About Slimjet browser
I would like to ask about compatibility with Slimjet browser.
Until May 20 VSO Downloader worked OK with Slimjet browser,
when streaming video file opened in Slimjet, it was recognized by
VSO downloader. Now on May 21 - VSO downloader does not
recognize videos, opened on Slimjet browser any more.
Slimjet is fast and convenient browser, based on Chromium.
I have updated up to Slimjet Version 26.0.8.0
(based on Chromium 80.0.3987.87)
VSO Downloader user from September, 2011 - starting from version v. 1.4.0.37
Re: About Slimjet browser
The same VSO Downloader still works correctly,
recognizes automatically opened videos and downloads them
when working with another browser -
Google Chrome - Version 83.0.4103.61 (Official Build) (64-bit)
My Op system is Windows 10 Pro 64bit version 1909
and there was a new update in night between 20 and 21 May.
After that update downloaded and istalled all that my PC
(was an obligatory restart required!) all tha mess happened.
May be the new Windows 10 update is reason, why VSO
Downloader now refuses to work together with newest version of Slimjet.
But it still works with Google Chrome and Opera![Smile :)](./images/smilies/icon_smile.gif)
Problem SOLVED!!!
Downgraded Slimjet back to version 25.0.10.0 (Chromium 78.0.3904.63) 64bit and Hurray!![Smile :)](./images/smilies/icon_smile.gif)
With that (older version) VSO Downloader works again![Smile :)](./images/smilies/icon_smile.gif)
So - sometimes older is better!!!
Hi there,
Thanks for the report!
Could you please send me the download link for the last version of Slimjet you used?
So I can investigate.
Which Downloader version are you using now?
I investigated the VSO Downloader log by startup - and looks like it is a missing driver - WinPcap (libpcap) driver
from log -
06 juuni 19:39:22 | Streaming monitoring started: D-Link DWA-137 Wireless N High-Gain USB Adapter
06 juuni 19:39:21 | VSO EVE (NDIS) (8 event(s))
06 juuni 19:39:22 | Võrgukaart on edukalt automaatselt tuvastatud: D-Link DWA-137 Wireless N High-Gain USB Adapter
06 juuni 19:39:22 | Detection of the online network adapter finished
06 juuni 19:39:21 | Available network adapters: 4
06 juuni 19:39:21 | NIC_3 (7 event(s))
06 juuni 19:39:21 | NIC_2 (7 event(s))
06 juuni 19:39:21 | NIC_1 (8 event(s))
06 juuni 19:39:21 | NIC_0 (7 event(s))
06 juuni 19:39:21 | Starting detection of the online network adapter
06 juuni 19:39:21 | VSO EVE (NDIS) 0.2 driver is installed: started
06 juuni 19:39:21 | WinPcap (libpcap) driver is not installed - marked red
06 juuni 19:39:21 | Unable to load: wpcap.dll - marked red
06 juuni 19:39:21 | Unable to load: packet.dll - marked red
Is it possible to find that driver - or the VSO Downloader install should be done again ???
from log -
Full log -
06 juuni 19:39:22 | Updater: An update (5.1.1.70 release) is available online.
06 juuni 19:39:22 | License (3 event(s))
06 juuni 19:39:22 | License status: active customer license
06 juuni 19:39:22 | License type: commercial (online activated)
06 juuni 19:39:22 | Computer ID: 2720172
06 juuni 19:39:19 | download (1 event(s))
06 juuni 19:39:22 | Previous download loaded: 0
06 juuni 19:39:19 | NIC manager (5 event(s))
06 juuni 19:39:22 | NOT ONLINE
06 juuni 19:39:22 | Streaming monitoring stopped: Microsoft Wi-Fi Direct Virtual Adapter #2
06 juuni 19:39:21 | Streaming monitoring started: Microsoft Wi-Fi Direct Virtual Adapter #2
06 juuni 19:39:21 | NOT ONLINE
06 juuni 19:39:21 | Streaming monitoring stopped: Intel(R) Ethernet Connection I217-V
06 juuni 19:39:21 | Streaming monitoring started: Intel(R) Ethernet Connection I217-V
06 juuni 19:39:21 | ONLINE
06 juuni 19:39:21 | Streaming monitoring stopped: D-Link DWA-137 Wireless N High-Gain USB Adapter
06 juuni 19:39:21 | Streaming monitoring started: D-Link DWA-137 Wireless N High-Gain USB Adapter
06 juuni 19:39:21 | Streaming monitoring stopped: Microsoft Wi-Fi Direct Virtual Adapter
06 juuni 19:39:19 | proxy (5 event(s))
06 juuni 19:39:22 | HTTPS/SSL support activated
06 juuni 19:39:19 | setting (10 event(s))
06 juuni 19:39:21 | avutil.dll: 54.23.101
06 juuni 19:39:21 | avformat.dll: 56.30.100
06 juuni 19:39:21 | avcodec.dll: 56.35.101
06 juuni 19:39:21 | ad_c.dll loaded: version 1.4
06 juuni 19:39:19 | Ad Blocker successfully loaded
06 juuni 19:39:19 | Secure streams successfully loaded
06 juuni 19:39:19 | Registry successfully loaded
06 juuni 19:39:19 | detection (4 event(s))
06 juuni 19:39:19 | pkt manager (0 event(s))
06 juuni 19:39:19 | HLS (0 event(s))
06 juuni 19:39:19 | HDS (0 event(s))
06 juuni 19:39:19 | manual (0 event(s))
06 juuni 19:39:19 | Total Physical Memory : 8075 Mb.
Available Physical Memory : 4861 Mb.
Memory Load : 39%
Available Virtual Memory : 3912 Mb.
Total Memory : 9355 Mb.
Available Memory : 5948 Mb.
06 juuni 19:39:19 | Processor Intel(R) Pentium(R) CPU G3440 @ 3.30GHz with 16/8 core(s) CPU
Supported instruction set: MMX,sse,sse2,sse3,ssse3,sse41,sse42
06 juuni 19:39:19 | User OS: Windows 10 Enterprise, Microsoft Windows 10 Professional (Build 19041)
06 juuni 19:39:19 | VsoDownloader.exe:7464 Log session start 2020-06-06 at 19:39:19.515
Memory Load : 39%
Re-installed VSO downloader > now both drivers are available and working -
full log file in attachment -
but VSO downloader does not recognize videos opened in Slimjet.
Works good with Firefox, Chrome and Opera.
Thanks to moderator JJ I found that - I was initiating this download failure case - myself...
After reading post of moderator JJ - from Finland -
Re: Proxy maleware in vso downloader ?
Post by JJ » Sat Sep 22, 2018 1:29 pm
That is the way to capture streams, all traffic has to go thru the downloader.
Works just fine here.
I checked my Slimjet browser proxy settings > it was set to > Automatic Detect.
After I set it to > Use System Proxy ....
VSO Downloader started to download videos on Slimjet Browser!!! Problem solved!
But it could be useful to explain that > Use System Proxy requirement somewhere in usage note!
Just for comparison - VSO Downloader still worked with browsers Firefox, Chrome and OPera - set for Auto Detect...
For information, the needed 'use system proxy' is a global solution we found in order to improve the detection of HTTPS.
It works for all platforms (unlike driver solution) and needed a limited amount of work to implement.
