too many subtitles
djnish
too many subtitles
Post by djnish »
How do I remove some subtitles. Cannot convert because target size is too long.
Re: too many subtitles
Near as I remember, you don't save a whole lot of space by taking out the subtitles. So, you'll probably not achieve a desirable size by removing subtitles, unless there are a lot of subtitle streams in the source.
Anyway, to remove subtitles, I think you do the following:
Where it says Audio on the left side of the interface under a title set you've added, the available subtitle streams will be underlined. Click on these underlined subtitles. Click anywhere there will do the same thing. This will bring up the subtitles editor on the right side of the screen. You will notice a series of red circles with X's in them to the left of the available subtitle streams. Clicking on these X's will remove the selected subtitle stream. So, just remove as many as you desire.
