482 Info Parsed new section for stream "hevc 1920x1080 16:9 yuv420p10le, 23.98Fps, 0Kbps " [Section: Section #1][ts: 0.00][duration: 2820.56][position: 39399]
07:53:33.476 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E06 Born Again (1080p x265 10bit Joy).mkv
07:53:33.463 Info The file The Americans S03E06 Born Again (1080p x265 10bit Joy) needs to be parsed in order to find its actual duration.
07:53:33.447 Group Parsing file "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E06 Born Again (1080p x265 10bit Joy).mkv"
07:53:33.226 Info File "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E05 Salang Pass (1080p x265 10bit Joy).mkv" parsed successfully
07:53:33.220 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E05 Salang Pass (1080p x265 10bit Joy).mkv
07:53:28.089 Info Parsed new section for stream "hevc 1920x1080 16:9 yuv420p10le, 23.98Fps, 0Kbps " [Section: Section #1][ts: 0.00][duration: 2634.71][position: 39399]
07:53:28.082 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E05 Salang Pass (1080p x265 10bit Joy).mkv
07:53:28.069 Info The file The Americans S03E05 Salang Pass (1080p x265 10bit Joy) needs to be parsed in order to find its actual duration.
07:53:28.066 Group Parsing file "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E05 Salang Pass (1080p x265 10bit Joy).mkv"
07:53:27.810 Info File "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E04 Dimebag (1080p x265 10bit Joy).mkv" parsed successfully
07:53:27.805 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E04 Dimebag (1080p x265 10bit Joy).mkv
ink
Post by ink »
07:53:22.500 Info Parsed new section for stream "hevc 1920x1080 16:9 yuv420p10le, 23.98Fps, 0Kbps " [Section: Section #1][ts: 0.00][duration: 2711.89][position: 39399]
07:53:22.495 Verbose FFmpeg Opening file M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E04 Dimebag (1080p x265 10bit Joy).mkv
07:53:22.483 Info The file The Americans S03E04 Dimebag (1080p x265 10bit Joy) needs to be parsed in order to find its actual duration.
07:53:22.480 Group Parsing file "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E04 Dimebag (1080p x265 10bit Joy).mkv"
07:53:22.072 Important Loaded with result [File ]
07:53:21.769 Info Loading: "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E03 Open House (1080p x265 10bit Joy).mkv - File" 13/13
07:53:21.767 Info Loading: "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E02 Baggage (1080p x265 10bit Joy).mkv - File" 12/13
07:53:21.764 Info Loading: "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E01 EST Men (1080p x265 10bit Joy).mkv - File" 11/13
07:53:21.761 Info Loading: "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E13 March 8, 1983 (1080p x265 10bit Joy).mkv - File" 10/13
07:53:21.759 Info Loading: "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E12 I Am Abassin Zadran (1080p x265 10bit Joy).mkv - File" 9/13
07:53:21.756 Info Loading: "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E11 One Day in the Life of Anton Baklanov (1080p x265 10bit Joy).mkv - File" 8/13
07:53:21.754 Info Loading: "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E10 Stingers (1080p x265 10bit Joy).mkv - File" 7/13
07:53:21.751 Info Loading: "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E09 Do Mail Robots Dream of Electric Sheep (1080p x265 10bit Joy).mkv - File" 6/13
07:53:21.748 Info Loading: "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E08 Divestment (1080p x265 10bit Joy).mkv - File" 5/13
07:53:21.746 Info Loading: "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E07 Walter Taffet (1080p x265 10bit Joy).mkv - File" 4/13
07:53:21.743 Info Loading: "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E06 Born Again (1080p x265 10bit Joy).mkv - File" 3/13
07:53:21.739 Info Loading: "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E05 Salang Pass (1080p x265 10bit Joy).mkv - File" 2/13
07:53:21.729 Info Loading: "M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E04 Dimebag (1080p x265 10bit Joy).mkv - File" 1/13
07:53:21.651 Info Sources filtered, found 13 protocols
07:53:21.581 Info Added protocol M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E03 Open House (1080p x265 10bit Joy).mkv, candidate 13/13
07:53:21.578 Info Added protocol M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E02 Baggage (1080p x265 10bit Joy).mkv, candidate 12/13
07:53:21.576 Info Added protocol M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E01 EST Men (1080p x265 10bit Joy).mkv, candidate 11/13
07:53:21.574 Info Added protocol M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E13 March 8, 1983 (1080p x265 10bit Joy).mkv, candidate 10/13
07:53:21.571 Info Added protocol M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E12 I Am Abassin Zadran (1080p x265 10bit Joy).mkv, candidate 9/13
07:53:21.569 Info Added protocol M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E11 One Day in the Life of Anton Baklanov (1080p x265 10bit Joy).mkv, candidate 8/13
07:53:21.567 Info Added protocol M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E10 Stingers (1080p x265 10bit Joy).mkv, candidate 7/13
07:53:21.564 Info Added protocol M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E09 Do Mail Robots Dream of Electric Sheep (1080p x265 10bit Joy).mkv, candidate 6/13
07:53:21.562 Info Added protocol M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E08 Divestment (1080p x265 10bit Joy).mkv, candidate 5/13
07:53:21.559 Info Added protocol M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E07 Walter Taffet (1080p x265 10bit Joy).mkv, candidate 4/13
07:53:21.556 Info Added protocol M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E06 Born Again (1080p x265 10bit Joy).mkv, candidate 3/13
07:53:21.553 Info Added protocol M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E05 Salang Pass (1080p x265 10bit Joy).mkv, candidate 2/13
07:53:21.550 Info Added protocol M:\Vuze Downloads\The Americans Season 3 (1080p Web x265 10bit Joy)\The Americans S03E04 Dimebag (1080p x265 10bit Joy).mkv, candidate 1/13
07:53:21.446 Info Found 13 candidates
07:53:21.349 Info Filtering sources
07:53:21.349 Group Loading file(s)
07:50:24.066 Important Loaded with result [File ]
07:50:23.753 Info Loading: "M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E06.Behind.the.Red.Door.1080p.WEB-DL.DD5.1.h.264-NTb.mkv - File" 13/13
07:50:23.751 Info Loading: "M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E05.The.Deal.1080p.WEB-DL.DD5.1.h.264-NTb.mkv - File" 12/13
07:50:23.749 Info Loading: "M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E04.A.Little.Night.Music.1080p.WEB-DL.DD5.1.h.264-NTb.mkv - File" 11/13
07:50:23.746 Info Loading: "M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E03.The.Walk.In.1080p.WEB-DL.DD5.1.h.264-NTb.mkv - File" 10/13
07:50:23.744 Info Loading: "M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E02.Cardinal.1080p.WEB-DL.DD5.1.h.264-NTb.mkv - File" 9/13
07:50:23.742 Info Loading: "M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E01.Comrades.1080p.WEB-DL.DD5.1.h.264-NTb.mkv - File" 8/13
07:50:23.740 Info Loading: "M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E13.Echo.1080p.WEB-DL.DD5.1.h.264-NTb.mkv - File" 7/13
07:50:23.738 Info Loading: "M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E12.Operation.Chronicle.1080p.WEB-DL.DD5.1.h.264-NTb.mkv - File" 6/13
07:50:23.736 Info Loading: "M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E11.Stealth.1080p.WEB-DL.DD5.1.h.264-NTb.mkv - File" 5/13
07:50:23.734 Info Loading: "M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E10.Yousaf.1080p.WEB-DL.DD5.1.h.264-NTb.mkv - File" 4/13
07:50:23.732 Info Loading: "M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E09.Martial.Eagle.1080p.WEB-DL.DD5.1.h.264-NTb.mkv - File" 3/13
07:50:23.730 Info Loading: "M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E08.New.Car.1080p.WEB-DL.DD5.1.h.264-NTb.mkv - File" 2/13
07:50:23.725 Info Loading: "M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E07.Arpanet.1080p.WEB-DL.DD5.1.h.264-NTb.mkv - File" 1/13
07:50:23.666 Info Sources filtered, found 13 protocols
07:50:23.609 Info Added protocol M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E06.Behind.the.Red.Door.1080p.WEB-DL.DD5.1.h.264-NTb.mkv, candidate 13/13
07:50:23.607 Info Added protocol M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E05.The.Deal.1080p.WEB-DL.DD5.1.h.264-NTb.mkv, candidate 12/13
07:50:23.604 Info Added protocol M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E04.A.Little.Night.Music.1080p.WEB-DL.DD5.1.h.264-NTb.mkv, candidate 11/13
07:50:23.601 Info Added protocol M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E03.The.Walk.In.1080p.WEB-DL.DD5.1.h.264-NTb.mkv, candidate 10/13
07:50:23.597 Info Added protocol M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E02.Cardinal.1080p.WEB-DL.DD5.1.h.264-NTb.mkv, candidate 9/13
07:50:23.594 Info Added protocol M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E01.Comrades.1080p.WEB-DL.DD5.1.h.264-NTb.mkv, candidate 8/13
07:50:23.591 Info Added protocol M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E13.Echo.1080p.WEB-DL.DD5.1.h.264-NTb.mkv, candidate 7/13
07:50:23.588 Info Added protocol M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E12.Operation.Chronicle.1080p.WEB-DL.DD5.1.h.264-NTb.mkv, candidate 6/13
07:50:23.585 Info Added protocol M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E11.Stealth.1080p.WEB-DL.DD5.1.h.264-NTb.mkv, candidate 5/13
07:50:23.582 Info Added protocol M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E10.Yousaf.1080p.WEB-DL.DD5.1.h.264-NTb.mkv, candidate 4/13
07:50:23.579 Info Added protocol M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E09.Martial.Eagle.1080p.WEB-DL.DD5.1.h.264-NTb.mkv, candidate 3/13
07:50:23.575 Info Added protocol M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E08.New.Car.1080p.WEB-DL.DD5.1.h.264-NTb.mkv, candidate 2/13
07:50:23.571 Info Added protocol M:\Vuze Downloads\The Americans Season 2 Complete 1080p WEB-DL [PublicHD]\The.Americans.S02E07.Arpanet.1080p.WEB-DL.DD5.1.h.264-NTb.mkv, candidate 1/13
07:50:23.486 Info Found 13 candidates
07:50:23.383 Info Filtering sources
07:50:23.383 Group Loading file(s)
10:00:19.973 Info Removed segment: The Americans 2013 S02E01 HDTV.XviD-AFG
10:00:18.848 Info Removed segment: The Americans 2013 S02E02 HDTV.XviD-EVO
10:00:08.207 Important Loaded with result [File ]
10:00:07.895 Info Loading: "M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E02 HDTV.XviD-EVO.avi - File" 1/1
10:00:07.823 Info Sources filtered, found 1 protocols
10:00:07.748 Info Added protocol M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E02 HDTV.XviD-EVO.avi, candidate 1/1
10:00:07.667 Info Found 1 candidates
10:00:07.530 Info Filtering sources
10:00:07.530 Group Loading file(s)
10:00:00.746 Important Loaded with result [File ]
10:00:00.466 Info Loading: "M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E01 HDTV.XviD-AFG.avi - File" 1/1
10:00:00.403 Info Sources filtered, found 1 protocols
10:00:00.340 Info Added protocol M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E01 HDTV.XviD-AFG.avi, candidate 1/1
10:00:00.270 Info Found 1 candidates
10:00:00.143 Info Filtering sources
10:00:00.143 Group Loading file(s)
09:59:53.770 Info Removed segment: The Americans 2013 S02E08 HDTV.XviD-AFG
09:59:52.799 Info Removed segment: The Americans 2013 S02E09 HDTV.XviD-AFG
09:59:51.890 Info Removed segment: The Americans 2013 S02E10 HDTV.XviD-AFG
09:59:50.406 Info Removed segment: The Americans 2013 S02E11 HDTV.XviD-AFG
09:59:48.977 Info Removed segment: The Americans 2013 S02E12 HDTV.XviD-AFG
09:59:48.380 Info Removed segment: The Americans 2013 S02E13 HDTV.XviD-AFG
09:59:47.346 Info Removed segment: The Americans 2013 S02E07 HDTV.XviD-AFG
09:59:46.947 Info Removed segment: The Americans 2013 S02E01 HDTV.XviD-AFG
09:59:46.386 Info Removed segment: The Americans 2013 S02E02 HDTV.XviD-EVO
09:59:44.793 Info Removed segment: The Americans 2013 S02E03 HDTV.XviD-AFG
09:59:44.244 Info Removed segment: The Americans 2013 S02E04 HDTV.XviD-AFG
09:59:43.870 Info Removed segment: The Americans 2013 S02E05 HDTV.XviD-AFG
09:59:42.676 Info Removed segment: The Americans 2013 S02E06 HDTV.XviD-AFG
09:58:56.059 Important Loaded with result [File ]
09:58:55.748 Info Loading: "M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E06 HDTV.XviD-AFG.avi - File" 13/13
09:58:55.745 Info Loading: "M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E05 HDTV.XviD-AFG.avi - File" 12/13
09:58:55.744 Info Loading: "M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E04 HDTV.XviD-AFG.avi - File" 11/13
09:58:55.742 Info Loading: "M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E03 HDTV.XviD-AFG.avi - File" 10/13
09:58:55.740 Info Loading: "M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E02 HDTV.XviD-EVO.avi - File" 9/13
09:58:55.738 Info Loading: "M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E01 HDTV.XviD-AFG.avi - File" 8/13
09:58:55.736 Info Loading: "M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E13 HDTV.XviD-AFG.avi - File" 7/13
09:58:55.734 Info Loading: "M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E12 HDTV.XviD-AFG.avi - File" 6/13
09:58:55.732 Info Loading: "M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E11 HDTV.XviD-AFG.avi - File" 5/13
09:58:55.731 Info Loading: "M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E10 HDTV.XviD-AFG.avi - File" 4/13
09:58:55.729 Info Loading: "M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E09 HDTV.XviD-AFG.avi - File" 3/13
09:58:55.726 Info Loading: "M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E08 HDTV.XviD-AFG.avi - File" 2/13
09:58:55.722 Info Loading: "M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E07 HDTV.XviD-AFG.avi - File" 1/13
09:58:55.657 Info Sources filtered, found 13 protocols
09:58:55.590 Info Added protocol M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E06 HDTV.XviD-AFG.avi, candidate 13/13
09:58:55.588 Info Added protocol M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E05 HDTV.XviD-AFG.avi, candidate 12/13
09:58:55.586 Info Added protocol M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E04 HDTV.XviD-AFG.avi, candidate 11/13
09:58:55.584 Info Added protocol M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E03 HDTV.XviD-AFG.avi, candidate 10/13
09:58:55.582 Info Added protocol M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E02 HDTV.XviD-EVO.avi, candidate 9/13
09:58:55.580 Info Added protocol M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E01 HDTV.XviD-AFG.avi, candidate 8/13
09:58:55.578 Info Added protocol M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E13 HDTV.XviD-AFG.avi, candidate 7/13
09:58:55.576 Info Added protocol M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E12 HDTV.XviD-AFG.avi, candidate 6/13
09:58:55.573 Info Added protocol M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E11 HDTV.XviD-AFG.avi, candidate 5/13
09:58:55.569 Info Added protocol M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E10 HDTV.XviD-AFG.avi, candidate 4/13
09:58:55.566 Info Added protocol M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E09 HDTV.XviD-AFG.avi, candidate 3/13
09:58:55.562 Info Added protocol M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E08 HDTV.XviD-AFG.avi, candidate 2/13
09:58:55.559 Info Added protocol M:\Vuze Downloads\The Americans - Season 2\The Americans 2013 S02E07 HDTV.XviD-AFG.avi, candidate 1/13
09:58:55.459 Info Found 13 candidates
09:58:55.281 Info Filtering sources
09:58:55.281 Group Loading file(s)
09:56:44.204 Info File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 05\The Americans S01E05 COMINT.1080p.WEB-DL.x264.anoXmous_.mp4" parsed successfully
09:56:44.165 Verbose FFmpeg Opening file M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 05\The Americans S01E05 COMINT.1080p.WEB-DL.x264.anoXmous_.mp4
09:56:37.019 Info Parsed new section for stream "h264 1912x1072 239:134 yuv420p, 23.98Fps, 2087Kbps " [Section: Section #1][ts: 0.00][duration: 2513.96][position: 1220713]
09:56:36.981 Verbose FFmpeg Opening file M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 05\The Americans S01E05 COMINT.1080p.WEB-DL.x264.anoXmous_.mp4
09:56:36.974 Info The file The Americans S01E05 COMINT.1080p.WEB-DL.x264.anoXmous_ needs to be parsed in order to find its actual duration.
09:56:36.971 Group Parsing file "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 05\The Americans S01E05 COMINT.1080p.WEB-DL.x264.anoXmous_.mp4"
09:56:36.571 Info File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 04\The Americans S01E04 In Control.1080p.WEB-DL.x264.anoXmous_.mp4" parsed successfully
09:56:36.531 Verbose FFmpeg Opening file M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 04\The Americans S01E04 In Control.1080p.WEB-DL.x264.anoXmous_.mp4
09:56:27.889 Info Parsed new section for stream "h264 1912x1072 239:134 yuv420p, 23.98Fps, 2089Kbps " [Section: Section #1][ts: 0.00][duration: 2649.22][position: 1277337]
09:56:27.848 Verbose FFmpeg Opening file M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 04\The Americans S01E04 In Control.1080p.WEB-DL.x264.anoXmous_.mp4
09:56:27.841 Info The file The Americans S01E04 In Control.1080p.WEB-DL.x264.anoXmous_ needs to be parsed in order to find its actual duration.
09:56:27.838 Group Parsing file "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 04\The Americans S01E04 In Control.1080p.WEB-DL.x264.anoXmous_.mp4"
09:56:27.363 Info File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 03\The Americans S01E03 Gregory.1080p.WEB-DL.x264.anoXmous_.mp4" parsed successfully
09:56:27.321 Verbose FFmpeg Opening file M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 03\The Americans S01E03 Gregory.1080p.WEB-DL.x264.anoXmous_.mp4
09:56:18.088 Info Parsed new section for stream "h264 1916x1076 203:114 yuv420p, 23.98Fps, 2088Kbps " [Section: Section #1][ts: 0.00][duration: 2855.17][position: 1383822]
09:56:18.048 Verbose FFmpeg Opening file M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 03\The Americans S01E03 Gregory.1080p.WEB-DL.x264.anoXmous_.mp4
09:56:18.039 Info The file The Americans S01E03 Gregory.1080p.WEB-DL.x264.anoXmous_ needs to be parsed in order to find its actual duration.
09:56:18.036 Group Parsing file "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 03\The Americans S01E03 Gregory.1080p.WEB-DL.x264.anoXmous_.mp4"
09:56:17.633 Info File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 02\The Americans S01E02 The Clock.1080p.WEB-DL.x264.anoXmous_.mp4" parsed successfully
09:56:17.573 Verbose FFmpeg Opening file M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 02\The Americans S01E02 The Clock.1080p.WEB-DL.x264.anoXmous_.mp4
09:56:07.909 Info Parsed new section for stream "h264 1916x1076 203:114 yuv420p, 23.98Fps, 2089Kbps " [Section: Section #1][ts: 0.00][duration: 2991.10][position: 1440094]
09:56:07.868 Verbose FFmpeg Opening file M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 02\The Americans S01E02 The Clock.1080p.WEB-DL.x264.anoXmous_.mp4
09:56:07.860 Info The file The Americans S01E02 The Clock.1080p.WEB-DL.x264.anoXmous_ needs to be parsed in order to find its actual duration.
09:56:07.858 Group Parsing file "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 02\The Americans S01E02 The Clock.1080p.WEB-DL.x264.anoXmous_.mp4"
09:56:07.436 Info File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 01\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_.mp4" parsed successfully
09:56:07.375 Verbose FFmpeg Opening file M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 01\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_.mp4
09:55:55.230 Info Parsed new section for stream "h264 1916x1076 203:114 yuv420p, 23.98Fps, 2088Kbps " [Section: Section #1][ts: 0.00][duration: 4265.32][position: 1989434]
09:55:55.164 Verbose FFmpeg Opening file M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 01\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_.mp4
09:55:55.157 Info The file The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_ needs to be parsed in order to find its actual duration.
09:55:55.135 Group Parsing file "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 01\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_.mp4"
09:55:53.438 Info File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 10\The Americans S01E10 Only You.1080p.WEB-DL.x264.anoXmous_.mp4" parsed successfully
09:55:53.399 Verbose FFmpeg Opening file M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 10\The Americans S01E10 Only You.1080p.WEB-DL.x264.anoXmous_.mp4
09:55:42.504 Info Parsed new section for stream "h264 1912x1072 239:134 yuv420p, 23.98Fps, 2088Kbps " [Section: Section #1][ts: 0.00][duration: 2835.56][position: 1389845]
09:55:42.460 Verbose FFmpeg Opening file M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 10\The Americans S01E10 Only You.1080p.WEB-DL.x264.anoXmous_.mp4
09:55:42.453 Info The file The Americans S01E10 Only You.1080p.WEB-DL.x264.anoXmous_ needs to be parsed in order to find its actual duration.
09:55:42.449 Group Parsing file "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 10\The Americans S01E10 Only You.1080p.WEB-DL.x264.anoXmous_.mp4"
09:55:41.277 Info File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 07\The Americans S01E07 Duty and Honor.1080p.WEB-DL.x264.anoXmous_.mp4" parsed successfully
09:55:41.241 Verbose FFmpeg Opening file M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 07\The Americans S01E07 Duty and Honor.1080p.WEB-DL.x264.anoXmous_.mp4
09:55:33.024 Info Parsed new section for stream "h264 1912x1072 239:134 yuv420p, 23.98Fps, 2088Kbps " [Section: Section #1][ts: 0.00][duration: 2553.73][position: 1244733]
09:55:32.984 Verbose FFmpeg Opening file M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 07\The Americans S01E07 Duty and Honor.1080p.WEB-DL.x264.anoXmous_.mp4
09:55:32.977 Info The file The Americans S01E07 Duty and Honor.1080p.WEB-DL.x264.anoXmous_ needs to be parsed in order to find its actual duration.
09:55:32.965 Group Parsing file "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 07\The Americans S01E07 Duty and Honor.1080p.WEB-DL.x264.anoXmous_.mp4"
09:56:44.420 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 05\The Americans S01E05 COMINT.1080p.WEB-DL.x264.anoXmous_swe.srt" ignored. Ancillary files will eventually be loaded later.
09:56:44.372 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 05\The Americans S01E05 COMINT.1080p.WEB-DL.x264.anoXmous_eng.srt" ignored. Ancillary files will eventually be loaded later.
09:56:36.816 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 04\The Americans S01E04 In Control.1080p.WEB-DL.x264.anoXmous_swe.srt" ignored. Ancillary files will eventually be loaded later.
09:56:36.765 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 04\The Americans S01E04 In Control.1080p.WEB-DL.x264.anoXmous_eng.srt" ignored. Ancillary files will eventually be loaded later.
09:56:27.671 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 03\The Americans S01E03 Gregory.1080p.WEB-DL.x264.anoXmous_swe.srt" ignored. Ancillary files will eventually be loaded later.
09:56:27.622 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 03\The Americans S01E03 Gregory.1080p.WEB-DL.x264.anoXmous_eng.srt" ignored. Ancillary files will eventually be loaded later.
09:56:17.872 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 02\The Americans S01E02 The Clock.1080p.WEB-DL.x264.anoXmous_swe.srt" ignored. Ancillary files will eventually be loaded later.
09:56:17.822 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 02\The Americans S01E02 The Clock.1080p.WEB-DL.x264.anoXmous_eng.srt" ignored. Ancillary files will eventually be loaded later.
09:56:07.664 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 01\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_swe.srt" ignored. Ancillary files will eventually be loaded later.
09:56:07.611 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 01\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_eng.srt" ignored. Ancillary files will eventually be loaded later.
09:55:54.959 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 13\The Americans S01E13 The Colonel.1080p.WEB-DL.x264.anoXmous_swe.srt" ignored. Ancillary files will eventually be loaded later.
09:55:54.911 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 13\The Americans S01E13 The Colonel.1080p.WEB-DL.x264.anoXmous_eng.srt" ignored. Ancillary files will eventually be loaded later.
09:55:54.489 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 12\The Americans S01E12 The Oath.1080p.WEB-DL.x264.anoXmous_swe.srt" ignored. Ancillary files will eventually be loaded later.
09:55:54.443 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 12\The Americans S01E12 The Oath.1080p.WEB-DL.x264.anoXmous_eng.srt" ignored. Ancillary files will eventually be loaded later.
09:55:54.092 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 11\The Americans S01E11 Covert War.1080p.WEB-DL.x264.anoXmous_swe.srt" ignored. Ancillary files will eventually be loaded later.
09:55:54.047 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 11\The Americans S01E11 Covert War.1080p.WEB-DL.x264.anoXmous_eng.srt" ignored. Ancillary files will eventually be loaded later.
09:55:53.693 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 10\The Americans S01E10 Only You.1080p.WEB-DL.x264.anoXmous_swe.srt" ignored. Ancillary files will eventually be loaded later.
09:55:53.646 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 10\The Americans S01E10 Only You.1080p.WEB-DL.x264.anoXmous_eng.srt" ignored. Ancillary files will eventually be loaded later.
09:55:42.275 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 09\The Americans S01E09 Safe House.1080p.WEB-DL.x264.anoXmous_swe.srt" ignored. Ancillary files will eventually be loaded later.
09:55:42.230 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 09\The Americans S01E09 Safe House.1080p.WEB-DL.x264.anoXmous_eng.srt" ignored. Ancillary files will eventually be loaded later.
09:55:41.894 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 08\The Americans S01E08 Mutually Assured Destruction.1080p.WEB-DL.x264.anoXmous_swe.srt" ignored. Ancillary files will eventually be loaded later.
09:55:41.848 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 08\The Americans S01E08 Mutually Assured Destruction.1080p.WEB-DL.x264.anoXmous_eng.srt" ignored. Ancillary files will eventually be loaded later.
09:55:41.489 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 07\The Americans S01E07 Duty and Honor.1080p.WEB-DL.x264.anoXmous_swe.srt" ignored. Ancillary files will eventually be loaded later.
09:55:41.441 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 07\The Americans S01E07 Duty and Honor.1080p.WEB-DL.x264.anoXmous_eng.srt" ignored. Ancillary files will eventually be loaded later.
09:55:32.813 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 06\The Americans S01E06 Trust Me.1080p.WEB-DL.x264.anoXmous_swe.srt" ignored. Ancillary files will eventually be loaded later.
09:55:32.765 Hint File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 06\The Americans S01E06 Trust Me.1080p.WEB-DL.x264.anoXmous_eng.srt" ignored. Ancillary files will eventually be loaded later.
09:55:32.765 Group Ignored file(s)
09:55:32.038 Info File "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 06\The Americans S01E06 Trust Me.1080p.WEB-DL.x264.anoXmous_.mp4" parsed successfully
09:55:31.986 Verbose FFmpeg Opening file M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 06\The Americans S01E06 Trust Me.1080p.WEB-DL.x264.anoXmous_.mp4
09:55:20.344 Info Parsed new section for stream "h264 1912x1072 239:134 yuv420p, 23.98Fps, 2088Kbps " [Section: Section #1][ts: 0.00][duration: 3089.15][position: 1493001]
09:55:20.302 Verbose FFmpeg Opening file M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 06\The Americans S01E06 Trust Me.1080p.WEB-DL.x264.anoXmous_.mp4
09:55:20.294 Info The file The Americans S01E06 Trust Me.1080p.WEB-DL.x264.anoXmous_ needs to be parsed in order to find its actual duration.
09:55:20.292 Group Parsing file "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 06\The Americans S01E06 Trust Me.1080p.WEB-DL.x264.anoXmous_.mp4"
09:55:20.054 Important Loaded with result [File ]
09:55:19.779 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 05\The Americans S01E05 COMINT.1080p.WEB-DL.x264.anoXmous_swe.srt - File" 39/39
09:55:19.778 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 05\The Americans S01E05 COMINT.1080p.WEB-DL.x264.anoXmous_eng.srt - File" 38/39
09:55:19.777 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 05\The Americans S01E05 COMINT.1080p.WEB-DL.x264.anoXmous_.mp4 - File" 37/39
09:55:19.776 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 04\The Americans S01E04 In Control.1080p.WEB-DL.x264.anoXmous_swe.srt - File" 36/39
09:55:19.775 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 04\The Americans S01E04 In Control.1080p.WEB-DL.x264.anoXmous_eng.srt - File" 35/39
09:55:19.774 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 04\The Americans S01E04 In Control.1080p.WEB-DL.x264.anoXmous_.mp4 - File" 34/39
09:55:19.773 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 03\The Americans S01E03 Gregory.1080p.WEB-DL.x264.anoXmous_swe.srt - File" 33/39
09:55:19.772 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 03\The Americans S01E03 Gregory.1080p.WEB-DL.x264.anoXmous_eng.srt - File" 32/39
09:55:19.771 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 03\The Americans S01E03 Gregory.1080p.WEB-DL.x264.anoXmous_.mp4 - File" 31/39
09:55:19.770 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 02\The Americans S01E02 The Clock.1080p.WEB-DL.x264.anoXmous_swe.srt - File" 30/39
09:55:19.769 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 02\The Americans S01E02 The Clock.1080p.WEB-DL.x264.anoXmous_eng.srt - File" 29/39
09:55:19.769 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 02\The Americans S01E02 The Clock.1080p.WEB-DL.x264.anoXmous_.mp4 - File" 28/39
09:55:19.768 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 01\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_swe.srt - File" 27/39
09:55:19.767 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 01\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_eng.srt - File" 26/39
09:55:19.766 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 01\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_.mp4 - File" 25/39
09:55:19.765 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 13\The Americans S01E13 The Colonel.1080p.WEB-DL.x264.anoXmous_swe.srt - File" 24/39
09:55:19.765 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 13\The Americans S01E13 The Colonel.1080p.WEB-DL.x264.anoXmous_eng.srt - File" 23/39
09:55:19.764 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 13\The Americans S01E13 The Colonel.1080p.WEB-DL.x264.anoXmous_.mp4 - File" 22/39
09:55:19.763 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 12\The Americans S01E12 The Oath.1080p.WEB-DL.x264.anoXmous_swe.srt - File" 21/39
09:55:19.762 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 12\The Americans S01E12 The Oath.1080p.WEB-DL.x264.anoXmous_eng.srt - File" 20/39
09:55:19.761 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 12\The Americans S01E12 The Oath.1080p.WEB-DL.x264.anoXmous_.mp4 - File" 19/39
09:55:19.761 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 11\The Americans S01E11 Covert War.1080p.WEB-DL.x264.anoXmous_swe.srt - File" 18/39
09:55:19.760 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 11\The Americans S01E11 Covert War.1080p.WEB-DL.x264.anoXmous_eng.srt - File" 17/39
09:55:19.759 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 11\The Americans S01E11 Covert War.1080p.WEB-DL.x264.anoXmous_.mp4 - File" 16/39
09:55:19.758 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 10\The Americans S01E10 Only You.1080p.WEB-DL.x264.anoXmous_swe.srt - File" 15/39
09:55:19.758 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 10\The Americans S01E10 Only You.1080p.WEB-DL.x264.anoXmous_eng.srt - File" 14/39
09:55:19.757 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 10\The Americans S01E10 Only You.1080p.WEB-DL.x264.anoXmous_.mp4 - File" 13/39
09:55:19.756 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 09\The Americans S01E09 Safe House.1080p.WEB-DL.x264.anoXmous_swe.srt - File" 12/39
09:55:19.756 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 09\The Americans S01E09 Safe House.1080p.WEB-DL.x264.anoXmous_eng.srt - File" 11/39
09:55:19.753 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 09\The Americans S01E09 Safe House.1080p.WEB-DL.x264.anoXmous_.mp4 - File" 10/39
09:55:19.752 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 08\The Americans S01E08 Mutually Assured Destruction.1080p.WEB-DL.x264.anoXmous_swe.srt - File" 9/39
09:55:19.751 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 08\The Americans S01E08 Mutually Assured Destruction.1080p.WEB-DL.x264.anoXmous_eng.srt - File" 8/39
09:55:19.751 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 08\The Americans S01E08 Mutually Assured Destruction.1080p.WEB-DL.x264.anoXmous_.mp4 - File" 7/39
09:55:19.750 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 07\The Americans S01E07 Duty and Honor.1080p.WEB-DL.x264.anoXmous_swe.srt - File" 6/39
09:55:19.749 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 07\The Americans S01E07 Duty and Honor.1080p.WEB-DL.x264.anoXmous_eng.srt - File" 5/39
09:55:19.749 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 07\The Americans S01E07 Duty and Honor.1080p.WEB-DL.x264.anoXmous_.mp4 - File" 4/39
09:55:19.748 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 06\The Americans S01E06 Trust Me.1080p.WEB-DL.x264.anoXmous_swe.srt - File" 3/39
09:55:19.747 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 06\The Americans S01E06 Trust Me.1080p.WEB-DL.x264.anoXmous_eng.srt - File" 2/39
09:55:19.747 Info Loading: "M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 06\The Americans S01E06 Trust Me.1080p.WEB-DL.x264.anoXmous_.mp4 - File" 1/39
09:55:19.686 Info Sources filtered, found 39 protocols
09:55:19.624 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 05\The Americans S01E05 COMINT.1080p.WEB-DL.x264.anoXmous_swe.srt, candidate 39/39
09:55:19.623 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 05\The Americans S01E05 COMINT.1080p.WEB-DL.x264.anoXmous_eng.srt, candidate 38/39
09:55:19.622 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 05\The Americans S01E05 COMINT.1080p.WEB-DL.x264.anoXmous_.mp4, candidate 37/39
09:55:19.622 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 04\The Americans S01E04 In Control.1080p.WEB-DL.x264.anoXmous_swe.srt, candidate 36/39
09:55:19.621 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 04\The Americans S01E04 In Control.1080p.WEB-DL.x264.anoXmous_eng.srt, candidate 35/39
09:55:19.620 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 04\The Americans S01E04 In Control.1080p.WEB-DL.x264.anoXmous_.mp4, candidate 34/39
09:55:19.619 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 03\The Americans S01E03 Gregory.1080p.WEB-DL.x264.anoXmous_swe.srt, candidate 33/39
09:55:19.619 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 03\The Americans S01E03 Gregory.1080p.WEB-DL.x264.anoXmous_eng.srt, candidate 32/39
09:55:19.618 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 03\The Americans S01E03 Gregory.1080p.WEB-DL.x264.anoXmous_.mp4, candidate 31/39
09:55:19.617 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 02\The Americans S01E02 The Clock.1080p.WEB-DL.x264.anoXmous_swe.srt, candidate 30/39
09:55:19.616 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 02\The Americans S01E02 The Clock.1080p.WEB-DL.x264.anoXmous_eng.srt, candidate 29/39
09:55:19.615 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 02\The Americans S01E02 The Clock.1080p.WEB-DL.x264.anoXmous_.mp4, candidate 28/39
09:55:19.615 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 01\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_swe.srt, candidate 27/39
09:55:19.614 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 01\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_eng.srt, candidate 26/39
09:55:19.613 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 01\The Americans S01E01 Pilot.1080p.WEB-DL.x264.anoXmous_.mp4, candidate 25/39
09:55:19.612 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 13\The Americans S01E13 The Colonel.1080p.WEB-DL.x264.anoXmous_swe.srt, candidate 24/39
09:55:19.611 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 13\The Americans S01E13 The Colonel.1080p.WEB-DL.x264.anoXmous_eng.srt, candidate 23/39
09:55:19.611 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 13\The Americans S01E13 The Colonel.1080p.WEB-DL.x264.anoXmous_.mp4, candidate 22/39
09:55:19.610 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 12\The Americans S01E12 The Oath.1080p.WEB-DL.x264.anoXmous_swe.srt, candidate 21/39
09:55:19.609 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 12\The Americans S01E12 The Oath.1080p.WEB-DL.x264.anoXmous_eng.srt, candidate 20/39
09:55:19.608 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 12\The Americans S01E12 The Oath.1080p.WEB-DL.x264.anoXmous_.mp4, candidate 19/39
09:55:19.607 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 11\The Americans S01E11 Covert War.1080p.WEB-DL.x264.anoXmous_swe.srt, candidate 18/39
09:55:19.606 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 11\The Americans S01E11 Covert War.1080p.WEB-DL.x264.anoXmous_eng.srt, candidate 17/39
09:55:19.606 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 11\The Americans S01E11 Covert War.1080p.WEB-DL.x264.anoXmous_.mp4, candidate 16/39
09:55:19.605 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 10\The Americans S01E10 Only You.1080p.WEB-DL.x264.anoXmous_swe.srt, candidate 15/39
09:55:19.604 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 10\The Americans S01E10 Only You.1080p.WEB-DL.x264.anoXmous_eng.srt, candidate 14/39
09:55:19.603 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 10\The Americans S01E10 Only You.1080p.WEB-DL.x264.anoXmous_.mp4, candidate 13/39
09:55:19.603 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 09\The Americans S01E09 Safe House.1080p.WEB-DL.x264.anoXmous_swe.srt, candidate 12/39
09:55:19.602 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 09\The Americans S01E09 Safe House.1080p.WEB-DL.x264.anoXmous_eng.srt, candidate 11/39
09:55:19.601 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 09\The Americans S01E09 Safe House.1080p.WEB-DL.x264.anoXmous_.mp4, candidate 10/39
09:55:19.601 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 08\The Americans S01E08 Mutually Assured Destruction.1080p.WEB-DL.x264.anoXmous_swe.srt, candidate 9/39
09:55:19.600 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 08\The Americans S01E08 Mutually Assured Destruction.1080p.WEB-DL.x264.anoXmous_eng.srt, candidate 8/39
09:55:19.599 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 08\The Americans S01E08 Mutually Assured Destruction.1080p.WEB-DL.x264.anoXmous_.mp4, candidate 7/39
09:55:19.599 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 07\The Americans S01E07 Duty and Honor.1080p.WEB-DL.x264.anoXmous_swe.srt, candidate 6/39
09:55:19.598 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 07\The Americans S01E07 Duty and Honor.1080p.WEB-DL.x264.anoXmous_eng.srt, candidate 5/39
09:55:19.598 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 07\The Americans S01E07 Duty and Honor.1080p.WEB-DL.x264.anoXmous_.mp4, candidate 4/39
09:55:19.597 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 06\The Americans S01E06 Trust Me.1080p.WEB-DL.x264.anoXmous_swe.srt, candidate 3/39
09:55:19.597 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 06\The Americans S01E06 Trust Me.1080p.WEB-DL.x264.anoXmous_eng.srt, candidate 2/39
09:55:19.596 Info Added protocol M:\Vuze Downloads\The.Americans.2013.S01.Season.1.Complete.1080p.WEB-DL.x264.anoXmous\episode 06\The Americans S01E06 Trust Me.1080p.WEB-DL.x264.anoXmous_.mp4, candidate 1/39
09:55:19.519 Info Found 39 candidates
09:55:19.434 Info Filtering sources
09:55:19.434 Group Loading file(s)
09:54:57.764 Info Menu templates loaded: 20
09:54:57.014 Info Command line: 0 parameter(s)
Param #00: "C:\Program Files (x86)\VSO\ConvertXtoHD\3\ConvertXToHD.exe"
09:54:57.014 Info Total Physical Memory : 16360 Mb.
Available Physical Memory : 6845 Mb.
Memory Load : 58%
Available Virtual Memory : 3752 Mb.
Total Memory : 35823 Mb.
Available Memory : 6811 Mb.
09:54:57.014 Info Processor Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz with 16/8 core(s) CPU
Supported instruction set: MMX,sse,sse2,sse3,ssse3,sse41,sse42,avx,aes
09:54:57.013 Info User OS: Windows 7 Home Premium, Microsoft Windows 7 (Build 7601: Service Pack 1)
file name : C:\Program Files (x86)\VSO\ConvertXtoHD\3\ConvertXToHD.exe
file version : 3.0.0.58
User language : English (United Kingdom)
System language : English (United Kingdom)
09:54:56.874 Info License status: active customer license
09:54:56.874 Info License type: commercial (online activated)
09:54:56.874 Info Computer ID: 454890
09:54:56.874 Group License
09:54:52.273 Info Loading templates from: "C:\Users\Inkey\Documents\ConvertXtoHD_Resources\Templates\"
09:54:52.273 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoHD\3\Templates\"
09:54:52.272 ------------ **************************ConvertXToHD.exe:229552 Log session start 2019-01-19 at 09:54:51.598**************************
09:54:52.271 Info Monotonizer (C:\ProgramData\vso\vsomsl): 0MB
09:54:52.260 Info Thumb cache (C:\ProgramData\VSO\vsothumbs): 1,530.98GB
09:54:52.163 Info Program data (C:\ProgramData\VSO\ConvertXtoHD\3\): 79MB
09:54:52.135 Info Working folder size (M:\VSO Blu Ray): 45,115.41GB
09:54:52.002 Info Available Space M: 65.18GB of 1,863.01GB
09:54:52.001 Info Available Space G: 57.21GB of 57.68GB
09:54:52.000 Info Available Space E: 61MB of 62MB
09:54:51.999 Info Available Space C: 1.61GB of 111.79GB
09:54:51.998 Group Folder data
09:54:51.996 Info 1 writer(s) found.
09:54:51.975 Group Burn engine events
Re: any idea why this failed
Not sure but I suspect that program and system runs out of disc space for temporary files or something.
This is reported by program:
Conversion result is 45GB and most likely there is need for temporary files about the same amount, but your M: drive has only 65GB free.
Then also your C: is very full with Thumb Cache of 1.5TB ??
ink
Post by ink »
Thanks for that
I did delete a file just after I started the burn [so my M: drive actaully had 121Gb free] - that was about half an hour into the process, so well before it stopped
But maybe it was too late [?]
So in theory if I try again it might work now [?]
Thanks again
