I have just downloaded the software and entered my license key in the help/tools enter license key section.
I am burning DVDs for my autistic son, they download/burn fine but at the beginning of the playback I get a menu of somesort on the screen, which shows chapters/setting and then PLAY.
My son uses the DVD player buttons he is used to navigate the playback, is there anything I can do to get rid of the settings and play features that appear when I first try to playback the newly burnt DVD?
EDIT - appears to be the root menu, can I change that? I can see there are menu edit options but I can't appear to remove the root menu, I really don't want to see things like settings/home/play.
New user - menu playback question
Re: New user - menu playback question
Thanks for the reply, I did already check the menu options and also searched on the forum for answers.
I think I have resolved the problem by ticking the auto start playback, play titles one after the other and skip root menu initially tabs.
Mainly trail by error I suppose.
