Downloading HD Versions on YouTube
Gabrial
Post by Gabrial »
Hello everyone,,
Is it possible to download the HD version (on YouTube for example) :?: . I always download in poorer resolution.
openweb.vip/whatsapp-web/ https://19216801.onl/ routerlogin.uno/
Thanks a lot for support
Gabrial :wink:
Re: Downloading HD Versions on YouTube
Hi there, here are 2 methods you can try.
1- Manual: turn auto detection off.
Play the video and select the high definition resolution.
Copy & paste the url in downloader
2- I use firefox so I use this add-on: https://addons.mozilla.org/en-CA/firefo ... tube-hd-1/
Will always start every video to the highest resolution (or the one you select) and downloader will download the proper high definition version...
