Hello
1-I set this to do a conversion, which said 1 hour, left it overnight, with the option to shutdown on completion, but in the morning it hadn’t shutdown, but had a pop up saying “ if you liked the program please tell others” i clicked ok, then it shutdown.....please make a change to allow the pop up to time out after say 5 minutes, so the pc can perform it’s a turn on program completion setting !!! Please
2-in your other apps the setting for what happens after the program has completed is in the Actions drop down menu.....which makes sense, as it is an action to be taken after completion....however in this program it is ‘hidden’ in the quick settings menu, which took me ages to find.....don’t see the point in the quick settings menu, it’s not necessary.......I assumed it would be a few of the main options in the full settings menu, so if you can add actions after completion in the Actions drop down menu, I think it would help everyone.
Thank you
PS when making a post, the notify me of any replies should be defaulted to Ticked, so many times I forget to tick this box before submitting the post...
Feature request(s)
Re: Feature request(s)
Hi there,
Thanks for your reports!
1- Good call! https://bugs.vso-software.fr/view.php?id=13812
2- You are perfectly right, we have to work on UX/UI.
We should be releasing new versions with brand new user interfaces later this year
3- https://bugs.vso-software.fr/view.php?id=13813
Cheers,
Cheers,
