2 bugs of version 3.0.0.70 !
minhcute
Post by minhcute »
I just converted a movie to Blu-ray folder by using ConvertXtoHD 3.0.0.70. And the output result has 2 bugs :
1. The total duration of output movie is only 10 minutes while the original duration of input video is 01:53:56 ! It means that version 3.0.0.70 only converted first 10 mintues of my video !
2. The output Vietnamese Blu-ray subtitle has font error !
The following attachments are the log file and 2 pictures for you to understand what I want to describe. Please see them carefully.
I used graphic card Geforce GTX 1050Ti, NVENc encoding for conversion.
I hope you will reply soon
log file.txt
1. The log file
(9.25 KiB) Downloaded 554 times
2. The duration of input video
3. The duration of output Blu-ray folder movie
Re: 2 bugs of version 3.0.0.70 !
1) I suggest that you check in the About to see if the application is in demo mode or not.
If it is in full mode then try another movie.
1) I can't comment about the Vietnamese subs since can't read Vietnamese.
Hi minhcute,
Thanks for the detailed report.
I'll investigate on that asap & will keeep you informed.
Cheers,
minhcute
Post by minhcute »
Thanks !
I finally get some time to investigate! Sorry for the delay minhcute :oops:
Please send me the subtitle track / source files here:
minhcute
Post by minhcute »
Thank you, Maggie.
I changed another Vietnamese subtitle then tried converting again, and the result was OK.
