Click here to download the Latest beta version 2.0.0.99
Click here to download the Latest release version
Release notes:
Support Center minor changes, video capture module removed for now as not functional
Most important: green & red subtitles issue resolved!
Changes log
2.0.0.99 Released 2019-11-13
Yet another subtitle bug fixed
0013536: [Bug] Runtime error 217 occurs randomly
0013550: [Bug] Application won't start if burner is busy with some condition
0013745: [Bug] [VSORep] disabled emails appears on the pre-filled box
0013766: [Bug] [VSORep] closed ticket if we cannot retrieve the status
0013771: [Bug] Subtitles issue -> red subtitle with green border
0013781: [Bug] Remove the video capture module (for now!)
0013790: [Suggestion] [HELP MENU] Change "Report a bug" to "Support Center" + icon
2.0.0.98 Released 2019-10-14
Fix subtitle rendering issue in preview
0013740: [Bug] Preview with subtitles -> Crashing
0013749: [Feature Request] [VSORep] "app will be closed" warning issued during install/reinstall process
0013753: [Feature Request] [VSORep] error message if Internet-OFF
0013757: [Bug] [VSO Rep] Re-Install not working
2.0.0.97 Released 2019-07-22
Upgrade bug reporting tools
0013667: [Bug] "Check for Update" appear on every launch even if there is no update
0013703: [Suggestion] Change the blue button (conversion profil customization)+hint
0013717: [Bug] All VSO products not opening for no obvious reason
0013723: [Feature Request] VSO Reporting Tool is not user-friendly.
0013727: [Suggestion] Change ConvertXtoVideo logo to a clean one
2.0.0.96 Released 2019-06-24
0013548: [Bug] Plain Text subtitles from MKV are not correctly encoded to Blu-Ray
0013637: [Bug] Poor quality in converted subtitles
0013663: [Bug] no progression bar during conversion
0013666: [Bug] WMV format can't be converted to mp4 - no video - sound only
0013667: [Bug] "Check for Update" not working well
0013675: [Feature Request] Add setting to space lines of subtitles
2.0.0.95 Released 2019-06-18
Introduce easier 1-click update system
2.0.0.94 Released 2018-12-20
Partial Fix of some Subtitle issues - Improve encoding quality for HD and Blu-Ray target - more robust encoding
0012537: [Bug] source subtitle file converted to blu-ray is not good looking
0013549: [Feature Request] Make Project files (.vcprj) transportable on other computer.
2.0.0.93 Released 2018-10-23
Improve support of VC-1 source - Fix HW encoding on Nvidia Pascal-Based graphic cards
0013582: [Bug] Support of VC-1 is broken/incomplete
0013598: [Bug] Hardware encoding fail on NVIDIA GTX 10xx cards
2.0.0.92 Released 2018-06-25
Bugfix release, updated skin engine
0011483: [Feature Request] allow possibility to change vertical and horizontal margins and scale of DVDsub format subtitles
0013555: [Feature Request] Add Iphone 8 and Iphone X profiles
0013565: [Feature Request] Add write probing mechanism for working folder
0013576: [Feature Request] Visual Appearence: Update to Alphaskin 14
2.0.0.91 Released 2018-06-25
0013543: [Feature Request] Add computer revocation mechanism for licensee
2.0.0.90 Released 2018-06-13
0013488: [Bug] Soundtrack with Dolby True HD or other high end audio are systematically re-encoded.
0013493: [Bug] Incorrect conversion of BD subtitles to DVD subtitles
0013516: [Feature Request] Add the ability to change the vertical position of Image subtitles (DVD, BD, DVB, ...)
0013517: [Bug] DVD subtitles incorrectly copied in MKV files
0013532: [Crash] Scaler crash
ConvertXtoVideo - 2.0.0.89 Released 2018-06-05
Fix Subtitle issue
0013489: [Bug] Subtitles from BD source always appear in an opaque box
0013512: [Bug] Loading BD/DVD structure from disc no longer work
ConvertXtoVideo - 2.0.0.88 Released 2018-04-18
Fix file reader issue
0013476: [Bug] Produced video/audio has glitches, encoding stop before the end
ConvertXtoVideo - 2.0.0.86 - Released 2018-02-27
0013466: [Bug] Preliminary parsing of DVD Sources stuck.
ConvertXtoVideo - 2.0.0.85 - Released 2018-01-16
- 0013451: [Bug] Progress fomr not always appears on collaing form's center (felicia)
- 0013445: [Bug] Burning an already converted project may produce bad disks (felicia)
- 0013440: [Bug] Delete folder after burn not working if ISO is selected (felicia)
- 0013435: [Bug] Overhaul file loading (May fix random load deadlock) (felicia)
- 0007673: [Information] no theme on delete profile window (felicia)
- 0013426: [Bug] Remux disabled for audio in BD/DVD custom profiles (felicia)
ConvertXtoVideo - 2.0.0.84 - Not Yet Released
- 0013412: [Crash] Random crash in edit window if seeking after video playback ends (felicia)
- 0013414: [Bug] Error wrongly reported when remux is deactivated (felicia)
- 0013410: [Bug] DTS encoding wrongly offered as option (felicia)
ConvertXtoVideo - 2.0.0.83 - Released 2017-11-27
- 0013384: [Feature Request] Detail reasons to refuse remux (felicia)
- 0013374: [Bug] Language selection reads & writes to other programs (felicia)
- 0013400: [Bug] Wrong output size calculation when remuxing from DVD or BD (felicia)
- 0013398: [Bug] If source is DVD only beginning of video is read (felicia)
- 0013393: [Bug] Conversion files if last project name letter is a space for DVD output (felicia)
- 0013389: [Feature Request] Add support for F4V files (felicia)
- 0013379: [Bug] complex ass subtitles do no display in CXD preview or on output (felicia)
- 0013373: [Bug] Delete after burn option no longer works (felicia)
- 0013366: [Bug] conversion fails with subrip because of unhandled exception (felicia)
- 0013359: [Bug] Custom typesettings not remembered (felicia)
ConvertXtoVideo - 2.0.0.82 - Released 2017-10-26
- 0013353: [Bug] Add missing DLLs for localisation tool (felicia)
- 0007387: [Information] if conversion advisor in red conversion still starts (felicia)
- 0013336: [Bug] User bitrate is not always applied (felicia)
- 0013331: [Bug] BD subtitles rendered empty (felicia)
ConvertXtoVideo - Latest beta - 2.0.0.99 released!
Re: ConvertXtoVideo - Latest beta - 2.0.0.99 released!
Could you please ask Jacques to please make the 64bit program versions he's working on Processor Group Aware, so that high performance multi-core and/or multi-processor machines can use all their cores, rather than be limited to 1 group, as your current programs are.
Here's 2 links that help explain -
https://bitsum.com/general/the-64-core- ... d-windows/
https://docs.microsoft.com/en-us/window ... sor-groups
I use the ConvertX series daily, I'd just like to be able to use them to the fullest ability of my workstation
Joseph
Send Lawyers, Guns and Money
Quoting Jacques:
The new 64bit structure will have detached executable for each conversion encoding. Each will use its own group. However, it will depend on wanted output and hardware/software encoding. Group repartition should improve the process.
That is (effectively) the way it works now with 32 bit (if you start more than one instance of the executable).
But running multiple instances of the same executable is not the fastest way with multiple groups available (from what I've seen in Handbrake)
It would be much faster for true workstations if the 64bit executable were to use all available groups for each conversion, rather than a single group for each conversion. Each group (under Windows) is a NUMA node and some workstations have the ability to split NUMA nodes.
Perhaps it could be an option?
