Some Films Don't Work Why????
I was wondering if there was a reason for this
Anytime I burn a Blu-ray some films are unwatchable. They are totally jittery and glitchy - and in no way watchable. They are 'slightly' messed up.
If I try again the same films won't work.
Why?
The files play perfectly on the PC.
This is the most recent Blu-ray attempt
These files worked: Eurovision, Buffaloed, The Wrong Missy, The Favourite, The Souvenir, Jay & Silent Bob Reboot
These files DID NOT: Resistance, Spenser, Jay & Silent Bob Strike Back
Is there a reason?
Is there a fix?
Thanks for any help.
Here is the log file [and note this happens on all Blu-rays I burn that some films don't seem to work]
:std_log='C:\Users\inkey\AppData\Roaming\VSO\ConvertXtoHD\3\Log\ConvertXtoHD 3_mainlog.20201012.112136.642.log'
:library=false
:app_name=ConvertXToHD.exe
:app_version=3.0.0.71
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
10:19:08.442 Info Total size 32227 Mb., Target size Custom 46000 Mb., Occupation 70.06%
10:52:12.666 Info Disc name: "Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG"
10:19:08.755 Info Burned folder: "C:\Users\inkey\Documents\ConvertXtoHD\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG", Min. media size 31.5 GB.
10:19:08.435 Info Conversion completed in 02:18:28
10:19:03.720 Info "TITLE 2/2 (Global 2/2)" menu built successfully
10:18:32.748 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
10:18:32.593 Info "TITLE 1/2 (Global 1/2)" menu built successfully
10:17:34.434 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
10:17:34.039 Important Starting BD title menus encoding: [Memory load 38%] [Available virtual memory 1760 Mb.]
10:17:34.036 Info Building TITLE menu
08:00:40.068 Info [ ] Loop playback
08:00:40.066 Info [ ] Play titles one after the other
08:00:40.065 Info [ ] Don't create title menu for single video
08:00:40.064 Info [x] Return to title menu after titleset playback
08:00:40.063 Info [x] Skip root menu initially
08:00:40.062 Info [ ] Auto-start playback
08:00:40.061 Info Template: Metallic (open style), contains 4 page(s)
08:00:40.061 Group Blu-ray/AVCHD menu options
08:00:40.060 Info Output target size : BD-50 (46000 MB)
08:00:40.059 Info Number of core(s) used for encoding : 16
08:00:40.058 Info Number of core(s) used for decoding : 16
08:00:40.057 Info [ ] Use 2 pass encoding
08:00:40.056 Info [ ] Use best video quality settings
08:00:40.055 Info [x] Use hardware encoding (if possible)
08:00:40.054 Info [x] Use hardware decoding (if possible)
08:00:40.053 Info Max simultaneous conversions: 4
08:00:40.052 Group Advanced encoding options
10:17:29.022 ------------ *****************************************File encoded successfully: 00008.m2ts******************************************
10:17:29.019 Info "SETTINGS 1/1 (Global 5/5)" menu built successfully
10:17:20.346 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
10:17:20.264 Info "CHAPTERS 3/3 (Global 4/5)" menu built successfully
10:16:45.856 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
10:16:43.008 Info "CHAPTERS 2/3 (Global 3/5)" menu built successfully
10:15:53.597 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
10:15:44.967 Info "CHAPTERS 1/3 (Global 2/5)" menu built successfully
10:15:03.265 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
10:15:02.569 Info "ROOT 1/1 (Global 1/5)" menu built successfully
10:14:35.725 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
10:14:33.330 Important Starting BD root menu encoding: [Memory load 39%] [Available virtual memory 1760 Mb.]
10:14:33.328 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Metallic (open style)
10:14:33.267 Info subtitle #3 - Encoded subtitles frames: 3937
10:14:33.265 Info video #1 - Processed video frames: 151513 (151513 frames encoded, 0 frames dropped, 0 frames duplicated)
09:45:51.669 Info H264 settings for stream #1: preset=superfast,qmin=-1,lmin=354,mblmin=354,b=5100000,bt=50M,maxrate=20000000,minrate=0,me_method=epzs,codec=h264_nvenc,width=1280,height=720,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=4,h264_level=4.1,bufsize=15000000,rc_init_occupancy=15000000,slices=4,language=en,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,gpu_id=0,qmax=-1,pass_number=1,threads=16
09:45:51.666 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [English] (Default)]
+-[subtitle #1 - hdmv_pgs_subtitle subtitle]
+--> [audio #2 - ac3 audio, 48000Hz, 5.1 Ch., 640000 bps [English]]
+-[audio [eng] DTS HD-Master main audio 6 Ch. 48000Hz ]
+--> [video #1 - h264_nvenc video, 1280x720, yuv420p, 16x9, 23.98Fps, 5100Kbps]
+-[video [eng] hevc 1920x800 12:5 yuv420p10le, 23.98Fps, 0Kbps ]
Output file: C:\Users\inkey\Documents\ConvertXtoHD\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG\BDMV\STREAM\00008.m2ts (Blu-ray)
Input file: D:\VUZE downloads\Jay.and.Silent.Bob.Reboot.2019.1080p.Blu-ray.DTS-HD.MA.5.1.HEVC-DDR[EtHD]\Jay.and.Silent.Bob.Reboot.2019.1080p.Blu-ray.DTS-HD.MA.5.1.HEVC-DDR[EtHD].mkv
Video filters used:
- DeInterlace filter: VSO
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: letterbox (Padding: top: 94, bottom: 94, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
09:45:51.664 Info Chapters to generate: 16 (0h00m00s, 0h03m38s, 0h09m30s, 0h16m32s, 0h24m10s, 0h30m43s, 0h40m34s, 0h44m53s, 0h48m46s, 0h54m34s, 0h59m26s, 1h07m03s, 1h10m01s, 1h16m08s, 1h25m37s, 1h32m39s, )
09:45:51.662 Important Starting video encoding: [Memory load 39%] [Available virtual memory 1304 Mb.]
09:45:51.598 Verbose FFmpeg Opening file D:\VUZE downloads\Jay.and.Silent.Bob.Reboot.2019.1080p.Blu-ray.DTS-HD.MA.5.1.HEVC-DDR[EtHD]\Jay.and.Silent.Bob.Reboot.2019.1080p.Blu-ray.DTS-HD.MA.5.1.HEVC-DDR[EtHD].mkv
08:00:40.014 Info Menu fit: Text size reduced from 13.00 to 13.00 in style "Captions in title menu pages"
^^^Repeated 6 Times in 32 millisecond(s)^^^
08:00:40.007 Warning Reached font size limit, text truncated from "Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG" to "Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x26"
08:00:40.006 Info Menu fit: Text size reduced from 27.00 to 13.00 in style "Captions in title menu pages"
08:00:39.861 Info Menu fit: Text size reduced from 36.00 to 14.00 in style "Title of title menu pages"
08:00:38.328 Verbose FFmpeg Opening file D:\VUZE downloads\Jay.and.Silent.Bob.Reboot.2019.1080p.Blu-ray.DTS-HD.MA.5.1.HEVC-DDR[EtHD]\Jay.and.Silent.Bob.Reboot.2019.1080p.Blu-ray.DTS-HD.MA.5.1.HEVC-DDR[EtHD].mkv
08:00:38.327 Group ******************** Titleset #9 - ~105 min. File: "Jay.and.Silent.Bob.Reboot.2019.1080p.Blu-ray.DTS-HD.MA.5.1.HEVC-DDR[EtHD]" -> 00008.m2ts - Blu-ray ********************|GK_TITLESET|
09:44:48.001 ------------ *****************************************File encoded successfully: 00007.m2ts******************************************
09:44:47.995 Info "SETTINGS 1/1 (Global 6/6)" menu built successfully
09:44:39.314 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
09:44:39.233 Info "CHAPTERS 4/4 (Global 5/6)" menu built successfully
09:44:22.166 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
09:44:19.955 Info "CHAPTERS 3/4 (Global 4/6)" menu built successfully
09:43:54.068 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
09:43:52.224 Info "CHAPTERS 2/4 (Global 3/6)" menu built successfully
09:43:24.980 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
09:43:22.064 Info "CHAPTERS 1/4 (Global 2/6)" menu built successfully
09:42:54.349 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
09:42:49.393 Info "ROOT 1/1 (Global 1/6)" menu built successfully
09:42:33.093 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
09:42:29.739 Important Starting BD root menu encoding: [Memory load 40%] [Available virtual memory 1088 Mb.]
09:42:29.737 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Metallic (open style)
09:42:29.584 Info subtitle #3 - Encoded subtitles frames: 4394
09:42:29.580 Info video #1 - Processed video frames: 150264 (150263 frames encoded, 0 frames dropped, 0 frames duplicated)
09:23:57.020 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [English] (Default)]
+-[subtitle #3 - ass subtitle]
+--> [audio #2 - ac3 audio, 48000Hz, Stereo, 224000 bps [English]]
+-[audio [eng] vorbis main audio 2 Ch. 48000Hz ]
+--> [video #1 - h264_opencl video, 1280x720, yuv420p, 16x9, 23.98Fps, 5100Kbps]
+-[video [eng] h264 1920x816 40:17 yuv420p, 23.98Fps, 0Kbps ]
Output file: C:\Users\inkey\Documents\ConvertXtoHD\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG\BDMV\STREAM\00007.m2ts (Blu-ray)
Input file: D:\VUZE downloads\Jay.and.Silent.Bob.Strike.Back.2001.BluRay.1080p.x264.AC3-5.1-iLL\Jay.and.Silent.Bob.Strike.Back.2001.BluRay.1080p.x264.AC3-5.1iLL.mkv
Video filters used:
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: letterbox (Padding: top: 88, bottom: 88, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
09:23:57.018 Info Chapters to generate: 21 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, 0h55m00s, 1h00m00s, 1h05m00s, 1h10m00s, 1h15m00s, 1h20m00s, 1h25m00s, 1h30m00s, 1h35m00s, 1h40m00s, )
09:23:57.014 Important Starting video encoding: [Memory load 40%] [Available virtual memory 1449 Mb.]
09:23:56.828 Verbose FFmpeg Opening file D:\VUZE downloads\Jay.and.Silent.Bob.Strike.Back.2001.BluRay.1080p.x264.AC3-5.1-iLL\Jay.and.Silent.Bob.Strike.Back.2001.BluRay.1080p.x264.AC3-5.1iLL.mkv
08:00:38.162 Verbose FFmpeg Opening file D:\VUZE downloads\Jay.and.Silent.Bob.Strike.Back.2001.BluRay.1080p.x264.AC3-5.1-iLL\Jay.and.Silent.Bob.Strike.Back.2001.BluRay.1080p.x264.AC3-5.1iLL.mkv
08:00:38.161 Group ******************** Titleset #8 - ~104 min. File: "Jay.and.Silent.Bob.Strike.Back.2001.BluRay.1080p.x264.AC3-5.1iLL" -> 00007.m2ts - Blu-ray ********************|GK_TITLESET|
09:53:00.491 ------------ *****************************************File encoded successfully: 00006.m2ts******************************************
09:53:00.487 Info "SETTINGS 1/1 (Global 5/5)" menu built successfully
09:52:36.809 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
09:52:36.704 Info "CHAPTERS 3/3 (Global 4/5)" menu built successfully
09:51:32.751 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
09:51:31.954 Info "CHAPTERS 2/3 (Global 3/5)" menu built successfully
09:50:12.340 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
09:50:09.672 Info "CHAPTERS 1/3 (Global 2/5)" menu built successfully
09:48:53.345 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
09:48:51.470 Info "ROOT 1/1 (Global 1/5)" menu built successfully
09:48:11.709 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
09:48:08.920 Important Starting BD root menu encoding: [Memory load 40%] [Available virtual memory 1249 Mb.]
09:48:08.916 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Metallic (open style)
09:48:08.841 Info subtitle #4 - Encoded subtitles frames: 2857
09:48:08.837 Info subtitle #3 - Encoded subtitles frames: 2563
09:48:08.833 Info video #1 - Processed video frames: 172321 (172321 frames encoded, 0 frames dropped, 0 frames duplicated)
09:45:20.066 Important Resuming paused task
09:42:55.393 Important Pausing task because memory is runnng low
09:23:52.081 Info H264 settings for stream #1: preset=superfast,qmin=-1,lmin=354,mblmin=354,b=5100000,bt=50M,maxrate=40000000,minrate=0,me_method=epzs,codec=h264_nvenc,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=4,h264_level=4.1,bufsize=30000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,gpu_id=0,qmax=-1,pass_number=1,threads=16
09:23:52.079 ------------ +--> [subtitle #4 - hdmv_pgs_subtitle subtitle, 1920x1080 [English]]
+-[subtitle #3 - subrip subtitle]
+-[subtitle #2 - subrip subtitle]
+-[audio [eng] dts main audio 6 Ch. 48000Hz , 1536 Kbps]
+--> [video #1 - h264_nvenc video, 1920x1080, yuv420p, 16x9, 23.98Fps, 5100Kbps]
+-[video dxva2 h264 1808x1080 226:135 dxva2_vld, 23.98Fps, 0Kbps ]
Output file: C:\Users\inkey\Documents\ConvertXtoHD\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG\BDMV\STREAM\00006.m2ts (Blu-ray)
Input file: D:\VUZE downloads\The.Souvenir.2019.1080p.BluRay.X264-AMIABLE[EtHD]\The.Souvenir.2019.1080p.BluRay.X264-AMIABLE[EtHD].mkv
Video filters used:
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: letterbox (Padding: top: 0, bottom: 0, left: 56, right: 56. Cropping: top: 0, bottom: 0, left: 0, right: 0)
09:23:52.077 Info Chapters to generate: 16 (0h00m00s, 0h06m49s, 0h13m51s, 0h26m13s, 0h29m55s, 0h37m30s, 0h45m39s, 0h52m25s, 1h00m26s, 1h07m22s, 1h15m17s, 1h23m06s, 1h32m12s, 1h40m58s, 1h45m06s, 1h52m52s, )
09:23:52.075 Important Starting video encoding: [Memory load 38%] [Available virtual memory 1902 Mb.]
09:23:52.042 Info Hardware decoding: H.264 variable-length decoder, no film grain technology using Adapter #0 - NVIDIA GeForce RTX 2070 SUPER, converting h264 to yuv420p
09:23:51.976 Verbose FFmpeg Opening file D:\VUZE downloads\The.Souvenir.2019.1080p.BluRay.X264-AMIABLE[EtHD]\The.Souvenir.2019.1080p.BluRay.X264-AMIABLE[EtHD].mkv
08:00:38.022 Verbose FFmpeg Opening file D:\VUZE downloads\The.Souvenir.2019.1080p.BluRay.X264-AMIABLE[EtHD]\The.Souvenir.2019.1080p.BluRay.X264-AMIABLE[EtHD].mkv
08:00:38.021 Group ******************** Titleset #7 - ~119 min. File: "The.Souvenir.2019.1080p.BluRay.X264-AMIABLE[EtHD]" -> 00006.m2ts - Blu-ray ********************|GK_TITLESET|
09:45:44.324 ------------ *****************************************File encoded successfully: 00005.m2ts******************************************
09:45:44.318 Info "CHAPTERS 2/2 (Global 3/3)" menu built successfully
09:45:20.147 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
09:45:20.017 Info "CHAPTERS 1/2 (Global 2/3)" menu built successfully
09:44:48.685 Important Resuming paused task
09:42:55.406 Important Pausing task because memory is runnng low
09:42:40.496 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
09:42:39.667 Info "ROOT 1/1 (Global 1/3)" menu built successfully
09:42:09.760 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
09:42:08.465 Important Starting BD root menu encoding: [Memory load 41%] [Available virtual memory 1028 Mb.]
09:42:08.461 Info Building ROOT, CHAPTERS, menus using template: Metallic (open style)
09:42:08.415 Info video #1 - Processed video frames: 171888 (171888 frames encoded, 0 frames dropped, 0 frames duplicated)
09:23:47.287 Info H264 settings for stream #1: preset=superfast,qmin=-1,lmin=354,mblmin=354,b=5100000,bt=50M,maxrate=40000000,minrate=0,me_method=epzs,codec=h264_nvenc,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=4,h264_level=4.1,bufsize=30000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,gpu_id=0,qmax=-1,pass_number=1,threads=16
09:23:47.285 ------------ +--> [audio #2 - ac3 audio, 48000Hz, 5.1 Ch., 640000 bps [English]]
+-[video dxva2 h264 1920x1040 24:13 dxva2_vld, 23.98Fps, 0Kbps ]
Output file: C:\Users\inkey\Documents\ConvertXtoHD\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG\BDMV\STREAM\00005.m2ts (Blu-ray)
Input file: D:\VUZE downloads\The.Favourite.2018.1080p.BluRay.x264-SPARKS[EtHD]\the.favourite.2018.1080p.bluray.x264-sparks[EtHD].mkv
Video filters used:
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: letterbox (Padding: top: 20, bottom: 20, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
09:23:47.283 Info Chapters to generate: 8 (0h00m00s, 0h18m36s, 0h40m35s, 0h46m44s, 1h06m23s, 1h15m12s, 1h28m32s, 1h36m55s, )
09:23:47.282 Important Starting video encoding: [Memory load 37%] [Available virtual memory 2178 Mb.]
09:23:47.252 Info Hardware decoding: H.264 variable-length decoder, no film grain technology using Adapter #0 - NVIDIA GeForce RTX 2070 SUPER, converting h264 to yuv420p
09:23:47.150 Verbose FFmpeg Opening file D:\VUZE downloads\The.Favourite.2018.1080p.BluRay.x264-SPARKS[EtHD]\the.favourite.2018.1080p.bluray.x264-sparks[EtHD].mkv
08:00:37.911 Verbose FFmpeg Opening file D:\VUZE downloads\The.Favourite.2018.1080p.BluRay.x264-SPARKS[EtHD]\the.favourite.2018.1080p.bluray.x264-sparks[EtHD].mkv
08:00:37.911 Group ******************** Titleset #6 - ~119 min. File: "the.favourite.2018.1080p.bluray.x264-sparks[EtHD]" -> 00005.m2ts - Blu-ray ********************|GK_TITLESET|
09:23:40.496 ------------ *****************************************File encoded successfully: 00004.m2ts******************************************
09:23:40.491 Info "CHAPTERS 3/3 (Global 4/4)" menu built successfully
09:19:54.399 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
09:19:17.546 Info "CHAPTERS 2/3 (Global 3/4)" menu built successfully
09:15:17.739 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
09:14:32.575 Info "CHAPTERS 1/3 (Global 2/4)" menu built successfully
09:10:55.681 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
09:10:12.657 Info "ROOT 1/1 (Global 1/4)" menu built successfully
09:09:17.654 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
09:09:09.210 Important Starting BD root menu encoding: [Memory load 38%] [Available virtual memory 2246 Mb.]
09:09:09.208 Info Building ROOT, CHAPTERS, menus using template: Metallic (open style)
09:09:09.133 Info video #1 - Processed video frames: 128336 (128336 frames encoded, 0 frames dropped, 0 frames duplicated)
08:37:19.623 Info H264 settings for stream #1: preset=superfast,qmin=-1,lmin=354,mblmin=354,b=5100000,bt=50M,maxrate=40000000,minrate=0,me_method=epzs,codec=h264_nvenc,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1/24,bf=3,refs=4,h264_level=4.1,bufsize=30000000,rc_init_occupancy=20000000,slices=4,language=en,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,gpu_id=0,qmax=-1,pass_number=1,threads=16
08:37:19.621 ------------ +--> [audio #2 - ac3 audio, 48000Hz, 5.1 Ch., 640000 bps [English]]
+-[audio [eng] eac3 main audio 6 Ch. 48000Hz , 640 Kbps]
+--> [video #1 - h264_nvenc video, 1920x1080, yuv420p, 16x9, 24.00Fps, 5100Kbps]
+-[video [eng] hevc 3840x1600 12:5 yuv420p10le, 24.00Fps, 0Kbps ]
Output file: C:\Users\inkey\Documents\ConvertXtoHD\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG\BDMV\STREAM\00004.m2ts (Blu-ray)
Input file: D:\VUZE downloads\The.Wrong.Missy.2020.UHD.MULTI.2160p.HDR.WEBRip.DDP.5.1.HEVC-DDR[EtHD]\The.Wrong.Missy.2020.UHD.MULTI.2160p.HDR.WEBRip.DDP.5.1.HEVC-DDR[EtHD].mkv
Video filters used:
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: letterbox (Padding: top: 140, bottom: 140, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
08:37:19.619 Info Chapters to generate: 19 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, 0h55m00s, 1h00m00s, 1h05m00s, 1h10m00s, 1h15m00s, 1h20m00s, 1h25m00s, 1h30m00s, )
08:37:19.618 Important Starting video encoding: [Memory load 38%] [Available virtual memory 1691 Mb.]
08:37:19.432 Verbose FFmpeg Opening file D:\VUZE downloads\The.Wrong.Missy.2020.UHD.MULTI.2160p.HDR.WEBRip.DDP.5.1.HEVC-DDR[EtHD]\The.Wrong.Missy.2020.UHD.MULTI.2160p.HDR.WEBRip.DDP.5.1.HEVC-DDR[EtHD].mkv
08:00:37.768 Verbose FFmpeg Opening file D:\VUZE downloads\The.Wrong.Missy.2020.UHD.MULTI.2160p.HDR.WEBRip.DDP.5.1.HEVC-DDR[EtHD]\The.Wrong.Missy.2020.UHD.MULTI.2160p.HDR.WEBRip.DDP.5.1.HEVC-DDR[EtHD].mkv
08:00:37.767 Group ******************** Titleset #5 - ~90 min. File: "The.Wrong.Missy.2020.UHD.MULTI.2160p.HDR.WEBRip.DDP.5.1.HEVC-DDR[EtHD]" -> 00004.m2ts - Blu-ray ********************|GK_TITLESET|
08:34:39.054 ------------ *****************************************File encoded successfully: 00003.m2ts******************************************
08:34:39.050 Info "CHAPTERS 4/4 (Global 5/5)" menu built successfully
08:33:49.838 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:33:49.561 Info "CHAPTERS 3/4 (Global 4/5)" menu built successfully
08:32:50.690 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:32:50.354 Info "CHAPTERS 2/4 (Global 3/5)" menu built successfully
08:31:47.329 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:31:46.386 Info "CHAPTERS 1/4 (Global 2/5)" menu built successfully
08:30:42.622 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:30:41.382 Info "ROOT 1/1 (Global 1/5)" menu built successfully
08:30:10.976 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:30:09.790 Important Starting BD root menu encoding: [Memory load 37%] [Available virtual memory 1891 Mb.]
08:30:09.789 Info Building ROOT, CHAPTERS, menus using template: Metallic (open style)
08:30:09.711 Info video #1 - Processed video frames: 160090 (160089 frames encoded, 0 frames dropped, 0 frames duplicated)
08:22:53.674 Important Resuming paused task
08:18:21.090 Important Pausing task because memory is runnng low
08:00:54.713 ------------ +--> [audio #2 - ac3 audio, 48000Hz, 5.1 Ch., 640000 bps [English]]
+-[audio [eng] ac3 main audio 6 Ch. 48000Hz , 384 Kbps]
+--> [video #1 - h264_opencl video, 1920x1080, yuv420p, 16x9, 24.00Fps, 5100Kbps]
+-[video h264 1920x1080 16:9 yuv420p, 24.00Fps, 0Kbps ]
Output file: C:\Users\inkey\Documents\ConvertXtoHD\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG\BDMV\STREAM\00003.m2ts (Blu-ray)
Input file: D:\VUZE downloads\Spenser.Confidential.2020.1080p.NF.WEB-DL.DDP5.1.X264-EVO[TGx]\Spenser.Confidential.2020.1080p.NF.WEB-DL.DDP5.1.X264-EVO.mkv
Video filters used:
08:00:54.711 Info Chapters to generate: 23 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, 0h55m00s, 1h00m00s, 1h05m00s, 1h10m00s, 1h15m00s, 1h20m00s, 1h25m00s, 1h30m00s, 1h35m00s, 1h40m00s, 1h45m00s, 1h50m00s, )
Why?
Is there a reason?
Is there a fix?
:library=false
:most_recent=first
:status=started
:group_indent=4
Video filters used:
Video filters used:
Video filters used:
Video filters used:
Video filters used:
Video filters used:
Re: Some Films Don't Work Why????
08:00:54.708 Important Starting video encoding: [Memory load 38%] [Available virtual memory 1898 Mb.]
08:00:54.648 Verbose FFmpeg Opening file D:\VUZE downloads\Spenser.Confidential.2020.1080p.NF.WEB-DL.DDP5.1.X264-EVO[TGx]\Spenser.Confidential.2020.1080p.NF.WEB-DL.DDP5.1.X264-EVO.mkv
08:00:37.608 Verbose FFmpeg Opening file D:\VUZE downloads\Spenser.Confidential.2020.1080p.NF.WEB-DL.DDP5.1.X264-EVO[TGx]\Spenser.Confidential.2020.1080p.NF.WEB-DL.DDP5.1.X264-EVO.mkv
08:00:37.607 Group ******************** Titleset #4 - ~111 min. File: "Spenser.Confidential.2020.1080p.NF.WEB-DL.DDP5.1.X264-EVO" -> 00003.m2ts - Blu-ray ********************|GK_TITLESET|
08:37:12.622 ------------ *****************************************File encoded successfully: 00002.m2ts******************************************
08:37:12.620 Info "SETTINGS 1/1 (Global 4/4)" menu built successfully
08:37:04.059 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:37:03.972 Info "CHAPTERS 2/2 (Global 3/4)" menu built successfully
08:36:38.090 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:36:35.205 Info "CHAPTERS 1/2 (Global 2/4)" menu built successfully
08:36:05.223 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:35:59.433 Info "ROOT 1/1 (Global 1/4)" menu built successfully
08:35:44.008 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:35:41.868 Important Starting BD root menu encoding: [Memory load 37%] [Available virtual memory 2245 Mb.]
08:35:41.867 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Metallic (open style)
08:35:41.821 Info subtitle #3 - Encoded subtitles frames: 1839
08:35:41.819 Info video #1 - Processed video frames: 174555 (174554 frames encoded, 0 frames dropped, 0 frames duplicated)
08:22:52.465 Important Resuming paused task
08:18:21.081 Important Pausing task because memory is runnng low
08:00:49.815 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [English] (Default)]
+-[subtitle #2 - hdmv_pgs_subtitle subtitle]
+-[video h264 1920x802 79:33 yuv420p, 23.98Fps, 0Kbps ]
Output file: C:\Users\inkey\Documents\ConvertXtoHD\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG\BDMV\STREAM\00002.m2ts (Blu-ray)
Input file: D:\VUZE downloads\Resistance.2020.1080p.BluRay.x264-GECKOS[TGx]\resistance.2020.1080p.bluray.x264-geckos.mkv
Video filters used:
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: letterbox (Padding: top: 92, bottom: 92, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
08:00:49.811 Info Chapters to generate: 12 (0h00m00s, 0h10m10s, 0h22m19s, 0h32m50s, 0h40m27s, 0h51m29s, 1h00m17s, 1h12m19s, 1h21m58s, 1h33m52s, 1h46m57s, 1h55m20s, )
08:00:49.807 Important Starting video encoding: [Memory load 37%] [Available virtual memory 2292 Mb.]
08:00:49.764 Verbose FFmpeg Opening file D:\VUZE downloads\Resistance.2020.1080p.BluRay.x264-GECKOS[TGx]\resistance.2020.1080p.bluray.x264-geckos.mkv
08:00:37.485 Verbose FFmpeg Opening file D:\VUZE downloads\Resistance.2020.1080p.BluRay.x264-GECKOS[TGx]\resistance.2020.1080p.bluray.x264-geckos.mkv
08:00:37.484 Group ******************** Titleset #3 - ~121 min. File: "resistance.2020.1080p.bluray.x264-geckos" -> 00002.m2ts - Blu-ray ********************|GK_TITLESET|
08:25:48.926 ------------ *****************************************File encoded successfully: 00001.m2ts******************************************
08:25:48.923 Info "SETTINGS 1/1 (Global 6/6)" menu built successfully
08:25:22.665 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:25:22.550 Info "CHAPTERS 4/4 (Global 5/6)" menu built successfully
08:24:52.144 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:24:51.997 Info "CHAPTERS 3/4 (Global 4/6)" menu built successfully
08:24:13.520 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:24:12.212 Info "CHAPTERS 2/4 (Global 3/6)" menu built successfully
08:23:32.688 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:23:31.386 Info "CHAPTERS 1/4 (Global 2/6)" menu built successfully
08:22:53.830 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:22:52.568 Info "ROOT 1/1 (Global 1/6)" menu built successfully
08:22:41.312 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:22:40.880 Important Starting BD root menu encoding: [Memory load 40%] [Available virtual memory 1213 Mb.]
08:22:40.879 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Metallic (open style)
08:22:40.811 Info subtitle #3 - Encoded subtitles frames: 4179
08:22:40.809 Info video #1 - Processed video frames: 136680 (136680 frames encoded, 0 frames dropped, 0 frames duplicated)
08:22:18.714 Important Resuming paused task
08:18:21.062 Important Pausing task because memory is runnng low
08:00:44.986 Info H264 settings for stream #1: preset=superfast,qmin=-1,lmin=354,mblmin=354,b=5100000,bt=50M,maxrate=20000000,minrate=0,me_method=epzs,codec=h264_nvenc,width=1280,height=720,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=4,h264_level=4.1,bufsize=15000000,rc_init_occupancy=15000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,gpu_id=0,qmax=-1,pass_number=1,threads=8
08:00:44.984 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [English] (Default)]
+-[audio [eng] aac main audio 2 Ch. 48000Hz ]
+-[video dxva2 h264 1280x528 12:5 dxva2_vld, 23.98Fps, 0Kbps ]
Output file: C:\Users\inkey\Documents\ConvertXtoHD\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG\BDMV\STREAM\00001.m2ts (Blu-ray)
Input file: D:\VUZE downloads\Buffaloed.2019.720p.AMZN.WEBRip.800MB.x264-GalaxyRG[TGx]\Buffaloed.2019.720p.AMZN.WEBRip.800MB.x264-GalaxyRG.mkv
Video filters used:
08:00:44.983 Info Chapters to generate: 20 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, 0h55m00s, 1h00m00s, 1h05m00s, 1h10m00s, 1h15m00s, 1h20m00s, 1h25m00s, 1h30m00s, 1h35m00s, )
08:00:44.982 Important Starting video encoding: [Memory load 36%] [Available virtual memory 2737 Mb.]
08:00:44.956 Info Hardware decoding: H.264 variable-length decoder, no film grain technology using Adapter #0 - NVIDIA GeForce RTX 2070 SUPER, converting h264 to yuv420p
08:00:44.911 Verbose FFmpeg Opening file D:\VUZE downloads\Buffaloed.2019.720p.AMZN.WEBRip.800MB.x264-GalaxyRG[TGx]\Buffaloed.2019.720p.AMZN.WEBRip.800MB.x264-GalaxyRG.mkv
08:00:37.337 Verbose FFmpeg Opening file D:\VUZE downloads\Buffaloed.2019.720p.AMZN.WEBRip.800MB.x264-GalaxyRG[TGx]\Buffaloed.2019.720p.AMZN.WEBRip.800MB.x264-GalaxyRG.mkv
08:00:37.336 Group ******************** Titleset #2 - ~95 min. File: "Buffaloed.2019..x264-GalaxyRG" -> 00001.m2ts - Blu-ray ********************|GK_TITLESET|
08:22:17.632 ------------ *****************************************File encoded successfully: 00000.m2ts******************************************
08:22:17.625 Info "SETTINGS 1/1 (Global 7/7)" menu built successfully
08:22:00.643 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:22:00.540 Info "CHAPTERS 5/5 (Global 6/7)" menu built successfully
08:21:40.911 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:21:39.147 Info "CHAPTERS 4/5 (Global 5/7)" menu built successfully
08:20:58.748 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:20:48.378 Info "CHAPTERS 3/5 (Global 4/7)" menu built successfully
08:20:05.682 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:19:55.408 Info "CHAPTERS 2/5 (Global 3/7)" menu built successfully
08:19:12.934 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:19:02.323 Info "CHAPTERS 1/5 (Global 2/7)" menu built successfully
08:18:16.656 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:18:03.195 Info "ROOT 1/1 (Global 1/7)" menu built successfully
08:17:02.437 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
08:16:55.827 Important Starting BD root menu encoding: [Memory load 41%] [Available virtual memory 1039 Mb.]
08:16:55.825 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Metallic (open style)
08:16:55.186 Info subtitle #5 - Encoded subtitles frames: 3100
08:16:55.184 Info subtitle #4 - Encoded subtitles frames: 21
08:16:55.180 Info subtitle #3 - Encoded subtitles frames: 4565
08:16:55.179 Info video #1 - Processed video frames: 177957 (177957 frames encoded, 0 frames dropped, 0 frames duplicated)
08:00:41.786 Info H264 settings for stream #1: preset=superfast,qmin=-1,lmin=354,mblmin=354,b=5100000,bt=50M,maxrate=40000000,minrate=0,me_method=epzs,codec=h264_nvenc,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1/24,bf=3,refs=4,h264_level=4.1,bufsize=30000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,gpu_id=0,qmax=-1,pass_number=1,threads=8
08:00:41.785 ------------ +--> [subtitle #5 - hdmv_pgs_subtitle subtitle, 1920x1080 (Default)]
+-[subtitle #20 - subrip subtitle]
+--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [English]]
+-[video dxva2 h264 1920x1080 16:9 dxva2_vld, 24.00Fps, 0Kbps ]
Output file: C:\Users\inkey\Documents\ConvertXtoHD\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG\BDMV\STREAM\00000.m2ts (Blu-ray)
Input file: D:\VUZE downloads\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG[TGx]\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG.mkv
Video filters used:
08:00:41.784 Info Chapters to generate: 25 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, 0h55m00s, 1h00m00s, 1h05m00s, 1h10m00s, 1h15m00s, 1h20m00s, 1h25m00s, 1h30m00s, 1h35m00s, 1h40m00s, 1h45m00s, 1h50m00s, 1h55m00s, 2h00m00s, )
08:00:41.782 Important Starting video encoding: [Memory load 35%] [Available virtual memory 3082 Mb.]
08:00:40.137 Info Hardware decoding: H.264 variable-length decoder, no film grain technology using Adapter #0 - NVIDIA GeForce RTX 2070 SUPER, converting h264 to yuv420p
08:00:40.075 Verbose FFmpeg Opening file D:\VUZE downloads\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG[TGx]\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG.mkv
08:00:37.320 Info Menu fit: Text size reduced from 36.00 to 14.00 in style "Title of root menu pages"
08:00:35.460 Verbose FFmpeg Opening file D:\VUZE downloads\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG[TGx]\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG.mkv
08:00:35.459 Group ******************** Titleset #1 - ~123 min. File: "Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x26" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
08:00:35.453 Info Encoding options: Long Project (Automatic)
08:00:35.452 Info Target size: 46000 Mb.
08:00:35.450 Important Setting queuer for Blu-ray output: [Wait: 4000], [ld: 1000], [Hd: 10000], [MAM: 600], [RM: 500], [ALL: True]
08:00:35.449 Important Reduced simultaneous conversions to 4 because the output is a Blu-ray Full HD
08:00:35.448 Info Don't log FFMpeg log events
08:00:35.447 ------------ ***************************************************Burn settings end****************************************************
08:00:35.446 Info Default speed selected: 4x
08:00:35.445 Info [ ] Delete vsomsl files after burn complete
08:00:35.444 Info [ ] Delete output folder after burn complete
08:00:35.443 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
08:00:35.442 Info SAO setting: Automatic
08:00:35.441 Info [x] Burn result to disk / as ISO file in working folder
08:00:35.440 ------------ **************************************************Burn settings begin***************************************************
08:00:35.440 Group Encoding session started at 08:00:35: 9 titleset(s) to encode -> Completed in 02:18:28|GK_CONVERT_SESSION|
07:58:18.730 Info User requested cancellation
07:58:19.538 Info Conversion cancelled after 00:00:09
07:58:09.619 Info [ ] Loop playback
07:58:09.618 Info [ ] Play titles one after the other
07:58:09.618 Info [ ] Don't create title menu for single video
07:58:09.617 Info [x] Return to title menu after titleset playback
07:58:09.616 Info [x] Skip root menu initially
07:58:09.615 Info [ ] Auto-start playback
07:58:09.614 Info Template: Metallic (open style), contains 4 page(s)
07:58:09.614 Group Blu-ray/AVCHD menu options
07:58:09.614 Info Output target size : BD-50 (46000 MB)
07:58:09.613 Info Number of core(s) used for encoding : 16
07:58:09.612 Info Number of core(s) used for decoding : 16
07:58:09.611 Info [ ] Use 2 pass encoding
07:58:09.611 Info [ ] Use best video quality settings
07:58:09.610 Info [x] Use hardware encoding (if possible)
07:58:09.609 Info [x] Use hardware decoding (if possible)
07:58:09.608 Info Max simultaneous conversions: 4
07:58:09.608 Group Advanced encoding options
07:58:09.574 Info Menu fit: Text size reduced from 13.00 to 13.00 in style "Captions in title menu pages"
^^^Repeated 6 Times in 31 millisecond(s)^^^
07:58:09.567 Warning Reached font size limit, text truncated from "Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG" to "Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x26"
07:58:09.567 Info Menu fit: Text size reduced from 27.00 to 13.00 in style "Captions in title menu pages"
07:58:09.424 Info Menu fit: Text size reduced from 36.00 to 14.00 in style "Title of title menu pages"
07:58:07.888 Verbose FFmpeg Opening file D:\VUZE downloads\Jay.and.Silent.Bob.Reboot.2019.1080p.Blu-ray.DTS-HD.MA.5.1.HEVC-DDR[EtHD]\Jay.and.Silent.Bob.Reboot.2019.1080p.Blu-ray.DTS-HD.MA.5.1.HEVC-DDR[EtHD].mkv
07:58:07.720 Verbose FFmpeg Opening file D:\VUZE downloads\Jay.and.Silent.Bob.Strike.Back.2001.BluRay.1080p.x264.AC3-5.1-iLL\Jay.and.Silent.Bob.Strike.Back.2001.BluRay.1080p.x264.AC3-5.1iLL.mkv
07:58:07.569 Verbose FFmpeg Opening file D:\VUZE downloads\The.Souvenir.2019.1080p.BluRay.X264-AMIABLE[EtHD]\The.Souvenir.2019.1080p.BluRay.X264-AMIABLE[EtHD].mkv
07:58:07.460 Verbose FFmpeg Opening file D:\VUZE downloads\The.Favourite.2018.1080p.BluRay.x264-SPARKS[EtHD]\the.favourite.2018.1080p.bluray.x264-sparks[EtHD].mkv
07:58:07.310 Verbose FFmpeg Opening file D:\VUZE downloads\The.Wrong.Missy.2020.UHD.MULTI.2160p.HDR.WEBRip.DDP.5.1.HEVC-DDR[EtHD]\The.Wrong.Missy.2020.UHD.MULTI.2160p.HDR.WEBRip.DDP.5.1.HEVC-DDR[EtHD].mkv
07:58:07.146 Verbose FFmpeg Opening file D:\VUZE downloads\Spenser.Confidential.2020.1080p.NF.WEB-DL.DDP5.1.X264-EVO[TGx]\Spenser.Confidential.2020.1080p.NF.WEB-DL.DDP5.1.X264-EVO.mkv
07:58:07.019 Verbose FFmpeg Opening file D:\VUZE downloads\Resistance.2020.1080p.BluRay.x264-GECKOS[TGx]\resistance.2020.1080p.bluray.x264-geckos.mkv
07:58:19.009 Warning File encoding cancelled by user: 00001.m2ts - step preparing titles
07:58:14.563 Info H264 settings for stream #1: preset=superfast,qmin=-1,lmin=354,mblmin=354,b=5100000,bt=50M,maxrate=20000000,minrate=0,me_method=epzs,codec=h264_nvenc,width=1280,height=720,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=4,h264_level=4.1,bufsize=15000000,rc_init_occupancy=15000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,gpu_id=0,qmax=-1,pass_number=1,threads=8
07:58:14.562 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [English] (Default)]
Video filters used:
07:58:14.559 Info Chapters to generate: 20 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, 0h55m00s, 1h00m00s, 1h05m00s, 1h10m00s, 1h15m00s, 1h20m00s, 1h25m00s, 1h30m00s, 1h35m00s, )
07:58:14.558 Important Starting video encoding: [Memory load 36%] [Available virtual memory 2944 Mb.]
07:58:14.532 Info Hardware decoding: H.264 variable-length decoder, no film grain technology using Adapter #0 - NVIDIA GeForce RTX 2070 SUPER, converting h264 to yuv420p
07:58:14.485 Verbose FFmpeg Opening file D:\VUZE downloads\Buffaloed.2019.720p.AMZN.WEBRip.800MB.x264-GalaxyRG[TGx]\Buffaloed.2019.720p.AMZN.WEBRip.800MB.x264-GalaxyRG.mkv
07:58:06.863 Verbose FFmpeg Opening file D:\VUZE downloads\Buffaloed.2019.720p.AMZN.WEBRip.800MB.x264-GalaxyRG[TGx]\Buffaloed.2019.720p.AMZN.WEBRip.800MB.x264-GalaxyRG.mkv
07:58:06.862 Group ******************** Titleset #2 - ~95 min. File: "Buffaloed.2019..x264-GalaxyRG" -> 00001.m2ts - Blu-ray ********************|GK_TITLESET|
07:58:18.902 Warning File encoding cancelled by user: 00000.m2ts - step preparing titles
07:58:11.432 Info H264 settings for stream #1: preset=superfast,qmin=-1,lmin=354,mblmin=354,b=5100000,bt=50M,maxrate=40000000,minrate=0,me_method=epzs,codec=h264_nvenc,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1/24,bf=3,refs=4,h264_level=4.1,bufsize=30000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,gpu_id=0,qmax=-1,pass_number=1,threads=8
07:58:11.430 ------------ +--> [subtitle #5 - hdmv_pgs_subtitle subtitle, 1920x1080 (Default)]
Video filters used:
07:58:11.429 Info Chapters to generate: 25 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, 0h55m00s, 1h00m00s, 1h05m00s, 1h10m00s, 1h15m00s, 1h20m00s, 1h25m00s, 1h30m00s, 1h35m00s, 1h40m00s, 1h45m00s, 1h50m00s, 1h55m00s, 2h00m00s, )
07:58:11.428 Important Starting video encoding: [Memory load 34%] [Available virtual memory 3400 Mb.]
07:58:09.846 Info Hardware decoding: H.264 variable-length decoder, no film grain technology using Adapter #0 - NVIDIA GeForce RTX 2070 SUPER, converting h264 to yuv420p
07:58:09.628 Verbose FFmpeg Opening file D:\VUZE downloads\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG[TGx]\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG.mkv
07:58:06.845 Info Menu fit: Text size reduced from 36.00 to 14.00 in style "Title of root menu pages"
07:58:04.977 Verbose FFmpeg Opening file D:\VUZE downloads\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG[TGx]\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG.mkv
07:58:04.976 Group ******************** Titleset #1 - ~123 min. File: "Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x26" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
07:58:04.970 Info Encoding options: Long Project (Automatic)
07:58:04.969 Info Target size: 46000 Mb.
07:58:04.968 Important Setting queuer for Blu-ray output: [Wait: 4000], [ld: 1000], [Hd: 10000], [MAM: 600], [RM: 500], [ALL: True]
07:58:04.967 Important Reduced simultaneous conversions to 4 because the output is a Blu-ray Full HD
07:58:04.966 Info Don't log FFMpeg log events
07:58:04.965 ------------ ***************************************************Burn settings end****************************************************
07:58:04.965 Info Default speed selected: 4x
07:58:04.964 Info [ ] Delete vsomsl files after burn complete
07:58:04.964 Info [ ] Delete output folder after burn complete
07:58:04.963 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
07:58:04.962 Info SAO setting: Automatic
07:58:04.962 Info [x] Burn result to disk / as ISO file in working folder
07:58:04.961 ------------ **************************************************Burn settings begin***************************************************
07:58:04.961 Group Encoding session started at 07:58:04: 9 titleset(s) to encode -> Cancelled after 00:00:09|GK_CONVERT_SESSION|
07:57:04.116 Info Removed segment: Bait.2019.1080p.WEB-DL.H264.AC3-EVO
07:57:00.713 Important Loaded with result [File ]
07:57:00.471 Info Loading: "D:\VUZE downloads\Bait.2019.1080p.WEB-DL.H264.AC3-EVO[TGx]\Bait.2019.1080p.WEB-DL.H264.AC3-EVO.mkv - File" 1/1
07:57:00.288 Info Sources filtered, found 1 protocols
07:56:59.973 Info Added protocol D:\VUZE downloads\Bait.2019.1080p.WEB-DL.H264.AC3-EVO[TGx]\Bait.2019.1080p.WEB-DL.H264.AC3-EVO.mkv, candidate 1/1
07:56:59.814 Info Found 1 candidates
07:56:59.615 Info Filtering sources
07:56:59.615 Group Loading file(s)
07:56:24.894 Important Loaded with result [File ]
07:56:24.658 Info Loading: "D:\VUZE downloads\Jay.and.Silent.Bob.Reboot.2019.1080p.Blu-ray.DTS-HD.MA.5.1.HEVC-DDR[EtHD]\Jay.and.Silent.Bob.Reboot.2019.1080p.Blu-ray.DTS-HD.MA.5.1.HEVC-DDR[EtHD].mkv - File" 1/1
07:56:24.482 Info Sources filtered, found 1 protocols
07:56:24.175 Info Added protocol D:\VUZE downloads\Jay.and.Silent.Bob.Reboot.2019.1080p.Blu-ray.DTS-HD.MA.5.1.HEVC-DDR[EtHD]\Jay.and.Silent.Bob.Reboot.2019.1080p.Blu-ray.DTS-HD.MA.5.1.HEVC-DDR[EtHD].mkv, candidate 1/1
07:56:24.000 Info Found 1 candidates
07:56:23.813 Info Filtering sources
07:56:23.813 Group Loading file(s)
07:56:09.000 Important Loaded with result [File ]
07:56:08.764 Info Loading: "D:\VUZE downloads\Jay.and.Silent.Bob.Strike.Back.2001.BluRay.1080p.x264.AC3-5.1-iLL\Jay.and.Silent.Bob.Strike.Back.2001.BluRay.1080p.x264.AC3-5.1iLL.mkv - File" 1/1
07:56:08.598 Info Sources filtered, found 1 protocols
07:56:08.300 Info Added protocol D:\VUZE downloads\Jay.and.Silent.Bob.Strike.Back.2001.BluRay.1080p.x264.AC3-5.1-iLL\Jay.and.Silent.Bob.Strike.Back.2001.BluRay.1080p.x264.AC3-5.1iLL.mkv, candidate 1/1
07:56:08.141 Info Found 1 candidates
07:56:07.943 Info Filtering sources
07:56:07.943 Group Loading file(s)
07:55:25.153 Important Loaded with result [File ]
07:55:24.908 Info Loading: "D:\VUZE downloads\The.Souvenir.2019.1080p.BluRay.X264-AMIABLE[EtHD]\The.Souvenir.2019.1080p.BluRay.X264-AMIABLE[EtHD].mkv - File" 1/1
07:55:24.745 Info Sources filtered, found 1 protocols
07:55:24.420 Info Added protocol D:\VUZE downloads\The.Souvenir.2019.1080p.BluRay.X264-AMIABLE[EtHD]\The.Souvenir.2019.1080p.BluRay.X264-AMIABLE[EtHD].mkv, candidate 1/1
07:55:24.248 Info Found 1 candidates
07:55:24.076 Info Filtering sources
07:55:24.076 Group Loading file(s)
07:55:15.091 Info Removed segment: The.Irishman.2019.1080p.NF.WEB-DL.DDP5.1.Atmos.H.265.HDR-Pawel2006
07:55:00.729 Important Loaded with result [File ]
07:55:00.480 Info Loading: "D:\VUZE downloads\The.Irishman.2019.1080p.NF.WEBRip.x265.10bit.HDR.DDP5.1.Atmos-pawel2006\The.Irishman.2019.1080p.NF.WEB-DL.DDP5.1.Atmos.H.265.HDR-Pawel2006.mkv - File" 1/1
07:55:00.300 Info Sources filtered, found 1 protocols
07:55:00.187 Info Added protocol D:\VUZE downloads\The.Irishman.2019.1080p.NF.WEBRip.x265.10bit.HDR.DDP5.1.Atmos-pawel2006\The.Irishman.2019.1080p.NF.WEB-DL.DDP5.1.Atmos.H.265.HDR-Pawel2006.mkv, candidate 1/1
07:55:00.025 Info Found 1 candidates
07:54:59.749 Info Filtering sources
07:54:59.749 Group Loading file(s)
07:54:47.604 Important Loaded with result [File ]
07:54:47.370 Info Loading: "D:\VUZE downloads\The.Favourite.2018.1080p.BluRay.x264-SPARKS[EtHD]\the.favourite.2018.1080p.bluray.x264-sparks[EtHD].mkv - File" 1/1
07:54:47.225 Info Sources filtered, found 1 protocols
07:54:46.925 Info Added protocol D:\VUZE downloads\The.Favourite.2018.1080p.BluRay.x264-SPARKS[EtHD]\the.favourite.2018.1080p.bluray.x264-sparks[EtHD].mkv, candidate 1/1
07:54:46.760 Info Found 1 candidates
07:54:46.575 Info Filtering sources
07:54:46.575 Group Loading file(s)
07:53:56.433 Info Removed segment: EVO
07:51:12.015 Important Loaded with result [File ]
07:51:11.784 Info Loading: "D:\VUZE downloads\The.Wrong.Missy.2020.UHD.MULTI.2160p.HDR.WEBRip.DDP.5.1.HEVC-DDR[EtHD]\The.Wrong.Missy.2020.UHD.MULTI.2160p.HDR.WEBRip.DDP.5.1.HEVC-DDR[EtHD].mkv - File" 1/1
07:51:11.638 Info Sources filtered, found 1 protocols
07:51:11.530 Info Added protocol D:\VUZE downloads\The.Wrong.Missy.2020.UHD.MULTI.2160p.HDR.WEBRip.DDP.5.1.HEVC-DDR[EtHD]\The.Wrong.Missy.2020.UHD.MULTI.2160p.HDR.WEBRip.DDP.5.1.HEVC-DDR[EtHD].mkv, candidate 1/1
07:51:11.378 Info Found 1 candidates
07:51:11.117 Info Filtering sources
07:51:11.117 Group Loading file(s)
07:50:51.566 Important Loaded with result [File ]
07:50:51.312 Info Loading: "D:\VUZE downloads\Spenser.Confidential.2020.1080p.NF.WEB-DL.DDP5.1.X264-EVO[TGx]\Spenser.Confidential.2020.1080p.NF.WEB-DL.DDP5.1.X264-EVO.mkv - File" 1/1
07:50:51.153 Info Sources filtered, found 1 protocols
07:50:50.843 Info Added protocol D:\VUZE downloads\Spenser.Confidential.2020.1080p.NF.WEB-DL.DDP5.1.X264-EVO[TGx]\Spenser.Confidential.2020.1080p.NF.WEB-DL.DDP5.1.X264-EVO.mkv, candidate 1/1
07:50:50.688 Info Found 1 candidates
07:50:50.510 Info Filtering sources
07:50:50.510 Group Loading file(s)
07:50:30.756 Important Loaded with result [File ]
07:50:30.527 Info Loading: "D:\VUZE downloads\Resistance.2020.1080p.BluRay.x264-GECKOS[TGx]\resistance.2020.1080p.bluray.x264-geckos.mkv - File" 1/1
07:50:30.374 Info Sources filtered, found 1 protocols
07:50:30.265 Info Added protocol D:\VUZE downloads\Resistance.2020.1080p.BluRay.x264-GECKOS[TGx]\resistance.2020.1080p.bluray.x264-geckos.mkv, candidate 1/1
07:50:30.104 Info Found 1 candidates
07:50:29.790 Info Filtering sources
07:50:29.790 Group Loading file(s)
07:50:05.386 Important Loaded with result [File ]
07:50:05.149 Info Loading: "D:\VUZE downloads\Buffaloed.2019.720p.AMZN.WEBRip.800MB.x264-GalaxyRG[TGx]\Buffaloed.2019.720p.AMZN.WEBRip.800MB.x264-GalaxyRG.mkv - File" 1/1
07:50:05.004 Info Sources filtered, found 1 protocols
07:50:04.660 Info Added protocol D:\VUZE downloads\Buffaloed.2019.720p.AMZN.WEBRip.800MB.x264-GalaxyRG[TGx]\Buffaloed.2019.720p.AMZN.WEBRip.800MB.x264-GalaxyRG.mkv, candidate 1/1
07:50:04.498 Info Found 1 candidates
07:50:04.317 Info Filtering sources
07:50:04.317 Group Loading file(s)
07:49:07.299 Important Loaded with result [File ]
07:49:07.050 Info Loading: "D:\VUZE downloads\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO.mkv - File" 1/1
07:49:06.895 Info Sources filtered, found 1 protocols
07:49:06.790 Info Added protocol D:\VUZE downloads\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO.mkv, candidate 1/1
07:49:06.627 Info Found 1 candidates
07:49:06.368 Info Filtering sources
07:49:06.368 Group Loading file(s)
07:48:54.847 Important Loaded with result [File ]
07:48:54.622 Info Loading: "D:\VUZE downloads\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG[TGx]\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG.mkv - File" 1/1
07:48:54.452 Info Sources filtered, found 1 protocols
07:48:54.121 Info Added protocol D:\VUZE downloads\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG[TGx]\Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG.mkv, candidate 1/1
07:48:53.970 Info Found 1 candidates
07:48:53.801 Info Filtering sources
07:48:53.801 Group Loading file(s)
07:48:41.389 Info Removed segment: EVO
07:48:35.930 Important Loaded with result [File ]
07:48:35.694 Info Loading: "D:\VUZE downloads\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO.mkv - File" 1/1
07:48:35.548 Info Sources filtered, found 1 protocols
07:48:35.235 Info Added protocol D:\VUZE downloads\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO.mkv, candidate 1/1
07:48:35.068 Info Found 1 candidates
07:48:34.866 Info Filtering sources
07:48:34.866 Group Loading file(s)
07:48:13.181 Info Update check returned that version is up to date
07:48:12.969 Info Personnal resources size (C:\Users\inkey\Documents\ConvertXtoHD_Resources\): 0MB, 0 file(s)
07:48:12.766 Info Monotonizer size (C:\ProgramData\vso\vsomsl): 0MB, 23 file(s)
07:48:12.565 Info Thumb cache size (C:\ProgramData\VSO\vsothumbs): 62MB, 75 file(s)
07:48:12.360 Info Logs and templates size (C:\ProgramData\VSO\ConvertXtoHD\3\): 74MB, 663 file(s)
07:48:12.149 Group Folder data
07:48:12.142 Info Menu templates loaded: 20
07:48:11.384 Info License status: active customer license
07:48:11.384 Info License type: commercial (online activated)
07:48:11.384 Info Computer ID: 4050210
07:48:11.384 Group License
07:48:08.321 Info Loading templates from: "C:\Users\inkey\Documents\ConvertXtoHD_Resources\Templates\"
07:48:08.321 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoHD\3\Templates\"
07:48:08.318 ------------ **************************ConvertXToHD.exe:110848 Log session start 2020-10-12 at 07:48:07.926**************************
10:52:10.131 Info Parsing disc ...
10:52:02.019 Info WRITE SUCCESS: Disc written
10:51:53.866 Info Burning process completed successfully.
10:51:53.858 Info Finalization Time 00:00:22.780 - Total completion time 00:32:26.670
10:51:53.849 Info Finalize: Finalisation completed
10:51:53.842 Info Finalize: Close disc - Completed
10:51:40.186 Info Finalize: Start Close media
10:51:40.181 Info Finalize: Close session - Completed
10:51:37.667 Info Finalize: Start Close session
10:51:37.659 Info Finalize: Close track - Completed
10:51:35.145 Info Finalize: Start Close track
10:51:35.137 Info Finalize: Flush device cache - Completed
10:51:31.081 Info Finalize: Flushing burner cache
10:51:31.077 Info Write finished in 00:32:03.892 - Finalization start here. Avg. burn rate 3.91
10:51:31.069 Info Finalize: Start disc finalisation
10:19:50.714 Info WRITING: Lead-in burning time required 00:00:23.530
10:19:27.183 Info Write started 16502336 sectors to write
10:19:27.179 Info Init BD-R: Success
10:19:27.168 Info Write speed set at x4.0 (17982 kB/s)
10:19:27.117 Info Available write speed: x6.0 (26973 kB/s) *, x4.0 (17982 kB/s), x2.0 (8991 kB/s)
10:19:27.112 Info Media ID: RITEK-DR3-00
10:19:26.944 Info Scanned files #475, folder #16 - total size 33792493246 b. (31.5 GB.)
10:19:26.940 Info Inserted media type : bd-r sequential recording
10:19:26.932 Info Volume ID: Eurovision.Song.Contest.The.Story.of.Fire.Saga.2020.1080p.NF.WEB-DL.DDP5.1.x264-CMRG
10:19:26.928 Info Folder: C:\USERS\INKEY\DOCUMENTS\CONVERTXTOHD\EUROVISION.SONG.CONTEST.THE.STORY.OF.FIRE.SAGA.2020.1080P.NF.WEB-DL.DDP5.1.X264-CMRG\
10:19:26.914 Info Write started
10:19:25.823 Info Blu-ray/AVCHD structure burn process started
10:19:10.868 Info Writable disc bd-r sequential recording inserted. Ready to write
10:19:08.811 Info Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu-Ray-R, Blu-Ray-RE (V1), Blu-Ray-RE (V2)
10:19:08.810 Info Drive has Serial ATA physical interface
10:19:08.810 Info New Drive selected : [G] HL-DT-ST BD-RE BH10LS30 1.00 (USB)
07:48:08.315 Info 2 writer(s) found.
07:48:08.287 Group Burn engine events
+-[audio [eng] DTS HD-Master main audio 6 Ch. 48000Hz ]
+--> [video #1 - h264_opencl video, 1280x720, yuv420p, 16x9, 23.98Fps, 5100Kbps]
Video filters used:
- DeInterlace filter: VSO
+--> [audio #2 - ac3 audio, 48000Hz, Stereo, 224000 bps [English]]
+--> [video #1 - h264_nvenc video, 1280x720, yuv420p, 16x9, 23.98Fps, 5100Kbps]
Video filters used:
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: letterbox (Padding: top: 94, bottom: 94, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
Video filters used:
Video filters used:
Video filters used:
You are using ConverxToHD 3.0.0.71.
The latest version is 3.0.0.73.
Maybe if you try that one it works for you.
Nemesh
Nemesh
Thanks - not sure if that will change anything - but I hope it does
Will try that on the next burn
Thanks again
Thanks again
Are you sure?
As it says I am up to date
I then looked directly on the website and that also says 3.0.0.71 is the newest version
Anyone know of any other reason - is there a best way to contact VSO and ask them directly [?] as I presume they don't answer the forums [?]
Look here please: viewtopic.php?f=53&t=20817
I didn't see there was a 'secret' newer update
Thanks again for that
Alas it made no difference
The same files [that work perfectly on PC - before burned to blu-ray] don't burn correctly
Gah
I guess noone else has had this issue?
Gah
Can you get codec info from all files here?
You have so many files going on those logs that it is a mess to check.
Is your problem the same as this one: viewtopic.php?f=53&t=20899
Also, if your empty BD's are 6x speed don't write faster.
Keep write settings to 6x speed.
Create a .iso file from the BD files ConvertXtoHD created.
This can be done with ImgBurn: http://www.imgburn.com/
The write the .iso file to a empty BD with ImgBurn,
Check three options in ImgBurn:
1. Check the option 'Verify' (see screenshot 1)
2. Check in the settings 'Verify Against Image' to on (Screenshot 2)
3. Check 'Preform OPC Before Write' (OPC = Optimum Power Calibration)
Do you have the lastest firmware installed in your BD writer?
I see that you have a external USB LG writer with firmware 1.00 (first release).
Often new firmwares are released witch improve writing etc.
You can read how to do that here: https://www.lg.com/us/support/help-libr ... 4654347994
This way you can eliminate write errors then can cause a not readable disc (Coaster).
With regards,
Nemesh
With regards,
Nemesh
Nemesh wrote: ↑Mon Oct 19, 2020 8:20 am Is your problem the same as this one: viewtopic.php?f=53&t=20899
Thanks - but no
I would best describe it as - showing pixelated frames... but only showing a few. So you see a slow/stuttery framerate, and those frames are 'low fi' or pixelated. These seems to be through out the affected films.
I tried again using convertXto Video Ultimate 2
Same results
Always the same films effected [so if x doesn't work one time, it never works]
In this 'run' 6 of the 8 films didn't work
With the stuttering - I wonder if it's a frame rate issue? Have I set up the frame rate to mess up somehow [I guess not, as noone picked up an issue from the log file]
Ever since the issue started I have always been burning at 2x to give it the best chance to work
Nemesh wrote: ↑Mon Oct 19, 2020 8:20 am Create a .iso file from the BD files ConvertXtoHD created.
Now... on ConvertXto Video Ultimate 2... I can watch the video files back from the advanced edit option - I don't know if that is the processed version or the original version... but that plays back fine. If that is the processed version [to burn] - then it has to be 100% a burn and not a processing issue... so maybe it's the BluRay player?
Ok - there is an upgrade but it seems rather complex to add firmware in that everything has to be off. And I am not 100% sure if it's correct...Nemesh wrote: ↑Mon Oct 19, 2020 8:20 am Do you have the lastest firmware installed in your BD writer?
With regards,
Nemesh
New firmware(Ver. 1.02)) for only BH10LS30(SUPER MULTI BLUE)
Not sure if I have 'super multi blue' - and have no way to work that out
This was written is 2014 and says: This firmware update can works with Windows based OS(Windows 8, 7, Vista and XP
I guess Windows 10 is fine... but not sure...
I guess I need to try the .iso thing and then try updating the firmware... argh
Thanks ever so much for your help
Best wishes
Right I did the ImgBurn
And that had exactly the same results
I will put the log below
NOTE: [maybe normal] but the blu-ray in the player can't be read/played on PC apps like VLC/etc just says nor readable. I guess that may be normal for a Blu-Ray with mulitple files ?
So I am left with the 'firmware' update I really didn't want to do - as it sounds sketchy
Thanks again for you help
ImgBurn log file:
; ImgBurn Version 2.5.8.0 - Log
; Saturday, 24 October 2020, 10:23:18
I 10:09:10 ImgBurn Version 2.5.8.0 started!
I 10:09:10 Microsoft Windows 8 Core x64 Edition (6.2, Build 9200)
I 10:09:10 Total Physical Memory: 33,480,940 KiB - Available: 19,842,640 KiB
I 10:09:10 Initialising SPTI...
I 10:09:10 Searching for SCSI / ATAPI devices...
I 10:09:10 -> Drive 1 - Info: ATAPI iHAS124 F CL9N (E:) (SATA)
I 10:09:10 Found 1 DVD±RW!
W 10:11:41 Device Arrival Detected!
I 10:11:41 Searching for SCSI / ATAPI devices...
I 10:11:41 -> Drive 1 - Info: HL-DT-ST BD-RE BH10LS30 1.00-A9 (G:) (USB 2.0)
I 10:11:41 -> Drive 2 - Info: ATAPI iHAS124 F CL9N (E:) (SATA)
I 10:11:41 Found 1 DVD±RW and 1 BD-RE!
I 10:16:40 Operation Started!
I 10:16:40 Building Image Tree...
I 10:16:57 Calculating Totals...
I 10:16:57 Preparing Image...
I 10:16:58 Contents: 597 Files, 16 Folders
I 10:16:58 Content Type: BD Video
I 10:16:58 Data Type: MODE1/2048
I 10:16:58 File System(s): UDF (2.50)
I 10:16:58 Volume Label: Master Js Marverlous Movies
I 10:16:58 Size: 36,827,786,605 bytes
I 10:16:58 Sectors: 17,982,761
I 10:16:58 Image Size: 36,832,215,040 bytes
I 10:16:58 Image Sectors: 17,984,480
I 10:17:02 Operation Successfully Completed! - Duration: 00:00:21
I 10:17:02 Operation Started!
I 10:17:02 Image Contents: 597 Files, 16 Folders
I 10:17:02 Image Sectors: 17,984,480 (MODE1/2048)
I 10:17:02 Image Size: 36,832,215,040 bytes
I 10:17:02 Image Volume Identifier: Master Js Marverlous Movies
I 10:17:02 Image Volume Set Identifier: 5158521401126909
I 10:17:02 Image Application Identifier: ImgBurn v2.5.8.0
I 10:17:02 Image Implementation Identifier: ImgBurn
I 10:17:02 Image File System(s): UDF (2.50)
I 10:17:02 Destination File: C:\Users\inkey\Documents\ConvertXtoHD\TEST ISO\Master Js Marverlous Movies.iso
I 10:17:02 Destination Free Space: 350,365,425,664 Bytes (342,153,736.00 KiB) (334,134.51 MiB) (326.30 GiB)
I 10:17:02 Destination File System: NTFS
I 10:17:02 File Splitting: Auto
I 10:17:02 Writing Image...
I 10:23:06 Operation Successfully Completed! - Duration: 00:06:03
I 10:23:06 Average Write Rate: 99,088 KiB/s (22.6x) - Maximum Write Rate: 491,086 KiB/s (111.9x)
I 10:23:18 Close Request Acknowledged
I 10:23:18 Closing Down...
I 10:23:18 Shutting down SPTI...
I 10:23:18 ImgBurn closed!
; Saturday, 24 October 2020, 10:09:03
I 10:00:44 ImgBurn Version 2.5.8.0 started!
I 10:00:44 Microsoft Windows 8 Core x64 Edition (6.2, Build 9200)
I 10:00:44 Total Physical Memory: 33,480,940 KiB - Available: 19,830,208 KiB
I 10:00:44 Initialising SPTI...
I 10:00:44 Searching for SCSI / ATAPI devices...
I 10:00:44 -> Drive 1 - Info: ATAPI iHAS124 F CL9N (E:) (SATA)
I 10:00:44 Found 1 DVD±RW!
I 10:05:29 Operation Started!
I 10:05:29 Building Image Tree...
I 10:05:43 Corrected file system selection for Blu-ray Video disc.
I 10:05:43 Corrected UDF revision selection for Blu-ray Video disc.
I 10:05:43 Calculating Totals...
I 10:05:43 Preparing Image...
I 10:05:43 Contents: 597 Files, 16 Folders
I 10:05:43 Content Type: BD Video
I 10:05:43 Data Type: MODE1/2048
I 10:05:43 File System(s): UDF (2.50)
I 10:05:43 Volume Label: [Not Configured]
I 10:05:43 Size: 36,827,786,605 bytes
I 10:05:43 Sectors: 17,982,761
I 10:05:43 Image Size: 36,832,215,040 bytes
I 10:05:43 Image Sectors: 17,984,480
I 10:05:43 Operation Successfully Completed! - Duration: 00:00:13
I 10:09:02 Close Request Acknowledged
I 10:09:02 Closing Down...
I 10:09:03 Shutting down SPTI...
I 10:09:03 ImgBurn closed!
ImgBurn log file:
My guess is that you're using a real assortment of unusual and non-standard sizes (i.e. resolutions and bitrates) for input files, mixed formats for both audio and video, and requiring that XtoHD do transcoding and conversions and re-sizing of both audio and video from whatever input format it finds to your single designated output resolution format fps and audio bitrate.
I'm sure XtoHD is theoretically supposed to be able to do whatever is required. But I simply point out that some of your input files may present "challenges".
Looking at the LOG copies you posted and ignoring subtitle information, here is what I can pick up regarding just audio/video input and output. You're picking up a whole variety of inputs, and putting out 1280x720p, 23.97fps, 5100Kbps:
10:17:29.022 ------------ *****************************************File encoded successfully: 00008.m2ts******************************************
+-[video [eng] hevc 1920x800 12:5 yuv420p10le, 23.98Fps, 0Kbps ]
09:44:48.001 ------------ *****************************************File encoded successfully: 00007.m2ts******************************************
+-[audio [eng] vorbis main audio 2 Ch. 48000Hz ]
+-[video [eng] h264 1920x816 40:17 yuv420p, 23.98Fps, 0Kbps ]
09:53:00.491 ------------ *****************************************File encoded successfully: 00006.m2ts******************************************
+-[audio [eng] dts main audio 6 Ch. 48000Hz , 1536 Kbps]
+--> [video #1 - h264_nvenc video, 1920x1080, yuv420p, 16x9, 23.98Fps, 5100Kbps]
+-[video dxva2 h264 1808x1080 226:135 dxva2_vld, 23.98Fps, 0Kbps ]
09:45:44.324 ------------ *****************************************File encoded successfully: 00005.m2ts******************************************
+-[video dxva2 h264 1920x1040 24:13 dxva2_vld, 23.98Fps, 0Kbps ]
Your HD is very fragmented or has bad sectors if you can watch the movies on your PC but cannot watch them from the burned blurays/DVDs.
Individually each source video is easily playable. It's just one video file, and is rendered by the software media player without a problem.modmoomita wrote: ↑Sun Dec 06, 2020 9:00 am Your HD is very fragmented or has bad sectors if you can watch the movies on your PC but cannot watch them from the burned blurays/DVDs.
What he's trying to do here is take 8 different videos, almost all of them of almost random HxW aspect ratio and differing bit rate and FPS and codec, and ask CXtoHD to convert every one of them to either 1280x720 or 1920x1080 and some form of H.264 compression, and only 5100Kbps. I suspect it's just too much to ask of CXtoHD to have 100% success. It's probable that not all of them have been properly converted, or if they have been converted have had their video quality severely impaired.
I'm just speculating.
I try to burn discs of a similar nature - in my case, generally old films, mix of SD and HD, collected together on a blu ray for convenience. Like you, I have exactly the same problem. There is something about some of the files that Convert doesn't like, and the film stutters when you watch it, as if frames are missing. It's perhaps most noticeable in a scene where the camera pans from right to left or vice versa. It is as annoying as hell, but I have tried everything I can to correct it. I must have gone through every permutation in the settings menu, and none of them change anything. And it's not the the burning side of things, as I have changed my burner and it's still the same. And the problematic files seemingly have nothing in common.
