SSL support in VSOD 5.0.1.58 Beta
samuel82
Post by samuel82 »
Hi.
Today i tried the new VSOD beta (5.0.1.58) hoping to see that the SSL issue i had in the previous beta version was fixed, but unfortunally it still present, but now it show more bugs than before.
After program installation, each time i try to activate/deactivate SSL support, i get this error during SSL certificate installation:
It says about a missing sqlite3.dll file. If i accept this error message, SSL seems to be activated but like in the previous beta, i can't load any HTTPS site on Chrome or Firefox. Only after disabling SSL i can open any HTTPS site again.
I hope somebody in the support team can help me with this issue that still present since version 5.0.1.57 beta.
Thank you.
Re: SSL support in VSOD 5.0.1.58 Beta
Good morning,
Curious, have you tried a 100% clean install ?
[X] Delete Program Folder
[X] Clear Registry
[X]
remove all on install ?
Just an idea...
Someone else seems to still be having issues with SSL and certificate with I am assuming Build .58
samuel82
Post by samuel82 »
Cougar_II wrote:Good morning,
[X] Clear Registry
[X]
Just an idea...
I tested version 5.0.1.57 and 5.0.1.58 on 3 differents and 100% clean systems (no previous installation) with Windows 7, 8.1 and 10 1809 with the same result. I also tried version 5.0.1.56 and is the only one that works fine in these systems.
Hello again,
Since I have access to the bug report site, let me open up a new bug report for you, and another person also having issues and let's see what comes out of it...
samuel82
Post by samuel82 »
Cougar_II wrote:Hello again,
Thank you. :)
Bug report created:
http://bugs.vso-software.fr/view.php?id=13628
At least VSO will be aware of your issues...
Samuel, read this post:
https-ssl-support-t18841.html
Delete the VSO Certificate and see if this solves your issue.
Another no longer has the issue...
samuel82
Post by samuel82 »
Cougar_II wrote:Samuel, read this post:
Unfortunately it didn't work either. The problem is that every time I activate SSL, the internal proxy of VSOD seems not to work in this beta version. I don't have any firewall or security software installed that could interfere with VSOD, it's a clean system. As I said before, version 5.0.1.56 can be installed and works correctly without needing to do anything else. I think that for the moment I will have to stay with this last one.
Thanks anyway. :)
Jacques (VSO)
Post by Jacques (VSO) »
Hello Samuel,
The issue is related to SSL support in firefox. We have a potential fix however I'd like to work with you to verify if this fix is OK. I'll contact you on your email, and if it's working we will release a next build.
It the meantime it's been added to the bug list: http://bugs.vso-software.fr/view.php?id=13629
Jacques.
VSO Software Team Member
