Hi everybody
Is anybody like me: Downloader does not work with Qobuz in any configuration?
Thank you
[Downloader 5] Qobuz support?
Re: Qobuz ?
Hello, it has been reported.
https://bugs.vso-software.fr/view.php?id=13681
Your report has been added to the above bug report.
Re: Qobuz ?
Hi Cougar & Elenou6768
We filter small files < 4Mo in order not to overload detection result with ads.
Qobuz only delivers samples of 1.35Mo per song for unregistered user.
It's an intended Downloader 5 behavior to filter these samples..
If you don't have any credential for qobuz to properly test our software, we can't investigate the issue.
Cheers
Cheers
