Find the Burn options confusing
Find the choices on the Burn options screen confusing.
Burn results to disk or as an ISO in the working folder....why have two options with a single tick box ?
Plus there is a tick box “add iso file destination to drive list” ?
Would be much simpler to have a simple set of tick boxes...
1-Burn directly to a DVD ( would issue an immediate warning & not proceed, if there was no dvd in the drive )
2-Create an ISO image in the working folder
3-Create a Video TS folder in the working folder
This would be much simpler, All 3 could be selected, or Just 1....again the program would issue a warning if no selection was made & not proceed....
I converted a single film last night, it got 75% of the way through the bar creating an ISO image then stopped and didn’t shutdown the PC, also the video TS folder although appeared complete was unplayable,
Tried again, ticked top box burn or write, chose iso folder option plus add iso to drive list....
Added only a single 2 minute video to test.....again got stuck around 80% No ISO created but TS folder did play ok
Re: Find the Burn options confusing
Hello ArthurDent2020,
You are absolutely right, the current interface & menu are confusing.
We are currently working on the 64bit versions (4K, 265x, 10/12b) but as soon as this huge piece of work is over, we jump on the new interface of the converters.
Regarding the iso, we currently have an issue (not starting automatically, need to reselect iso).
That’s good to hear
That’s good to hear
