A while back there was a some time error about inserting a disk. It was fixed with the case # 0013479.
I would like to know what exactly what was causing the error if possible as I now have another program which gives me the exact same error message.
The tech support of the other program is having problems figuring it out and I think that the error message is being caused by the same problem which you found and fixed.
abm
Error fix #0013479
Re: Error fix #0013479
If you read some other posts you will realise that all the staff that was working on ConverXtoDVD has long left VSO. I don't think that the present staff can answer your question, unfortunately.
