ust a quick note of my experience.
I use Ver 7.0.0.40 and it works perfectly
When Ver 7.0.0.52 was released I installed it. It failed every single time (conversion failed error) so I went back to 40
I saw Ver 7.0.0.56 was released in Beta so I installed it thinking 52 problem would be solved; but never got to see if it did.
When I add a video to be converted, it takes over 5 minutes to load the file (v 40 takes less then 5 seconds) and then the program locks when I click "convert"
....so I'm back to Ver 7.0.0.40
Ver 7.0.0.56 (and v.52)
Re: Ver 7.0.0.56 (and v.52)
New builds are meant to solve bug problems. But could possibly create other bugs since not all computer structures are the same.
Better stick to the application build that works best on your PC.
As for myself the most recent build which works best on my PC is version 7.0.0.61. With the more recent I get menu problems.
It is going to take a very long time, if ever, to get the bugs sorted out.
