I am using v4.0.0.94
Every time I rip a new DVD, the quality keeps resetting down to about 19%, but when I click the quality, it's set to 100%. If I change the setting, it works for the current disc, but then resets back to the low setting the next time.
I have tried saving the preferences, but they are ignored the next launch.
I have tried clean reinstalling the product, but this does not seem to reset the existing preferences.
Any thoughts?
DVD Converter - Conversion Quality keeps resetting
Re: DVD Converter - Conversion Quality keeps resetting
We'll try to sort this out together!
Could you please try the last beta version and tell me how it goes for this quality issue? Thanks! (with the cleaning options checked again)
http://download.vso-software.fr/archive ... 0.0.96.exe
