Adding chapters - arrow key playback speed? Zoom?
outdoorben
Post by outdoorben »
Hi --
New to the software. One thing that I find really frustrating is trying to add chapters at exactly the right point I want them in a very long video. I either drag the slider (too fast, so not accurate), or use the right/left arrow keys (same problem) and there is no way to zoom in the timeline.
Questions:
1. Is there any way to get the forward/reverse playback using the arrow keys to slow down? As in just real time playback instead of skipping?
2. Does anyone know if there are plans to add a zoom feature?
The above have a very negative effect on my productivity. I edit lots of videos of community musicals, and I want the chapters to be in very exact positions. Thank you!
-Ben
Re: Adding chapters - arrow key playback speed? Zoom?
Hi there,
Could you please send a screenshot explaining what feature would you like to see exactly?
Thanks a lot!
Cheers,
Chapter points are always problematic since it all depends on key frames.
