Warning message
newsom3569
Warning message
Post by newsom3569 »
I have been trying to convert some videos and the length in convertxtodvd shows one length before conversion and a radically different length after conversion. I found a warning but am not sure what it means here is the log. Any help would be appreciated
:std_log='C:\Users\neptu\AppData\Roaming\VSO\ConvertXtoDVD\7\Log\ConvertXtoDVD 7_mainlog.20191120.234112.706.log'
:library=false
:app_name=ConvertXtoDVD.exe
:app_version=7.0.0.68
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
23:29:54.885 Info Total size 1343 Mb., Target size DVD5 4300 Mb., Occupation 31.25%
23:30:02.485 Info Disc name: "KATIE THOMAS VOL. 3"
23:29:55.789 Info Burned folder: "C:\Users\neptu\OneDrive\Documents\ConvertXtoDVD\KATIE THOMAS VOL. 3", Min. media size 1.31 GB.
23:29:54.881 Info Conversion completed in 00:07:02
23:29:53.507 Info "TITLE 1/1 (Global 1/1)" menu built successfully
23:29:41.544 Important Starting BD title menus encoding: [Memory load 59%] [Available virtual memory 3598 Mb.]
23:29:41.541 Info Building TITLE menu
23:22:52.671 Info [ ] Loop playback
23:22:52.671 Info [ ] Play titles one after the other
23:22:52.670 Info [ ] Don't create title menu for single video
23:22:52.669 Info [x] Return to title menu after titleset playback
23:22:52.669 Info [x] Skip root menu initially
23:22:52.668 Info [ ] Auto-start playback
23:22:52.668 Info Template: Metallic (open style), contains 4 page(s)
23:22:52.668 Group Video DVD menu options
23:22:52.667 Info Video DVD format: NTSC (30 Fps)
23:22:52.666 Info Output target size : DVD-5 (4300 MB)
23:22:52.666 Info Number of core(s) used for encoding : 4
23:22:52.665 Info Number of core(s) used for decoding : 4
23:22:52.665 Info [ ] Use 2 pass encoding
23:22:52.664 Info [ ] Use best video quality settings
23:22:52.663 Info [ ] Use hardware decoding (if possible)
23:22:52.663 Info Max simultaneous conversions: 4
23:22:52.663 Group Advanced encoding options
23:29:40.999 ------------ ****************************************File encoded successfully: VTS_04_1.VOB*****************************************
23:29:40.993 Info "CHAPTERS 2/2 (Global 3/3)" menu built successfully
23:29:26.811 Info "CHAPTERS 1/2 (Global 2/3)" menu built successfully
23:28:43.288 Info "ROOT 1/1 (Global 1/3)" menu built successfully
23:28:16.434 Important Starting BD root menu encoding: [Memory load 60%] [Available virtual memory 3458 Mb.]
23:28:16.411 Info Building ROOT, CHAPTERS, menus using template: Metallic (open style)
23:28:15.838 Info DVD sectors written - video: 152096, audio: 7143, subtitle: 0
23:28:15.822 Info video #1 - Processed video frames: 17972 (17974 frames encoded, 0 frames dropped, 2 frames duplicated)
23:23:05.321 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
+-[audio [eng] aac main audio 2 Ch. 48000Hz , 64 Kbps]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 4x3, 29.97Fps, 4090Kbps]
+-[video [eng] h264 480x360 15:11 yuv420p, 29.97Fps, 800Kbps ]
Output file: C:\Users\neptu\OneDrive\Documents\ConvertXtoDVD\KATIE THOMAS VOL. 3\VIDEO_TS\VTS_04_1.VOB (DVD NTSC)
Input file: C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\stallion_640_sm.mp4
Video filters used:
- DeInterlace filter: VSO
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: letterbox (Padding: top: 6, bottom: 6, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
23:23:05.297 Info Chapters to generate: 3 (0h00m00s, 0h05m00s, 0h10m00s, )
23:23:05.296 Important Starting video encoding: [Memory load 60%] [Available virtual memory 3561 Mb.]
23:23:05.093 Verbose FFmpeg Opening file C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\stallion_640_sm.mp4
23:22:51.865 Warning Stream 65537, none not found in C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\stallion_640_sm.mp4
23:22:51.865 Warning Stream 65536, none not found in C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\stallion_640_sm.mp4
23:22:51.838 Verbose FFmpeg Opening file C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\stallion_640_sm.mp4
23:22:51.837 Group ******************** Titleset #4 - ~30 min. File: "stallion_640_sm" -> VTS_04_1.VOB - DVD NTSC ********************|GK_TITLESET|
23:29:36.189 ------------ ****************************************File encoded successfully: VTS_03_1.VOB*****************************************
23:29:36.167 Info "CHAPTERS 2/2 (Global 3/3)" menu built successfully
23:29:19.651 Info "CHAPTERS 1/2 (Global 2/3)" menu built successfully
23:28:34.683 Info "ROOT 1/1 (Global 1/3)" menu built successfully
23:28:10.764 Important Starting BD root menu encoding: [Memory load 59%] [Available virtual memory 3556 Mb.]
23:28:10.762 Info Building ROOT, CHAPTERS, menus using template: Metallic (open style)
23:28:10.330 Info DVD sectors written - video: 151935, audio: 7143, subtitle: 0
23:28:10.328 Info video #1 - Processed video frames: 17969 (17971 frames encoded, 0 frames dropped, 2 frames duplicated)
23:23:00.919 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
+-[video [eng] h264 480x360 15:11 yuv420p, 29.97Fps, 799Kbps ]
Output file: C:\Users\neptu\OneDrive\Documents\ConvertXtoDVD\KATIE THOMAS VOL. 3\VIDEO_TS\VTS_03_1.VOB (DVD NTSC)
Input file: C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\kt_audrey_elson_640_sm.mp4
Video filters used:
23:23:00.916 Info Chapters to generate: 3 (0h00m00s, 0h05m00s, 0h10m00s, )
23:23:00.912 Important Starting video encoding: [Memory load 60%] [Available virtual memory 3597 Mb.]
23:23:00.824 Verbose FFmpeg Opening file C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\kt_audrey_elson_640_sm.mp4
23:22:51.685 Warning Stream 65537, none not found in C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\kt_audrey_elson_640_sm.mp4
23:22:51.684 Warning Stream 65536, none not found in C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\kt_audrey_elson_640_sm.mp4
23:22:51.657 Verbose FFmpeg Opening file C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\kt_audrey_elson_640_sm.mp4
23:22:51.656 Group ******************** Titleset #3 - ~30 min. File: "kt_audrey_elson_640_sm" -> VTS_03_1.VOB - DVD NTSC ********************|GK_TITLESET|
23:29:38.441 ------------ ****************************************File encoded successfully: VTS_02_1.VOB*****************************************
23:29:38.439 Info "CHAPTERS 2/2 (Global 3/3)" menu built successfully
23:29:22.768 Info "CHAPTERS 1/2 (Global 2/3)" menu built successfully
23:28:37.718 Info "ROOT 1/1 (Global 1/3)" menu built successfully
23:28:13.703 Important Starting BD root menu encoding: [Memory load 59%] [Available virtual memory 3529 Mb.]
23:28:13.697 Info Building ROOT, CHAPTERS, menus using template: Metallic (open style)
23:28:13.443 Info DVD sectors written - video: 151971, audio: 7143, subtitle: 0
23:28:13.442 Info video #1 - Processed video frames: 17972 (17974 frames encoded, 0 frames dropped, 2 frames duplicated)
23:22:56.793 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
Output file: C:\Users\neptu\OneDrive\Documents\ConvertXtoDVD\KATIE THOMAS VOL. 3\VIDEO_TS\VTS_02_1.VOB (DVD NTSC)
Input file: C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\byron_pile_driver_640_sm.mp4
Video filters used:
23:22:56.790 Info Chapters to generate: 3 (0h00m00s, 0h05m00s, 0h10m00s, )
23:22:56.790 Important Starting video encoding: [Memory load 59%] [Available virtual memory 3628 Mb.]
23:22:56.743 Verbose FFmpeg Opening file C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\byron_pile_driver_640_sm.mp4
23:22:51.502 Warning Stream 65537, none not found in C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\byron_pile_driver_640_sm.mp4
23:22:51.501 Warning Stream 65536, none not found in C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\byron_pile_driver_640_sm.mp4
23:22:51.473 Verbose FFmpeg Opening file C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\byron_pile_driver_640_sm.mp4
23:22:51.472 Group ******************** Titleset #2 - ~31 min. File: "byron_pile_driver_640_sm" -> VTS_02_1.VOB - DVD NTSC ********************|GK_TITLESET|
23:29:15.008 ------------ ****************************************File encoded successfully: VTS_01_1.VOB*****************************************
23:29:14.992 Info "CHAPTERS 2/2 (Global 3/3)" menu built successfully
23:28:53.884 Info "CHAPTERS 1/2 (Global 2/3)" menu built successfully
23:28:11.523 Info "ROOT 1/1 (Global 1/3)" menu built successfully
23:27:40.402 Important Starting BD root menu encoding: [Memory load 59%] [Available virtual memory 3572 Mb.]
23:27:40.397 Info Building ROOT, CHAPTERS, menus using template: Metallic (open style)
23:27:40.061 Info DVD sectors written - video: 151981, audio: 7143, subtitle: 0
23:27:40.045 Info video #1 - Processed video frames: 17973 (17975 frames encoded, 0 frames dropped, 2 frames duplicated)
23:22:52.727 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
Output file: C:\Users\neptu\OneDrive\Documents\ConvertXtoDVD\KATIE THOMAS VOL. 3\VIDEO_TS\VTS_01_1.VOB (DVD NTSC)
Input file: C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\broc_640_sm.mp4
Video filters used:
23:22:52.726 Info Chapters to generate: 3 (0h00m00s, 0h05m00s, 0h10m00s, )
23:22:52.726 Important Starting video encoding: [Memory load 59%] [Available virtual memory 3660 Mb.]
23:22:52.683 Verbose FFmpeg Opening file C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\broc_640_sm.mp4
23:22:50.694 Warning Stream 65537, none not found in C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\broc_640_sm.mp4
23:22:50.693 Warning Stream 65536, none not found in C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\broc_640_sm.mp4
23:22:50.667 Verbose FFmpeg Opening file C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\broc_640_sm.mp4
23:22:50.665 Group ******************** Titleset #1 - ~30 min. File: "broc_640_sm" -> VTS_01_1.VOB - DVD NTSC ********************|GK_TITLESET|
23:22:50.661 Info Encoding options: Medium Project (Automatic)
23:22:50.660 Info Target size: 4300 Mb.
23:22:50.659 Important Setting queuer for DVD NTSC output: [Wait: 0], [ld: 0], [Hd: 0], [MAM: 100], [RM: 100], [ALL: False]
23:22:50.659 Important 4 simultaneous conversions allowed
23:22:50.657 Info Don't log FFMpeg log events
23:22:50.656 ------------ ***************************************************Burn settings end****************************************************
23:22:50.656 Info Default speed selected: 4x
23:22:50.656 Info [ ] Delete vsomsl files after burn complete
23:22:50.655 Info [ ] Delete output folder after burn complete
23:22:50.655 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
23:22:50.654 Info SAO setting: Automatic
23:22:50.654 Info [x] Burn result to disk / as ISO file in working folder
23:22:50.654 ------------ **************************************************Burn settings begin***************************************************
23:22:50.654 Group Encoding session started at 11:22:50 PM: 4 titleset(s) to encode -> Completed in 00:07:02|GK_CONVERT_SESSION|
23:22:34.346 Important Loaded with result [File ]
23:22:33.780 Info Loading: "C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\stallion_640_sm.mp4 - File" 4/4
23:22:33.780 Info Loading: "C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\kt_audrey_elson_640_sm.mp4 - File" 3/4
23:22:33.779 Info Loading: "C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\byron_pile_driver_640_sm.mp4 - File" 2/4
23:22:33.779 Info Loading: "C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\broc_640_sm.mp4 - File" 1/4
23:22:33.598 Info Sources filtered, found 4 protocols
23:22:33.432 Info Added protocol C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\stallion_640_sm.mp4, candidate 4/4
23:22:33.430 Info Added protocol C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\kt_audrey_elson_640_sm.mp4, candidate 3/4
23:22:33.428 Info Added protocol C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\byron_pile_driver_640_sm.mp4, candidate 2/4
23:22:33.427 Info Added protocol C:\Users\neptu\Downloads\Dogfart\Katie Thomas\3\broc_640_sm.mp4, candidate 1/4
23:22:33.243 Info Found 4 candidates
23:22:32.853 Info Filtering sources
23:22:32.853 Group Loading file(s)
23:15:41.865 Info Personnal resources size (C:\Users\neptu\OneDrive\Documents\ConvertXtoDVD_Resources\): 0MB, 0 file(s)
23:15:41.660 Info Monotonizer size (C:\ProgramData\vso\vsomsl): 0MB, 1 file(s)
23:15:41.456 Info Thumb cache size (C:\ProgramData\VSO\vsothumbs): 0MB, 1 file(s)
23:15:41.254 Info Logs and templates size (C:\ProgramData\VSO\ConvertXtoDVD\7\): 74MB, 664 file(s)
23:15:41.045 Group Folder data
23:15:41.035 Info Menu templates loaded: 20
23:15:39.151 Info License status: Expired license
23:15:39.151 Info License type: trial
23:15:39.150 Info Computer ID: 3980785
23:15:39.150 Group License
23:15:28.707 Info Loading templates from: "C:\Users\neptu\OneDrive\Documents\ConvertXtoDVD_Resources\Templates\"
23:15:28.706 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoDVD\7\Templates\"
23:15:28.701 ------------ **************************ConvertXtoDVD.exe:18096 Log session start 2019-11-20 at 23:15:26.964**************************
23:29:57.871 Info No disc in drive.
23:29:55.855 Info Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
23:29:55.854 Info Drive has Serial ATA physical interface
23:29:55.853 Info New Drive selected : [D] HL-DT-ST DVD+-RW GU90N A1C1 (SATA)
23:15:28.691 Info 1 writer(s) found.
23:15:28.602 Group Burn engine events
Re: Warning message
Tell me how it goes!
VSO Support team
newsom3569
Re: Warning message
I did all of the above and the 4 scenes should be 2 hours and it is like thirty minutes after conversion.
Convert x Says two hour before conversion
Upon Further investigation i have a feeling it is the website (legal) that i am getting the videos from they show correct length if you stream them the time changes upon download
Re: Warning message
Would it be possible for you to send the file via our Support Center tool?
