Preview DVD before burning
I was wondering if there was a way to preview what the finished DVD would look like before I waste a DVD. I have already converted but, I want to see the finished product before I burn.
- VSO Fanatic
Re: Preview DVD before burning
Yes, disable Automatic Burning, check finished result using a player then burn if the result satisfies you
