Downloader - Latest Beta - 5.1.1.75 released!
Please note: Due to its inherent nature and the fact that websites providing video are constantly changing, Downloader needs to be updated very often.
Click here to Download latest beta version 5.1.1.75
Click here to download the Latest release version
Release notes:
HLS Streams and dood.la support
Changes log
5.1.1.72 Released 2021-08-19
0014008: [Unsupported file/stream format] VSO Downloader seems to download only pieces of HLS streams
0014010: [Unsupported file/stream format] dood.la unsupported
5.1.1.71 Released 2020-05-15
Removal of the Ugly popup for social media
0013853: [Suggestion] Support us! improved
5.1.1.70 Released 2020-03-09
Restore compatibility with Windows VISTA
0013852: [Bug] Restore Compatibility with Windows Vista
5.1.1.69 Released 2020-02-21
Fix automatic installer on old windows versions
0013847: [Bug] Auto updater fail on some old version of windows
5.1.1.68 Released 2020-02-20
Solve online registration issue on Windows version < 10
0013846: [Bug] Unlock key accepted but doesn't turn the software to registered
5.1.1.67 Released 2020-02-12
Add support for automatic subtitles (transcription) and langage selector
0013839: [Feature Request] Select/Limit languages for subtiles
0013840: [Feature Request] Detect/Download auto-generated subtitles
5.1.0.66 Released 2020-01-22
Improve support for subtitles (make them compatible with Windows 10 Photos App)
0013821: [Bug] Downloaded subtiltes won't play on all supports
Some remark on the subtitle support which is in its early stage :
* So far it's been tested only on Youtube.
* All the available subtitles are fetched, but not the automatic (AI) one.
* Due to inherent limitations on the MP4 format, if the video contains subtitles the final file will always be converted to WEBM format, with video and audio track untouched. Webm files can be read by any media player, including the default Windows one.
* The current version of our media player (VMP) is not likely to see the subtitles in the output file even if they are present. A future update of VMP will correct this. However, the recent media players such as VLC will see the embedded subtitles and let anyone choose among them.
- we have also improved the compatibility of the downloaded video in the extraction engine, which will always prefer most compatible video format at the highest possible resolution. It may prevent loosing the video track in the finalisation stage for some video.
5.1.0.65 Released 2020-01-16
Add support for subtitles
0013604: [Feature Request] Add support of subtitle tracks in Downloader
5.0.1.64 Released 2019-11-27
Fix engine updater issue and update download engine
0013806: [Bug] [ENGINE UPDATE] extraction motor update won't start (privilege?)
5.0.1.63 Released 2019-11-14
Download engine and translation updates
0013747: [Bug] [VSORep] disabled emails appears on the pre-filled box
0013768: [Bug] [VSORep] closed ticket if we cannot retrieve the status
0013791: [Suggestion] [HELP MENU] Change "Report a bug" to "Support Center" + icon
5.0.1.62 Released 2019-10-02
Upgrade bug reporting tools
0013690: [Bug] Remove VSO Media Player as long as it isn't updated
0013706: [Suggestion] Tick by default HTTPS detection
0013712: [Suggestion] change the Downloader icon to the clean one
0013714: [Bug] All VSO products not opening for no obvious reason
0013720: [Feature Request] VSO Reporting Tool is not user-friendly.
5.0.1.61 Released 2019-06-25
Autodetection feature fixed for older computer
0013632: [Bug] Downloader doesn't detect video on Firefox if installed on a fresh window 10 installation
0013633: [Bug] Secure HTTPS support doesn't work
0013635: [Bug] Autodetection no longer work
5.0.1.60 Released 2019-05-17
Fix installation issue and firefox support
We've discovered that the external tool we use to provide support in Firefox had a dependency on Microsoft Visual C++ 2015 redistributables which may not be present on user's computer.
This new version fix the issue and the side effects related.
0013628: [Bug] SSL support issues in VSOD 5.0.1.58 Beta
0013629: [Bug] Issue with SSL certificate installation
0013630: [Bug] HTTP activation / disactivation failure from main window
5.0.1.59 Released 2019-05-10
Fix Error when activating/disactivating SSL support
0013631: [Suggestion] Console window appearing from time to time
5.0.1.58 Released 2019-03-21
Improved automatic updating system.
0013620: [Bug] International support / langage issue
0013623: [Unsupported file/stream format] Unsupported site: BING Video
0013625: [Bug] XP compatibility
0013626: [Bug] Better support of recent Firefox version
0013627: [Bug] Issue with installation of redistributable C runtime libraries.
5.0.1.57 Released 2019-03-03
Fix automatic update issue
0013619: [Bug] Automatic update of extraction engine
0013621: [Bug] v5.0.1.56 Update Engine always fail / Menu Check For Updates does nothing now ! ?
0013622: [Bug] Update fail consistently
Some notes about the recent release. Downloader is by its nature a software that need to be very frequently updated, just to keep it compatible with many video sites that constantly changes the way they deliver their videos. So staying up to date with Downloader is a key. To simplify the process, we have introduced in V 5.0.1.56 an automatic update feature that is capable to update most part of the software in a very simple way: 1 click confirmation and that's all. We made it so most of the time Downloader don't even need to be restarted. However, in some case this update is not possible without "elevation", which is executing the software under administrative privileges so to gain the write access to the files/folders that need to be updated. V 5.0.1.56 did not include a mechanism to trigger this elevation, which is the root cause of most if not all the update failure reported with this version. Starting from V5.0.1.57 the issue is addressed and if elevation is required, it'll be prompted.
5.0.1.56 Released 2018-12-04
Updated skin engine, 1 click update of extraction engine
0013151: [Suggestion] maybe improve message about Visual C++ x86
0013553: [Bug] Conflicting OpenSSL dll disturb Downloader and prevent it from operating
0013578: [Feature Request] Visual Appearence: Update to Alphaskin 14
0013593: [Bug] Downloader fail to load with exception about OpenSSL
0013614: [Feature Request] Unsupported site: putlockers
0013619: [Feature Request] Automatic update of extraction engine
A side note about the new Automatic update engine: it's very new and designed to install hotfix and or updates when they are needed. The overall goal of this automatic update engine is to provide faster and easier solutions to download failures, often without needing to restart downloader or to open a web browser to download a new version.
So when there is a failed download in the download queue, a check for update is issued and if one is available, it can be installed in 1 click and all the failed download resubmitted automatically after the update. So far this autoupdate feature is limited to components of the network extraction engine of downloader, but it is very scalable and will be used to update parts of software such as user interface langage, visual appearance and the entire software itself, in semi-automatic (1 click) or fully automatic (0 click) way. As a warmup of this automatic update engine, on the first launch of this beta version user should be notified of the availability of an update - this is normal.
5.0.1.55 Released 2018-09-12
Restore support of some sites
0013554: [Bug] Unsupported site: nypost.com
0013569: [Bug] Partially unsupported site: Youtube
5.0.1.54 Released 2018-06-20
BBC Iplayer support restored
0010127: [Bug] support for BBC iPlayer is broken
0012360: [Bug] Programmes from bbc.co.uk not supported
0012579: [Feature Request] hd-stream.net support
0012630: [Bug] copy paste of url doesnt always work
0012664: [Bug] no auto detection with IE of some BBC content
0012680: [Bug] stream wanted not detected by downloader only extra fragments downloaded with bbc iplayer
0012682: [Bug] bbc sport - download error
0012818: [Bug] download completed with error
0013341: [Feature Request] Trying to download from bbc iplayer
0013483: [Bug] BBC iPlayer: Long radio program are not downloaded in full
0013527: [Bug] videos won't download if links entered manually
0013528: [Bug] Site unsupported finehomebuilding.com . Video are not downloaded in full
0013534: [Crash] Scaler crash
0013538: [Bug] BBC Iplayer is Unsupported
0013540: [Feature Request] Add checkmark to keep automatic detection off when switching to manual download
Re: Downloader - Latest Beta - 5.0.1.63 released!
:!: New beta version released!
Re: Downloader - Latest Beta - 5.0.1.64 released!
Re: Downloader - Latest Beta - 5.1.0.65 released!
mjpalm
Post by mjpalm »
Is there... or will there be a release for Windows 10?
Win10 has been released years ago. All VSO products run on Win10.
Re: Downloader - Latest Beta - 5.1.0.66 released!
qingyihy
Post by qingyihy »
Please support 4K resolution display. There is a problem with the software's display zoom on 4K computer.
I have opened up a bug report for you: https://bugs.vso-software.fr/view.php?id=13823
This way VSO can try to reproduce and fix in the next version.
Can you provide details like: Video Card Used / Resolution Used / Monitor model & type etc...
Hi there,
This bug has already been reported: https://bugs.vso-software.fr/view.php?id=13687.
It is happening with all our apps.
Since we are working on the new interfaces, it won't be solved soon but we are doing our best :)
Thanks for your patience and support!
Thanks Cougar_II for your help/support with the forum, you are the best 8)
Cheers,
Hello Maggie,
I was not 100% sure if the prior bug was OUTPUT issues with 4k
*OR*
Display Issues on the screen with a 4k monitor, it's the reason why I had opened the bug report.
Thank you for clearing it up...
I renamed the bug, you are right. Clearer like that!
Re: Downloader - Latest Beta - 5.1.0.67 released!
Good morning,
File is missing of link is broken, it sends me to the VSO Software download page !!!
I was able to edit the post and fix the link and version text v5.1.1.67 :D
I just realized the latest version is v5.1.1.67 and not v5.1.0.67
Use this LINK to download v5.1.1.67 !
http://download.vso-software.fr/archive ... 1.1.67.exe
Re: Downloader - Latest Beta - 5.1.1.67 released!
Ahhhh, my bad! Sorry!
Thanks for that :o
Cougar_II wrote: Wed Feb 12, 2020 3:45 pm Good morning,
The best! :D
Re: Downloader - Latest Beta - 5.1.1.68 released!
--> Please note, just spotted a bug with the update. Will be solved very soon!
Re: Downloader - Latest Beta - 5.1.1.69 released!
Re: Downloader - Latest Beta - 5.1.1.70 released!
