ConvertXtoDVD - Latest beta - 7.0.0.73 released!
Click here to Download latest beta version 7.0.0.73
Click here to download the Latest release version
Release notes:
Fix encoding of very complex SSA subtitles
Changes log
7.0.0.73 Released 2020-05-14
0013876: [Bug] ASS huge subtitles issue
0013881: [Bug] Memory allocation issue
0013887: [Bug] Having Japanese characters on menu blocks conversion
7.0.0.70 Released 2020-03-13
Fix regsitration issues after update of registration servers
0013863: [Bug] Restore Compatibility with Windows Vista
7.0.0.69 Released 2019-11-13
Yet another subtitle bug fixed
0013736: [Bug] [VSORep] disabled emails appears on the pre-filled box
0013764: [Bug] [VSORep] closed ticket if we cannot retrieve the status
0013772: [Bug] Subtitles issue -> red subtitle with green border
0013788: [Suggestion] [HELP MENU] Change "Report a bug" to "Support Center" + icon
7.0.0.68 Released 2019-10-10
Fix subtitle rendering issue in preview
0013732: [Bug] Preview with subtitles -> Crashing
0013737: [Feature Request] [VSORep] "app will be closed" warning issued during install/reinstall process
0013738: [Feature Request] [VSORep] error message if Internet-OFF
7.0.0.67 Released 2019-10-02
Upgrade bug reporting tools
0013678: [Bug] Editable subtitles + Button Overlays => colours change after conversion
0013705: [Suggestion] Even if the project has been saved - it asks again when closing the software
0013715: [Bug] All VSO products not opening for no obvious reason
0013721: [Feature Request] VSO Reporting Tool is not user-friendly.
7.0.0.66 Released 2019-06-24
0013653: [Bug] "Check for Update" not working well
0013655: [Bug] Video sources contained in ISO files are no longer supported
0013656: [Bug] Poor quality in converted subtitles
0013660: [Bug] no progression bar during conversion
0013669: [Bug] WMV format can't be converted to mp4 - no video - sound only
0013674: [Feature Request] Add setting to space lines of subtitles
*7.0.0.65 Released 2019-06-17
Improve support of VC-1 source, 1-click update
0013583: [Bug] Support of VC-1 is broken/incomplete
0013648: [Feature Request] Simpler 1-click update
7.0.0.64 Released 2018-09-14
Bugfix release, saved settings are back, updated skin engine
0013570: [Bug] Remember the last opened folder doesn't work for "Burn an already converted project"
0013573: [Bug] Default settings forced at installation
0013574: [Feature Request] Visual Appearence: Update to Alphaskin 14
7.0.0.62 Released 2018-09-10
Bugfix release, improve detection of issues with antivirus.
0013479: [Bug] "Insert Disc" appear when starting ConvertX
0013498: [Bug] Undetailed failure while encoding
0013557: [Bug] Incompatibility with AVG: encoding fail at the beginning
0013561: [Feature Request] Add write probing mechanism for working folder
0013567: [Bug] Conversion is dead slow while in menu generation
7.0.0.61 Released 2018-06-25
0013494: [Bug] Incorrect conversion of BD subtitles to DVD subtitles
0013507: [Bug] Access violation
0013513: [Bug] Loading BD/DVD structure from disc no longer work
0013522: [Feature Request] Add the ability to change the vertical position of Image subtitles (DVD, BD, DVB, ...)
0013530: [Crash] Scaler crash
ConvertXtoDVD - 7.0.0.60 Released 2018-05-29
0013482: [Bug] Embedded Subtitles in MKV are not all converted to DVD
0013506: [Bug] Movie Conversion failure
0013509: [Bug] AVI audio out of sync after conversion, but source play correctly
0013510: [Bug] intro video function no longer work
0013511: [Bug] Open folder button display text in 2 lines in 'overwrite folder' dialog
ConvertXtoDVD - 7.0.0.59
- 0013480: [Bug] Video file fail to load when there is the character ";" (semicolon) in the file name. (wesson)
- 0013479: [Bug] "Insert Disc" appear when starting ConvertX (wesson)
ConvertXtoDVD - 7.0.0.58 - Released 2018-03-28
- 0013474: [Bug] Produced video/audio has glitches, encoding stop before the end (wesson)
ConvertXtoDVD - 7.0.0.57 Released 2018-02-27
Fix slow or failed parsing of some sources
- 0013464: [Bug] Preliminary parsing of DVD Sources stuck. (wesson)
ConvertXtoDVD - 7.0.0.56 - Released 2018-01-16
- 0013453: [Feature Request] Add thumbs to section bar (felicia)
- 0013448: [Bug] Progress fomr not always appears on collaing form's center (felicia)
- 0013446: [Bug] Exception when opening cut tab (felicia)
- 0013442: [Bug] Burning an already converted project may produce bad disks (felicia)
- 0013437: [Bug] Delete folder after burn not working if ISO is selected (felicia)
ConvertXtoDVD - 7.0.0.55 - Released 2018-01-04
- 0013432: [Bug] Overhaul file loading (May fix random load deadlock) (felicia)
- 0013430: [Feature Request] Add thumbs to sections in cut tab (felicia)
- 0013428: [Feature Request] Add thumbs when hovering video trackbar (felicia)
- 0013419: [Bug] Program prevents batcher to switch to next item if output is ISO (felicia)
ConvertXtoDVD - 7.0.0.54 - Released 2017-12-05
From this version on, smart copy/remux settings will be independent for video, audio and subtitle streams. You can set them in the "Encoding", "Audio" and "Subtitle" settings in the "Default settings" form.
- 0013417: [Feature Request] Detect stt file language if present in filename (felicia)
- 0013402: [Bug] Any way to keep "Sound Events" preferences? (felicia)
- 0013408: [Bug] Template editor - Resources not remembered if not copied (felicia)
- 0013406: [Bug] Template editor - Button overlays are not remembered (felicia)
- 0013404: [Bug] Separate smart copy option for video, audio and subtitles (felicia)
ConvertXtoDVD - 7.0.0.53 - Released 2017-11-27
- 0013381: [Feature Request] Detail reasons to refuse remux (felicia)
- 0013368: [Bug] conversion fails with subrip because of unhandled exception (felicia)
- 0013357: [Bug] Default typesetting not applied if custom (felicia)
- 0013394: [Bug] If source is DVD only beginning of video is read (felicia)
- 0013390: [Bug] Conversion files if last project name letter is a space for DVD output (felicia)
- 0013387: [Feature Request] Add support for F4V files (felicia)
- 0010703: [Bug] complex ass subtitles do no display in CXD preview or on output (felicia)
- 0013370: [Bug] Delete after burn option no longer works (felicia)
- 0013364: [Bug] Audio edition for menu has issue with drop down translation visibility (felicia)
ConvertXtoDVD - 7.0.0.52 - Released 2017-10-26
- 0013350: [Bug] Add missing DLLs for localisation tool (felicia)
- 0013348: [Feature Request] Add import option for menu templates (felicia)
- 0013343: [Bug] A period appears after the Title (wesson)
- 0013344: [Bug] Folder not deleted after burning (wesson)
- 0010931: [Feature Request] make sure Spanish translation is uptodate (felicia)
- 0013339: [Bug] Exception when entring empty chain in menu editor (felicia)
- 0009955: [Suggestion] use 'disc' instead of 'disk' (felicia)
- 0009291: [Bug] taken into account folder structure when checking file name length (felicia)
- 0008328: [Bug] FR hint for cores setting is not correct (felicia)
- 0013333: [Bug] BD subtitles rendered empty (felicia)
Re: ConvertXtoDVD - Latest beta - 7.0.0.68 released!
Just to inform that the Bug Report Tool has some problems which are being looked into.
Please be patient.
Re: ConvertXtoDVD - Latest beta - 7.0.0.69 released!
:!: New beta version released!
Problem with audio start in menu still there in all its glory :( :?
Audio always begin from the beginning of the file.
Does not exist in version 7.0.0.61
DaveRFD
Post by DaveRFD »
Confirming bug reported by Coral, the menu audio does NOT align with the video selection, in fact...it can't be changed at all.
Hi everyone, sorry I haven't been around much lately :(
DAVE
Hi there,
I know Coral... We are sorry for that.
Menu editor was completely designed by Felicia, it is complex for Jacques to take over this part.
He is not familiar with the code. It demands too much time, and we will only do shorty corrections until 64bit.
Hi Dave, nice to meet you :)
This bug has been reported by Coral, thanks for confirming it! https://bugs.vso-software.fr/view.php?id=13783
Cheers,
Yes I know it is very complex. Felicia and I spent months exchanging email with ideas.
eddie11013
Post by eddie11013 »
Interesting - Why does it say: Trial period without limitation. In addition I just now remembered that it hasn't asked for my 'key', although I usually copy the key in advance before I open the program so that I will be ready for it.
Also, find attached my latest log of a movie I just made.
ConvertXtoDVD 7_mainlog.20191119.122403.899.log
(16.55 KiB) Downloaded 1348 times
Eddie, You need to have your internet on for the application to update and remove trial.
If you don't manage, let me know.
eddie11013
Hopefully issue is resolved. Normally I install program and program 'detects' my license key that I have copied to clipboard and I'm good to go. Have learned in the past that 'vpn' can not be "on" when doing this, so vpn is not installed until key is accepted. Anyway, I uninstalled vpn and uninstalled v68, installed v69 and still issue remained. Your post about "internet" being on, my Internet is always on by the way, led me to look at that "Help/Tools" again, and there was the "Enter License Key", clicked that, now program 'saw' by license key in clipboard, accepted that and hopefully I'm good. I'm going to assume that "something in that area" changed. Anyway now that I know that I should be good. -- "About" now shows registered version.
Thanks for your help.
filmczy
Post by filmczy »
Color option in menu edit still shows "Personnaliser"
I believe this was already reported as a bug prior to new release.
filmczy wrote: Fri Nov 22, 2019 6:01 am Color option in menu edit still shows "Personnaliser"
Hi there,
It has been reported: https://bugs.vso-software.fr/view.php?id=13804
Cheers,
BrimStone
Post by BrimStone »
v7.0.0.69 says my key is TOO OLD. OLD???
I purchased v7.0.0.59, upgraded to v7.0.0.64 with no problem. I installed v7.0.0.69 tonight, I enter the key and the program goes online to verify it and says my key is TOO OLD!!! WTF??? From v7.0.0.59 to v7.0.0.69 is NOT old!!! I could understand going from v6 to v7 getting a new key, but getting an OLD message from MINOR UPDATES in this program is NOT old!!!
I will just go back to v7.0.0.64 and say "screw you v7.0.0.69 !!!"
I am not paying another fee for such a minor update. Unless the fee is equal to the update, so do I send you my nickel and we call it even?
BrimStone,
Try and do a clean uninstallation of the application. Keep your internet on and install the latest version.
BrimStone
Post by BrimStone »
I did a CLEAN install and v7.0.0.69 STILL says my key is TOO OLD.
This is what I did:
I uninstalled v7.0.0.64, which likes my key. BTW, v7.0.0.68 gives me the SAME error as v7.0.0.69 saying my key is TOO OLD. I know your FTP site and downloaded an older version to see where your problem arises, and its v7.0.0.68. (the last 3 versions on your ftp site are 7.0.0.69, 7.0.0.68 and 7.0.0.64) After I uninstalled v7.0.0.64, I installed v7.0.0.69 and chose ALL the options to clean out older/previous version info. I have enclosed a screen capture of this. After program is installed AND I am connected to the net, I enter my VALID key, and v7.0.0.69 STILL says my key is TOO OLD!!!
So I now use your CleanVSO program, which removes ALL VSO software. When I run this program, it sees v4.1.19.365c, which I still HAVE TO USE because the NEWER versions of ConvertXtoDVD do NOT see DTS audio tracks. See this link viewtopic.php?t=20009 on why VSO REMOVED this feature and CRIPPLED newer versions.
For some reason, CleanVSO does NOT show v7 as being installed. hmmm, that's odd. I run it anyway to see if it removes v4 and v7 I have installed, knowing that VSO software is flaky and buggy. I check and the program groups AND folders on my hard drive are indeed removed. wow. It actually worked. Almost.
I reboot Windows (FYI: I'm using Win7 Ultimate 64 bit) I run CCleaner Pro (registered version) and it removes a few leftover temp files and registry keys that CleanVSO did NOT remove. I reboot Windows again. I run CleanVSO again and it doesn't see ANY VSO software. I then install v7.0.0.69, using the SAME CLEANING options as before, connected to the net, using my VALID product key and...........it says my key is TOO OLD again!!! WTF!!!???? v7.0.0.69 is obviously crap and buggy, I uninstall it, install v7.0.0.64 which sees my VALID key as good.
Maybe when v7.0.0.70 comes out in the next 5 years VSO will fix this BUG and MAYBE put BACK the feature where the program will see DTS audio tracks. :evil:
p.s.
And WHEN is VSO going to MAKE a users guide for v7? v6 which is similar but different is dated Feb 2016, which is ALMOST 4 YEARS OLD! And stop telling me you have a "skeleton crew", that excuse was old YEARS AGO. Replace the skeletons with LIVE people and get things FIXED and UPDATED. :shock:
Hi BrimStone,
I've just sent your new key by email.
Please note that your 1-year free update license has expired since 20-Jun-2019.
The download links point to the latest version(s) that can be used with your license: Regards,
P.S: new guides will be published for the 2020's 64bit versions.
BrimStone
Post by BrimStone »
Hi Maggie, I received the email and the new product key. I did a clean install, AGAIN, as I have explained before, entered the new key and the message is get is:
Gee, why am I NOT surprised.
How about you send me the uncompiled code, I FIX the program like it's supposed to be fixed (I used to be a programmer way back) and I rename it BrimStoneXtoDVD?
Your key is too old for v 7.0.0.69.
Either go back to one of the two versions I gave you before, or renew for another year, or purchase a lifetime license with lifetime updates so your key will never be too old again! 8)
2019-11-27_12-47-15 (2).png (2.63 KiB) Viewed 95133 times
BrimStone wrote: Wed Nov 27, 2019 6:07 am How about you send me the uncompiled code, I FIX the program like it's supposed to be fixed (I used to be a programmer way back) and I rename it BrimStoneXtoDVD?
As if !!
BrimStone
Post by BrimStone »
Ok Maggie, so I have to pay full price for a NEW license to go from v7.0.0.64 to v7.0.0.69 ???? No FRAKKIN WAY!!!
That NEW license price should be commensurate to the version advancements, in this case I think a NICKEL is what its worth to go from v7.0.0.64 to v7.0.0.69. And even then, I think I should get some change back. Especially since v7 is CRIPPLED and it does NOT see DTS audio tracks in files, but v4 will. AND, NO manual for v7 either. Is that VSO's policy, to charge customers more for getting less??? :evil:
