Hello Maggie,
I have installed the latest version of convertxtodvd 7.
Now I can't disable subtitels ( I want start the titles without subs)
When I make project with some titles I want to disabel the subs.
There was never a problem, but now I make the right settings to disabel the subs, the subs are still appear when I play the DVD
Can you look at it for me.
Thank you
Gr. Bert
Can't disable subtitles
Re: Can't disable subtitles
So, you're saying when you start playing a ConvertXToDVD disc, subtitles are automatically turned on and you don't want that behavior? Try and see if this setting is enabled and, if it is, disable it.
Default Settings --> Subtitles --> Always display a subtitle track on playback
If that boxed is checked, and it is checked by default settings from installing CXD, uncheck the box and see if that helps.
Thank you for your reply.
I have uncheck the box like you said, but the subs still appear.
I have burned the DVD and play it on my standalone DVD player.
The subtitles did'nt appear. That's just wat I want.
So I think this is more a Power DVD problem.
I use Power DVD to Check the VIDEO_TS file before I burn it on a disc.
PowerDVD might have an option like MPC-HC. By default, subtitles are turned on for DVD on playback, but you can turn this off. When you disable the subtitles, it turns it off across the board.
