Had to do a 'clean' install of windows 10 today. After I installed ConvertXtodvd I got one of those messages of do I want to buy it, Not accepting my 'key'. I am wondering if when the last time this happened, if my "key" was changed by "admin". She had to connect to my PC in order to fix it the last time. If so, could you please send me a new key. Upon an "email" I can, of course, send a copy of "my" license key.
Thanks in advance.
not accepting license key
Re: not accepting license key
Hi Eddie,
Try this link:
http://www.vso-software.fr/contactform. ... ic=license
Enter your email address. You will be taken to a sight with the software you are entitled to, marked green.
Choose by ticking the box on the left. Then click "Submit" The new key will be sent immediately to your email address.
After installing the software and entering the key it is important that you remain on internet for your key to be verified. You can turn off internet after verification, if you wish.
Note:
Make sure sure that you enter the exact email address as the one you have submitted to VSO
Try this link:
Note:
Hi Eddie & Coral,
I think Coral solution is the best one, thank you for posting it.
If it still doesn't work, please send me an email at support@vsosoftware.fr (so I'll have access to your account)
Thanks Coral, your solution worked.
Thanks again
Thanks again
Glad you're happyeddie11013 wrote:Thanks Coral, your solution worked.
Thanks again
