Hello is this still possible ? or must they be uploaded to an image hosting site the the URl PASTED ?
adding images to posts
Re: adding images to posts
If I remember well, it depends of your group.
I think moderator can without hosting...
Hosting should work for you!
Such a pain....be so much easier to browse for am image and attach it...
I understand your frustration, I think it was a protection for the forum. (not sure about it, will investigate
In the meantime (Jacques is very (VERY) busy at the moment), you can use something like https://www.flickr.com maybe?
Hi that’s what I used thanks, maybe saves on space on your server, as you don’t have to host the images, but don’t suppose you get many images anyway. Just be easier for everyone.....best wishes, keep safe.... :lol:
