In the current version a episode is started from the menu by selecting correspondig tekst (episode name) in the menu.
But many Blu-Ray's have a graphic in front of the tekst that highlights up when selected.
Currently I am working on The 100 Season 1 Disc 1 and these disc use a graphic to select the episode.
Blue is the standard color and yellow/gold is the selection color of a small TV thumbnail.
Is it possible to add this also to ConvertXtoHD so we can choose start the episode with a thumbnail?
With much regards,
Nemesh
P.s. If VSO support needs a example let me know.
REQ: Icons for episode selection
Re: REQ: Icons for episode selection
Hi Nemesh,
Not sure I get what is the issue...
Could you please attached screenshot, explaining your point?
Many thanks,
Many thanks,
No it's nog a bug or problem it's feature request.
I had alleday an PM exchange with Coral about this because he helped Felicia with the Template Editor in ConvertXtoHD.
All right I will try to explain better.
If you start a Blu-Ray disc (let's say The 100 Season 1 Disc 1).
In the menu of the disc you see the episodes.
Well you have to select a episode to watch.
In front of eacht episode is a tiny thumbnail (a small TV in case of the series The 100).
When you go down or up, the color of that small TV will change from blue to gold.
If it is gold, then that is the episode you want to watch and press enter on you remote.
My feature request is to add this to the Template Editor from ConvertXtoHD.
So that I can use home-made or the original thumbnails to select a episode.
At this moment ConvertXtoHD doesn't have such feature.
Had in April of this year a PM exchange with Coral about this, but at that time nobody from VSO was on the VSO forum.
Since English is not my native language mayby you can contact Coral and ask him what I mean.
Give you my best regards,
Nemesh
Nemesh
All good! I get it now.
Thanks for explaining. I'll report this feature request right now: http://bugs.vso-software.fr/view.php?id=13685
