Unable to load openssl
regodivad
Post by regodivad »
Hi all,
After having installed VSO Downloader on a new laptop (Windows 10 Home), once I start application, I'm requested to activate HTTPS/SSL.
There I receive following event message: "Unable to load OpenSSL" followed by "SSL certificate is not installed in the Windows store".
I already tried to install manually the certificate located in C:\Program Files (x86)\VSO\VSO Downloader\5\certificate without success.
Would you have any idea/suggestion?
Tks,
David.
Re: Unable to load openssl
Good morning,
Are you having those issues with v5.0.1.58 ?
I know that Build 58 fixed some of those issues...
Bug report created, as another user reported SSL issues with v5.0.1.58
http://bugs.vso-software.fr/view.php?id=13628
regodivad
Post by regodivad »
Thanks for the answer.
The issue is with version 5.0.1.56 as this is the last one I could find in VSO library.
This is where you can find v5.0.1.58
http://download.vso-software.fr/archive ... 0.1.58.exe
Try again with Build 58 and see if you are all good, or also having SSL issues like a few others are still having.
I am good (for now) with Build 58 :)
regodivad
Post by regodivad »
I installed last version (.58) as recommanded but I still have same error.
I hope the next more detailed information will help.
First I'm requested to activate SSL support:
Then I get following error message around OpenSSL:
...followed by:
regodivad
Post by regodivad »
No reaction, no update from VSO? Is there anybody there?
This will take time as VSO only has 1 developper now.
I have opened a bug report to report this, now we wait.
It's sad that it does take time as VSO has excellent products, we will just need to be patient !
regodivad
Post by regodivad »
Only 1 developper for all VSO products? How will he survive?
Tks anyway for the info Cougar_II...
regodivad
Post by regodivad »
Issue solved by following this post: https-ssl-support-t18841.html
Thank you very much, I will see if this solves the issue for the other user now...
