ConvertXtoHD - Latest beta - 3.0.0.74 released!
Click here to download the Latest beta version 3.0.0.74
Click here to download the Latest release version
Release notes:
Fix memory leaks in "smart copy" mode.
Change log
3.0.0.74 Released 2020-11-19
Fix memory leak issues
0013918: [Bug] Memory issue during conversion: fails with "running low on memory"
3.0.0.73 Released 2020-05-14
Fix encoding of very complex SSA subtitles
0013882: [Bug] Memory allocation issue
0013885: [Bug] ASS huge subtitles issue
0013888: [Bug] Having Japanese characters on menu blocks conversion
3.0.0.72 Released 2020-03-13
Fix regsitration issues after update of registration servers
0013864: [Bug] Restore Compatibility with Windows Vista
3.0.0.71 Released 2019-11-13
Yet another subtitle bug fixed
0013773: [Bug] Subtitles issue -> red subtitle with green border
3.0.0.70 Released 2019-10-11
Fix subtitle rendering issue in preview
0013739: [Bug] Preview with subtitles -> Crashing
0013748: [Feature Request] [VSORep] "app will be closed" warning issued during install/reinstall process
0013752: [Feature Request] [VSORep] error message if Internet-OFF
0013756: [Bug] [VSO Rep] Re-Install not working
3.0.0.69 Released 2019-10-02
Upgrade bug reporting tools
0013702: [Suggestion] Even if the project has been saved - it asks again when closing the software
0013716: [Bug] All VSO products not opening for no obvious reason
0013722: [Feature Request] VSO Reporting Tool is not user-friendly.
3.0.0.68 Released 2019-06-24
0013654: [Bug] Video sources contained in ISO files are no longer supported
0013657: [Bug] Poor quality in converted subtitles
0013659: [Bug] "Check for Update" not working well
0013662: [Bug] no progression bar during conversion
0013670: [Bug] WMV format can't be converted to mp4 - no video - sound only
0013673: [Feature Request] Add setting to space lines of subtitles
The entire subtitle support is not yet perfect: In case of plaintext subtitle overlap (so if the next subtitle start exactly at the previous subtitle end, or a few milliseconds before), the encoder may produce a subtitle that will play correctly on PC and most standalone players, but may not play correctly on other (the older subtitle is re-displayed in degraded quality). This issue occurs only with plaintext subtitles as source, when subtitles overlap or are chained without delay, on older standalone blu-ray player - recent one doesn't seem to suffer from that. So it's a pretty rare issue. To solve it, a pretty big rewrite of the encoder is required. However, because it's rare and to avoid further delay on the much awaited subtitle improvement, we are releasing what we have done as of today.
3.0.0.67 Released 2019-06-18
Introduce easier 1-click update system
3.0.0.66 Released 2018-12-13
Fix Subtitle issues, stability improvement
0010346: [Bug] subtitle artifacts on some subtitles
0012536: [Bug] source subtitle file converted to blu-ray is not good looking
0013596: [Bug] Plain Text subtitles from MKV are not correctly encoded to Blu-Ray
3.0.0.65 Released 2018-10-23
Improve support of VC-1 source - Fix HW encoding on Nvidia Pascal-Based graphic cards
0013584: [Bug] Support of VC-1 is broken/incomplete
0013597: [Bug] Hardware encoding fail on NVIDIA GTX 10xx cards
3.0.0.64 Released 2018-09-14
Bugfix release, saved settings are back, updated skin engine
0013572: [Bug] Default settings forced at installation, and changes not stored
0013575: [Feature Request] Visual Appearence: Update to Alphaskin 14
0013579: [Bug] Remember the last opened folder doesn't work for "Burn an already converted project"
3.0.0.63 Released 2018-09-11
Fix removal of computer authorization when uninstalling software
0013571: [Bug] When uninstalling, prompt to remove computer authorization doesn't work
3.0.0.62 Released 2018-09-10
0013564: [Feature Request] Add write probing mechanism for working folder
0013568: [Bug] Conversion is dead slow while in menu generation
3.0.0.61 Released 2018-06-25
0013491: [Bug] Soundtrack with Dolby True HD or other high end audio are systematically re-encoded.
0013523: [Feature Request] Add the ability to change the vertical position of Image subtitles (DVD, BD, DVB, ...)
0013529: [Bug] DVD subtitles incorrectly copied in MKV files
0013531: [Crash] Scaler crash
3.0.0.60 Released 2018-06-05
0013514: [Bug] Loading BD/DVD structure from disc no longer work
3.0.0.59 Released 2018-06-01
Fix subtitle issue
0013487: [Bug] Subtitles from BD source always appear in an opaque box
ConvertXtoHD - 3.0.0.58
Fix file reader issue
0013475: [Bug] Produced video/audio has glitches, encoding stop before the end (wesson)
ConvertXtoHD - 3.0.0.57 - Released 2018-02-27
0013465: [Bug] Preliminary parsing of DVD Sources stuck. (wesson)
ConvertXtoHD - 3.0.0.56 - Released 2018-01-16
- 0013454: [Feature Request] Add thumbs to section bar (felicia)
- 0013450: [Bug] Progress fomr not always appears on collaing form's center (felicia)
- 0013447: [Bug] Exception when opening cut tab (felicia)
- 0013444: [Bug] Burning an already converted project may produce bad disks (felicia)
- 0013439: [Bug] Delete folder after burn not working if ISO is selected (felicia)
ConvertXtoHD - 3.0.0.55 - Released 2018-01-04
- 0013434: [Bug] Overhaul file loading (May fix random load deadlock) (felicia)
- 0013431: [Feature Request] Add thumbs to sections in cut tab (felicia)
- 0013429: [Feature Request] Add thumbs when hovering video trackbar (felicia)
ConvertXtoHD - 3.0.0.54 - Released 2017-12-05
- 0013418: [Feature Request] Detect stt file language if present in filename (felicia)
- 0013403: [Bug] Any way to keep "Sound Events" preferences? (felicia)
- 0013409: [Bug] Template editor - Resources not remembered if not copied (felicia)
- 0013407: [Bug] Template editor - Button overlays are not remembered (felicia)
- 0013405: [Bug] Separate smart copy option for video, audio and subtitles (felicia)
ConvertXtoHD - 3.0.0.53 - Released 2017-11-27
- 0013383: [Feature Request] Detail reasons to refuse remux (felicia)
- 0013358: [Bug] Default typesetting not applied if custom (felicia)
- 0013397: [Bug] If source is DVD only beginning of video is read (felicia)
- 0013392: [Bug] Conversion files if last project name letter is a space for DVD output (felicia)
- 0013388: [Feature Request] Add support for F4V files (felicia)
- 0013378: [Bug] complex ass subtitles do no display in CXD preview or on output (felicia)
- 0013372: [Bug] Delete after burn option no longer works (felicia)
- 0013369: [Bug] conversion fails with subrip because of unhandled exception (felicia)
- 0013365: [Bug] Audio edition for menu has issue with drop down translation visibility (felicia)
ConvertXtoHD - 3.0.0.52 - Released 2017-10-26
- 0013352: [Bug] Add missing DLLs for localisation tool (felicia)
- 0013349: [Feature Request] Add import option for menu templates (felicia)
- 0013347: [Bug] A period appears after the Title (wesson)
- 0013340: [Bug] Exception when entring empty chain in menu editor (felicia)
- 0013334: [Bug] BD subtitles rendered empty (felicia)
*if using old menu templates, reinstall them from http://www.vso-software.fr/products/menu-resources.php
minhcute
Re: ConvertXtoHD - Latest beta - 3.0.0.69 released!
Post by minhcute »
Hi Maggie !
When will an official version be released ? It has been too long since version 3.0.0.64
This one will become an official release when we can see it's clean enough since it will be the last 32bits version. :wink:
After a while without negative feedback/bug reporting/ etc.... from our users, we'll release it!
minhcute
Post by minhcute »
“It will be the last 32 bit version" ---> wow, I can't wait to be one of the first users who will use the first 64 bit version. I hope it will be released soon !
jrt
Re: ConvertXtoHD - Latest beta - 3.0.0.70 released!
Post by jrt »
Hallo VSO-Team,
When is the version 4.xx, 64 bit expected, which is listed in the version history, if you install the program?
jrt wrote: Sun Oct 20, 2019 4:27 pm Hallo VSO-Team,
Don't expect it soon !!
Coral is right about this.
Work is just getting started. We do not know the difficulties we will face and how long it might take to overcome them.
The only thing I can say is: the first project will be ConvertXtoHD 64bit. So, it will be the first one to be over.
You'll be informed the whole process. Thank you so much for your patience.
Cheers!
Re: ConvertXtoHD - Latest beta - 3.0.0.71 released!
:!: New beta version released!
jrt
Post by jrt »
Coral wrote: Sun Oct 20, 2019 8:01 pm
I am looking forward to it.
We have a saying that says: impossible things are dealt with immediately, miracles take a little longer.
Re: ConvertXtoHD - Latest beta - 3.0.0.73 released!
I downloaded the file and had to override windows security (in win10) to save the file, win security saw file as a possible threat.
After installing and running program, the app threw up error message "a critical folder cannot be accessed....." and to click ok and the program then terminates. In windows 10 security had to "allow an app through controlled folder access" to run the program successfully.
This is the only app I have ever had to do this for.
For info and review in case there is an issue with the vso app v/s windows 10 security app.
There was no issue with convertxtodvd, only with convertxto hd 3
Hi yoyo57,
Thanks for the report!
Was it also happening with 3.0.0.71 (and prior) or only with this new beta?
just this latest beta
I've reported the issue to the team. Thanks!
jrt
Re: ConvertXtoHD - Latest beta - 3.0.0.74 released!
Post by jrt »
Hello VSO team
a few quick questions, what happened to the announced 64-bit versions of convertXtoHD and the other programs?
and the briefly mentioned convertXtoUHD?
is there something in the works?
Seems ConvertXtoDVD 64bits is in the works, and ConvertXtoHD, rumours are it’s next in line, so sometimes in 2025 I guess…
ConvertXtoUHD was the 1st release, working quite well. Let’s see in what order VSO releases them…
