Subtitle help
Subtitle help
Any solution for this alphabet change?please help
Re: Subtitle help
But this subtitle works fine in km player in PC and android mx player.
Re: Subtitle help
What is exactly the problem?
You have wrong character encoding in subtitle settings?
Re: Subtitle help
Yes sir.thanks for your helpJJ wrote: Thu Aug 20, 2020 2:58 am What is exactly the problem?
Re: Subtitle help
All settings give the same effect sirJJ wrote: Thu Aug 20, 2020 2:58 am What is exactly the problem?
Re: Subtitle help
VLC media player also show like this. wondershare dvd creator show correctly but there's only hard encoding option.
Re: Subtitle help
viewtopic.php?f=23&t=17588 I hv tried this too
Re: Subtitle help
Anyway to add more encoding pages?
I m from India.my language is Tamil.i think Code page 57004 (ISCII-Tamil) may be work.
Re: Subtitle help
Hi vvijay,
Would it be possible for you to send me a Tamil subtitle file at support@vsosoftware.fr?
Re: Subtitle help
Any solution sir?
Re: Subtitle help
Are you saying that only problem is subtitle being divided to three rows instead of two or even one?
Re: Subtitle help
No sir.check attachment picture Bottom are correct but in video preview characters are not in correct orderJJ wrote: Wed Sep 02, 2020 3:57 am Are you saying that only problem is subtitle being divided to three rows instead of two or even one?
Re: Subtitle help
Wrong characters in video preview marked with yellow colour sir
Re: Subtitle help
Ok, thanks for all the info!
Just to be sure I understand, the result after conversion is correct with some players (MX...) ?
Re: Subtitle help
No sir.its also show sameMaggie wrote: Wed Sep 02, 2020 9:04 am Ok, thanks for all the info!
