Conversion Problem Line Of Duty S1
Nemesh
Post by Nemesh »
Source: Original Blu-Ray
Resolution:1080i
Framerate video: 25
Audio: Dolby Digital Audio 2.0
Profile: Main@4
Problem: ConvertXToHD will not do a RAW copy dispite the source is a original Blu_ray.
Settings for audio and video: Try to copy only if the source is a complient structure
Settings for subtitle: Always encode due to a bug in the subtitle-engine
Software version: 3.0.0.71
Re: Conversion Problem Line Of Duty S1
Original BR and DVD discs are copy protected.
You can't convert them without removing copy protection.
Removing it is prohibited in EU so it requires separate software.
minhcute
Post by minhcute »
Wait...Original Blu-ray : 1080i & 25 FPS ??????
Nemesh
Post by Nemesh »
@JJ, have send you a PM.
@ Minuchute, there are many, many original BD's out there that are 1080i@25 fps.
Hence, I even encountered 1080p@25 fps.
Bought them myself at Amazon and eBay.
As I understand the problem is in the FFMPEG library.
Example: The Cry Season 1: 1080i@25 fps original BD
LINK: https://imgur.com/4kYEWAn
Example: The Bletchley Circle Season 1: 1080i@29.970
LINK: https://imgur.com/Bayahbk
Example: Line Of Duty Season 1 Disc 1: 1080i@25fps
LINK: https://imgur.com/FjmahfO
And even the brand new series Bad Banks Season 2 released on 06-02-2020 is 1080i@25fps
LINK: https://imgur.com/eIoqUQ3
