What the manual is missing
Cathexis
Post by Cathexis »
Greetings,
Using ConvertXToDVD 7 on PC running Windows 10 with built-in ASUS disc burner to produce the DVDs.
Looking for detailed explanation (definitions and implications of choosing) for the following sections of "Default Settings:"
1. Output/Encoding/Encoding Options & Conversion Processes
2. Output/Video Processing - all sections
3. Output/Hardware Optimizations - all sections.
I am aware you can mouse hover over fields and get a pop-up explanation. But they are general, not detailed descriptors.
Two examples: show me one place where it tells me the difference, and implications of choosing, between the various
deinterlacing choices or the difference in using, or not using, hardware optimization.
TIA,
Cathexis
Cathexis
Re: What the manual is missing
Post by Cathexis »
I guess we know now why the manual is missing this info. Because the forum doesn't know it either.
Do Developers read this forum?
deadlyshadow
Post by deadlyshadow »
Cathexis wrote: Do Developers read this forum?
No
Cathexis
Post by Cathexis »
Truth hurts ! But thanks.
Hi Cathexis,
Sorry for the delay, we've been a bit busy lately... But we're back now!
Check this general guide regarding settings of ConvertXtoDVD 7: http://www.vso-software.fr/guides/cxd/c ... ttings.php
Hope it will help you understand better the available settings.
For detailed infos regarding hardware optimizations: hardware-accelerations-guide-t16234.html
Does it help? Tell me if you need specific infos.
Cheers,
Cathexis
Post by Cathexis »
I'll review this and get back. Just want to acknowledge your reply!
