Automatically burn to ISO file
I just purchased the latest version of ConvertXtoHD. It does not burn to ISO file automatically as did the old version. I have to click a button in the burn window to start the ISO creation. Is there a way to set to an automatic burn?
Re: Automatically burn to ISO file
Hi there,
You're right, there is a new small bug with this on the last version.
It has been reported and will be corrected asap (https://bugs.vso-software.fr/view.php?id=13799)
Cheers,
Cheers,
THIS HAS NOT BEEN CORRECTED IT STILL DOSE IT ON NEWEST BETA VERSION .74. WHERE CAN I GET OLDER VERSION LIKE 300.64
I don't see the point of you bumping up your feedback on May 4 from your original post May 2 and using CAPS, as you say, you have to "click a button in the burn window to start the ISO creation" and this resolves the issue.
I use this app and version 70074 many times to burn videos to Blu-ray and do not have this issue.
Have you tried reinstall, using "clean" option that is about 3 or 4 screens into the installation process?
You can get the older version by going to the product page. Then select your product, then click version history. there click the download for that version...It's a green down arrow next to the version you want...
