DVD&Blu-ray Converter - Latest beta - 4.0.0.99 released!
Latest beta version 4.0.0.99 available here:
Blu-ray Converter
DVD Converter
Latest release versions here:
DVD Converter
Blu-Ray converter
Release notes:
Support Center minor changes.
Green & red subtitle issue has been resolved!
Changes log:
4.0.0.99 Released 2019-11-13
Yet another subtitle bug fixed
0013537: [Bug] Runtime error 217 occurs randomly
0013701: [Bug] Subtitles issue -> red subtitle with green border
0013746: [Bug] [VSORep] disabled emails appears on the pre-filled box
0013767: [Bug] [VSORep] closed ticket if we cannot retrieve the status
4.0.0.98 Released 2019-10-14
Fix subtitle rendering issue in preview
0013668: [Bug] "Check for Update" not working well
0013741: [Bug] Preview with subtitles -> Crashing
0013750: [Feature Request] [VSORep] "app will be closed" warning issued during install/reinstall process
0013754: [Feature Request] [VSORep] error message if Internet-OFF
0013758: [Bug] [VSO Rep] Re-Install not working
4.0.0.97 Released 2019-10-02
Upgrade bug reporting tools
0013718: [Bug] All VSO products not opening for no obvious reason
0013724: [Feature Request] VSO Reporting Tool is not user-friendly.
4.0.0.96 Released 2019-06-24
0013658: [Bug] Poor quality in converted subtitles
0013664: [Bug] no progression bar during conversion
0013671: [Bug] WMV format can't be converted to mp4 - no video - sound only
4.0.0.95 Released 2019-06-18
Introduce easier 1-click update system
4.0.0.94 Released 2018-12-20
Partial Fix of some Subtitle issues - Improve encoding quality for HD and Blu-Ray target - more robust encoding
0013602: [Bug] SRT subtitle file not accepted
4.0.0.93 Released 2018-10-23
Improve support of VC-1 source - Fix HW encoding on Nvidia Pascal-Based graphic cards
0013585: [Bug] Support of VC-1 is broken/incomplete
0013599: [Bug] Hardware encoding fail on NVIDIA GTX 10xx cards
4.0.0.92 Released 2018-06-25
Bugfix release, updated skin engine
0011480: [Feature Request] allow possibility to change vertical and horizontal margins and scale of DVDsub format subtitles
0013566: [Feature Request] Add write probing mechanism for working folder
0013577: [Feature Request] Visual Appearence: Update to Alphaskin 14
0013580: [Feature Request] Add Iphone 8 and Iphone X profiles
4.0.0.91 Released 2018-06-25
0013544: [Feature Request] Add computer revocation mechanism for licensee
4.0.0.90 Released 2018-06-13
0013492: [Bug] Soundtrack with Dolby True HD or other high end audio are systematically re-encoded.
0013495: [Bug] Incorrect conversion of BD subtitles to DVD subtitles
0013521: [Bug] DVD subtitles incorrectly copied in MKV files
0013524: [Feature Request] Add the ability to change the vertical position of Image subtitles (DVD, BD, DVB, ...)
0013533: [Crash] Scaler crash
Blu-ray & DVD Converters - 4.0.0.89 Released 2018-06-05
Fix Subtitle issue
0013490: [Bug] Subtitles from BD source always appear in an opaque box
0013515: [Bug] Loading BD/DVD structure from disc no longer work
Blu-ray & DVD Converters - 4.0.0.88
Fix file reader issue
- 0013477: [Bug] Produced video/audio has glitches, encoding stop before the end (wesson)
Blu-ray & DVD Converters - 4.0.0.86 - Released 2018-02-27
- 0013467: [Bug] Preliminary parsing of DVD Sources stuck. (wesson)
Blu-ray & DVD Converters - 4.0.0.85 - Released 2018-01-16
- 0013449: [Bug] Progress fomr not always appears on collaing form's center (felicia)
- 0013443: [Bug] Burning an already converted project may produce bad disks (felicia)
- 0013438: [Bug] Delete folder after burn not working if ISO is selected (felicia)
- 0013433: [Bug] Overhaul file loading (May fix random load deadlock) (felicia)
- 0013425: [Bug] Remux disabled for audio in BD/DVD custom profiles (felicia)
Blu-ray & DVD Converters - 4.0.0.84 - Released 2017-12-05
- 0013413: [Crash] Random crash in edit window if seeking after video playback ends (felicia)
- 0013415: [Bug] Error wrongly reported when remux is deactivated (felicia)
- 0013411: [Bug] DTS encoding wrongly offered as option (felicia)
Blu-ray & DVD Converters - 4.0.0.83 - Released 2017-11-27
- 0013382: [Feature Request] Detail reasons to refuse remux (felicia)
- 0013399: [Bug] Wrong output size calculation when remuxing from DVD or BD (felicia)
- 0013396: [Bug] If source is DVD only beginning of video is read (felicia)
- 0013391: [Bug] Conversion files if last project name letter is a space for DVD output (felicia)
- 0013386: [Feature Request] Add support for F4V files (felicia)
- 0013377: [Bug] complex ass subtitles do no display in CXD preview or on output (felicia)
- 0013375: [Bug] Language selection reads & writes to other programs (felicia)
- 0013371: [Bug] Delete after burn option no longer works (felicia)
- 0013367: [Bug] conversion fails with subrip because of unhandled exception (felicia)
- 0013360: [Bug] Custom typesettings not remembered (felicia)
Blu-ray & DVD Converters - 4.0.0.82 - Released 2017-10-26
- 0013351: [Bug] Add missing DLLs for localisation tool (felicia)
- 0013337: [Bug] User bitrate is not always applied (felicia)
- 0013332: [Bug] BD subtitles rendered empty (felicia)
Re: DVD&Blu-ray Converter - Latest beta - 4.0.0.99 released!
:!: New beta version released!
dosibo51
Post by dosibo51 »
When I enable "Add an additional subtitle track with forced subtitles" in Settings > Conversion > Subtitle and select e.g. "Deutsch" (German) as forced subtltle language, press OK etc.
and then re-start blu-ray converter, the selected subtltle language is jumped back to default "English" (bug).
Maybe all other converters have the same bug.
Can you fix this small bug please?
I'm using latest 4.0.0.100 (from official download) (missing here as beta incl release notes).
